Question about Yamaha HTR-3065
My amplifier turns on, but will not produce sound for several minutes
The sounds will not come on
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: Yamaha YST-SW320 subwoofer won't play sound
I too have amplifier and speakers thatI rent for parties, and sometimes when I connect them they don't work and I battle with them for hours before I find the out that its just a little thing that happened, like speaker wire might have cut inside, or the wire conneted for the CD to Amplifier is bad and son on.
But I will advice that you test your amplifier and woofer, with another equipment independently to be sure if they still working well or not. As this will help you to know what to do next.
May somthing happened to one of them the last time you used it and you did not notice, and it might just need some servicing.
Best wishes
Posted on Nov 13, 2009
Philips home theater suddenly doesn't produce sounds
Sounds like the main amplifier section circuit inside the system is damaged. Contact any service technician, or the authorized service center for Philips.
Jul 13, 2015 | Philips Audio Players & Recorders
How do I reset my pioneer deh-x6500bt car stereo and produce sound from my rear speakers?
a 'reset' of the entire stereo should be able to be accomplished by disconnecting the battery for several minutes: alternately if you remove the faceplate there should be a reset button you would need a pen to press, however you should be able to find the EQ levels and set the balance and fade I think it is so the rear produces sound, if that is not the case, I would check wiring to make sure nothing is loose. I suppose it could only be a software/firmware problem with the stereo itself however, if you have had this happen before and it was fixed without tinkering with the wiring.
Jul 30, 2014 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
Bose solo tv sound system suddenly stopped producing sound
I have had this happen several times now. Unplug the Bose power plug for a few minutes, then plug the power back in and turn the Bose back on. It has reset the Bose unit everytime and the audio is back.
Jun 09, 2014 | Bose Solo TV sound system - Black
I got a LG ht33s subwoofer to my denon avr1513. Connected with RCA cable but no sound.
make sure the wattage of the amplifier has the same amount or more wattage to the subwoofer otherwise it will not be able to produce sound because of power complications
Dec 07, 2013 | Denon AVR-1513
My s-master digital amplifier was suddenly not working and would not produce sound. It flashes UNPLUG, PROTECT. I have unplugged several cords but with no luck.
You must remove the power to the amplifier to allow it to reset, find the fault with the speaker leads or short circuit wires and then plug back into the power.
Feb 27, 2011 | Televison & Video
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
Technics HD560 Losing Sound
Hello sir, there are several things you should check for, first the impedance of the amp and speakers, do they match 8ohms to 8ohms, two the amplifiers heat sink is it sufficient? or the amp. may need an extra cooling fan. third the main amplifier is the culprit. check each one and let me know if there is progress. thanks
Jul 18, 2009 | Audio Players & Recorders
No sound
When the amplifier will turn on but not produce any sound that is usually an indication of either the high voltage power supply inside the amplifier is not working, or the amplifier IC or amplifier circuit is damaged. It is not something that can be repaired unless you have experience working on electronics.
Dec 30, 2008 | Sony TA-N9000ES 5-Channel Amplifier
Mtx 1501d
ARE U USING THE CONTROLS THAT CAME WITH THE AMP?
USUALLY THE CONTROLS CABLE GOES BAD
May 08, 2008 | MTX Thunder 1501D Car Audio Amplifier
Not producing sound
It sounds like the power supply may have failed. I'm not familiar with that particular Boss amp but many amplifiers will light the power indicator even though the amp isn't operating.
Have you checked your speakers to see if they're blown?
Have you checked the wiring to make sure the speakers are still connected to the amp?
Dec 19, 2007 | Car Audio & Video
Yamaha HTR-3065 Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
