Question about Pioneer Car Audio & Video
Cnp 6899 jack pin are not connected properly so that control panel is not working
3 Suggested Answers
siawolf
  • 749 Answers
SOURCE: Need proper wiring for the J9C2 connector pinout
The User Manual for this m/board (E210882) can be found at :- ftp://download.intel.com/support/motherboards/desktop/d865glc/BFLC_English.pdf
you will need adobe free reader to view it. refer to pages 40 thru 46 for the front panel header and isb info.
Posted on Apr 01, 2009
ebay312
  • 118 Answers
SOURCE: 34 pin FRONT PANEL insert locations.
http://support.dell.com/support/edocs/systems/opgx270/en/ug/specs.htm
This link should open an html document from Dell, providing you with all the information you seek.
good luck
tony
Posted on May 23, 2009
Bad connection on 5 pin mic jack on realistic trc-469. Wiggle it and it'll work. But how does it come out ? Have a new 4 pin to replace it with. Can't find the break.
With the CB radio off & not connected to power, check or have a friend check the contact points, at each end with a Volt/Ohm Meter.
Oct 10, 2016 | Radio Communications
Need manual to show how to hook up vcr to tv and then how to get it to work. hooked up but not getting a picture or sound.
no need for a amanual so long as you connect properly. check for the provision of a video and sound inputs terminals in your television and connect the video and sound cables as required. note that the white jack pin is connected to the terminal marked white and the red to red as well. if the cable has the third jack pin which is yellow then connect the yellow for video input. then power both the dvd and the television then switch on and select video mode on the remote
Sep 21, 2011 | Televison & Video
Dear sir...greetings... i have a ibm fw82801db motherboard which is working fine... the main problem what i am facing is i have a 20 pin front panel jack like FDD jack as unable to connect my front...
Because of the many configuration of motherboard, I can possibly know how to help you with this problem without the keyboard in front of me. The best advice to you is to go back to the manual to find the proper connection of those jumpers.
Feb 26, 2011 | Intel Desktop Board D845HV Motherboard
Front panel connectors/jacks is not working
OK--usually what you will find from the front is 3 connectors.
One will be a solid block that has one blank hole which is the key. That will plug into the corresponding pins on the motherboard--usually toward the back of the case.
There will be another other wire that terminates in two plastic connectors. These are the USB connectors. Sometimes the connectors are in two parts. One is a 3-hole and one is a 1-hole. Usually you will find two sets as they sort of go together.
The pin configuration on the motherboard looks like this ::::.
The single pin on the end is not used. The other ones are connected with the plastic connector on the first three starting at the left, with the end marked VCC to the left. The fourth pin is the ground which is usually the separate connector.
The second USB connectors are plugged in right next to the first--so each block of pins controls 2 USB ports.
Hope this helps.
May 14, 2009 | ASUS Computers & Internet
HOW TO CONNECT 5.1 WITH DELL STUDIO 15(1555) LAPTOP
Open up Control Panel and navigate to IDT Audio Control Panel.
On the right hand side, there would be an image depicting the jacks available on the 1555. Left click on the respective jacks and change them corresponding to the 5.1 outputs. 21d6042.jpg
Apr 26, 2009 | Dell Studio 15 Laptop
Apr 01, 2009 | Dell Dimension 4600 PC Desktop
No sound out headphone jack
Are you connect the jack at front panel,if so just try with the backside of C.P.U.,If in this case it works that means you have to connect the front panel wires to your motherboard Pins.
Mar 25, 2009 | Toshiba Tecra A9-S9012X Notebook
TDK NX-7CD not working
With some of the TDK NX models the 9 pin lead between the subwoofer unit and the control unit gets damaged in careless connection. Its not the most idiot proof connection out there and when the connector is not aligned rotationally with the socket and/or pushed in at an angle, the connection pins can get bent. Sometimes if there arent too many pins bent, the pins can be carefully straightened and when properly inserted, the unit will work perfectly. In most cases however, one, or maybe even two fuses in the subwoofer unit will blow. If the unit doesnt work in your case after correcting the lead issue, open up the subwoofer unit by removing the screws around the outer edge of the back panel of the subwoofer (about 10 screws) and carefully prize the panel away from the subwoofer box. Sometimes this may be difficult as the back panel is glued to the subwoofer box to varying degrees. Dont pull the panel away from the box too far as it is connected internally by leads, etc. You should find the two fuses on the circuit boards attached the the inside of the back panel, one for the input transformer and one for the amplifier circuitry. Replace them (**** Smith or Tandy electronics stocks them) and you should be in business. If it still doesnt work, there may be some additional damaged caused, but this is rare. If you need a new lead, Imation (TDK) will supply you one at a cost. Hopefully you can get it up and running as it is a great little HiFi.
Mar 21, 2009 | TDK Audio Players & Recorders
Audio deosn't work on mobo
Hi Chris, the problem can be one of two issues. If the sound jack located at the back of the PC did function at the same time as the front case sound jack. Than the problem is the jack it's self is bad. (Back of PC). Someone had to hook up the front mic & sound jack to the motherboard. So disconnecting the front sound & mic may give you rear sound & mic.
Turn to page 2-29 in you're user manual for the Asus M2N-SLI. The pic shown is the default setting for the front case audio & mic. (What you do see are the two jumpers connected). So disconnect any connector & place a jumper over pins 9 & 10, (last two pins at the right of the two rows of pins). Place another jumper over pins 5 & 6.
Pin 1 is the first pin on the left bottom row (MIC2). Pin 2 is the first pin, left edge top row (AGND). Pin 8 is not installed but you still count its spot as if there was a pin. (This is how the board was setup from factory). Once you fix this you should regain sound & mic function at the rear of the PC. To fine tune the audio run the Asus sound effect manager. If you installed this software, (Recommended). If it’s not by you're clock than it’s in control panel.
Link to all for M2N-E SLI
http://support.asus.com/download/download.aspx?modelname=M2N-E%20SLI&SLanguage=en-us
Good Luck!
m
Jun 07, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Microphone is not working
1-adjust the overall volume by pressing fn+f 5 hotkeys
2-adjust sliding mixer controls by doubleclicking the speaker icon
3-disconnect the headphone jack to enable check of internel speaker.4-confirm that microphone plug is proper connected to mono mic jack.5-confirm that microphone is selected as recording source in control panel----multimedia and recording level is adjusted.
confirm that sound source is selected in control panel----multimedia
confirm that headphone connector connected in right postion
Jan 24, 2008 | Compaq PC Microphone (Black or Beige)...
Car Audio & Video Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
