Question about Refrigerators
Problems with a refrigerator
There seems to be a lot of moisture in the refrigerator. Is that how it is supposed to Be?
Ice maker in door has a lot of moisture and freezes
seems like u have a seal problem in the door ice making part. which is causing condensation
Mar 11, 2015 | Refrigerators
The unit just stopped extracting any moisture from the air. The fan runs and the compressor sounds like it turns on. I use the bucket to capture the moisture so do not have the pump on for the hose.
If the unit isnt extracting moisture in the air you have one of two problems a leak in the refrigeration system or the compressor is locked up. In my experience its probably a leak in the refrigeration system because they make the dehumidifiers very cheap and the coils are paper thin. Delonghi has a lot of issues with there dehumidifiers and any other appliance they make. Check to see if the compressor is running if it is then you have no freon in the system. You can access the compressor by the back panel and you will know if it is running. If it is a refrigeration leak buy a new unit it will be a whole lot cheaper and less stressful,.
If this helps please rate me.
Jun 27, 2011 | DeLonghi DE500P Dehumidifier
Our company has started manufacturing frost free display cases for Pastries & cakes. The problem we are facing is we are getting a lot of frost on glasses during the operation cycle. Due to this...
Make up a way to blow warm air from the condenser over the glass and your frost problem will disappear! The higher the temperature of the air - the more moisture it can absorb. The reason you are having the problem is that you are cooling moisture laden air and it has to give up the moisture as you cool it. So run some warm air over it and it will absorb the moisture for you = problem gone.
koolman77 (refrigeration technician)
Feb 07, 2011 | Jet Tech Systems Refrigerated Display...
It is leaking water from the freezer into the refrigerator
During the defrost cycle heaters inside the walls of the freezer turn on to melt the frost. The melted frost "water" is supposed to drain into a pan under the fridge where it will evaporate. I think the drain line from the freezer to this pan may be blocked. I'd also check the seal on the freezer door. If it's not sealing well it lets a lot of moisture into the freezer which means more water during the defrost cycle. I'd also recommend checking to make sure the ice maker is not leaking.
Jan 25, 2010 | Whirlpool Refrigerators
Refrigerator tilt
Refrigerators are designed to be level and drain properly.
Aug 24, 2009 | Whirlpool ED2FHEXN Side by Side...
My refrigerator door was left open for several hours, now it is not cold. Any suggestions? Also, ice maker is not working
It is going to take a long time to cool down a full fridge. You may have problems with moisture build up and frost. Don't worry it will take time but it will get cold again. If you have any meats please throw them away and save yourself the food poisioning. Please give me a good rating it means a lot to me.
Jul 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Build up of ice in bottom of freezer compartment
During the defrost cycle heaters in the wall of the freezer are turned on to melt the frost build up. This melted frost "water" is supposed to run out a drain in the bottom of the freezer and collect in a pan under the refrigerator/freezer where it will eventually evaporate. If this drain is blocked it will cause a lot of water to collect in the bottom of the freezer and that water will eventually turn back into ice. I recommend defrosting the freezer manually, removing all the ice/water buildup in the bottom, and trying to unplug the drain line to the pan underneath. Also check the seal on the freezer door. If it's not sealing well it could be letting a lot of moisture enter the freezer which would lead to more frost buildup and more water during the defrost cycle.
May 22, 2009 | Hoover HCA390FFK Bottom Freezer...
Water leaking from freezer
May 18, 2009 | Kenmore 64802 Top Freezer Refrigerator
Moisture inside freezer
Make sure the temperature is at the level its suppose to be and that hot air is not blowing on it or thats its not in a extremely hot area.If all checks out I'd be returning it..
Mar 29, 2009 | GE Refrigerators
Kenmore 253.54622406 Problem
I have had the experience of Moisture in the refrigeration system with some of this brand. If this is your problem it will require a refrigeration tech to recover the charge from the system, change the system drier, evacuate the system to remove air and moisture, then recharge the system with the proper refrigerant.
If your refrigerator is covered by warranty your cost should be minimal. If it is not covered by warranty it can be somewhat expensive. If it is a problem with the defrost system you will see frost build-up on the back freezer wall.
May 02, 2008 | Kenmore 54622 / 54624 Side by Side...
Refrigerators Logo
11 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
