Question about Brother Disney ULT-2002D
THREADER DOES NOT WORK
Needle threader won't work on my Singer 4423
The needle threader hook is very tiny and easily bent or damaged.
The needle threader is designed not to turn, if the needle is not at its most upper position to protect the threader - Turn hand wheel until needle reaches its highest position.
Needle not alining with threader hook - Replace needle.
Threader hook bent - Replace with new needle threader hook.
Hope this helps.
Read more from the link I attatched.
Good luck & have a nice day!
Automatic needle threader will not work
Jul 14, 2017 | Singer Sewing Machines
The needle threader on my Janome 6260 quit working. The needle is inserted correctly.
Is the threader broken or just not meeting the needle eye? If broken, it can most likely be repaired.
If the threader is not meeting the needle eye, adjust the needle height so the threader meets the eye and intercept the thread. I have a 60's machine with a threader that needs the needle height manually adjusted because the needle does not stop in any particular place. Usually, if I raise the needle to its highest, the threader will work.
Oct 06, 2016 | Janome Sewing Machines
Needle threader on 830 operates but will not let go of thread
1. Try a high quality thread; usually embroidery. Your thread sounds like Walmart. Look at it at a light and see if there is fuzz. That's bad thread.
If this doesn't work you have a threader that is bent out of shape causing it to hang on. You can attempt to adjust the threader with small pair of needle nose pliers, maybe even tweezers. Careful, it is fragile. The cost of replacement and a repairman will be over $ 50 so it is worth the try at home.
Oct 05, 2016 | Sewing Machines
Auto threader wont thread
Move the needle to the top.
Loosen the screw on the threader.
Use the threader as if you are using it. You will have to adjust it to the side and up or down. Move it so the threader is in the needle hole.
Tighten the needle.
If it still doesn't work you may need to replace the threader.
Apr 18, 2015 | Sewing Machines
Automatic threader doesn't work
The automatic needle threader is very tiny and easily bent or damaged; however, it is designed not to turn if needle is not at its most upper position to protect the threader. Turn the hand wheel until the needle is at the highest position. If the needle is not aligning with the threader hook, you will need to replace it. And you can replace the needle threader hook if it is bent. I hope this helps!Jimmy
Mar 27, 2012 | Brother Sewing Machines
Cant make the auto threader work on an elna 2007
Do you mean the auto needle threader?
Mine won't work on very small needle sizes so I resort to the old manual needle threader for these. Ditto for twin needles.
Otherwise its a case of pulling the auto threader down so the hook swings into the needle eye, then pulling the thread over the face of the needle and catching it into the hook, then release the threader so it pulls back through the needle eye, taking the thread with it.
The only other thing that springs to mind is "is the needle at the top position in its stich cycle so that the threader lines up with the needle eye?
hope these ideas help a little.
Dec 03, 2010 | Elna 2007 Mechanical Sewing Machine
The automatic threader does not work
Please refer to page 33 of the user's manual.
The needle has to be in the highest position for the needle threader to align with the eye of the needle.
Threaders will not work if the eye of the needle is too small for the wire on the threader.
Sometimes the wire gets bent if it was forced against a needle that was too small or if the needle was not in the correct position for the threader to work.
The wire can be bent back into place, but you have to be careful as it is very thin and can break.
If the wire is broken, the dealer can order a new threader - they are not very expensive and are easy to install.
Feb 19, 2010 | Brother XR-65t Mechanical Sewing Machine
Singer Athena automatic needle threader does not work.
Check on the threader and see if the part that goes through the eye of the needle is bent. This is a very common problem. The threaders are becoming more and more difficult to replace. If the piece is bent, you can usually use a pair of tweezers to straighten it out.
Feb 07, 2009 | Singer 132QRFB Mechanical Sewing Machine
The needle threader has stopped working
Check you needle size. On my machine the needle threader does not work with the smaller needles, 9/65 and 11/75. The eye of the needle appears to be just short of the hook on the needle threader. I have no problems threading needles in larger sizes.
Good luck,
SewReady
Oct 01, 2008 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
21 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
