Question about Dyson Ball DC24 Bagless Upright Vacuum
The on-off switch for the brush on my Dyson dc 24 vacume hangs up
Brush switch hangs up
    Genius:
  • Dyson Master
  • 1,204 Answers
A new switch is usually the easiest solution
Posted on Apr 23, 2014
geordie rob
  • 7 Answers
SOURCE: roller brush is not turning on a dyson DC14
http://www.dyson.co.uk/support/help.asp?product=DC07-SY&article=527
here's a link that might help
good luck
Posted on Dec 29, 2008
  • 389 Answers
SOURCE: Dyson DC 24 blockage between brush bar and
You can remove that short length of pipe very easily. Just pull it away from the fitting at the vacuum end and unscrew it from the brush bar end. While you've got it off, check it for splits (which are common) and replace it with a new one if it is damaged.
Posted on Jan 06, 2010
Testimonial: "Solved problem first time,also one we thought was a manufacturing fault,that side hose uremovable,were doing it wrong and this told us the right way."
Dysonteam
  • 167 Answers
SOURCE: the brush bar wont spin on my dyson dc 25... i
Hi its Darran at Dyson.
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Posted on Apr 22, 2010
SOURCE: Brush stopped spinning
If you've had the brush out to clean it you need to re-set the trip switch which is a red button at the right side of the brush simply press it in till it clicks.
Posted on Sep 08, 2010
  • 101 Answers
SOURCE: We have a Dyson ball
There is a known issue with the DC24 brushbar motors. First thing to do is try the reset button. That is located on the left of the brush bar unit as you look at the machine. It is red. Press it and see if the brush bar works when the machine is reclined then. If it doesn't, you most likely need a brushbar motor. You can get one from here: Dyson DC24 brushbar motor.
Posted on Nov 30, 2010
Dc dyson 24 free repair maule
About 1,100 results (0.84 seconds) Search Results
    Dyson DC24 - Resetting the brush bar (Official Dyson video ...
    ? 1:55
    https://www.youtube.com/watch?v=akGLQ7UbctY
    Sep 29, 2011 - Uploaded by AskDyson
    DC24's brush bar is engineered to shut off for protection if something jams i. ... How to clear and reset the brush bar of yourDyson DC24 upright vacuum cleaner ... Dyson DC24: How toRepair a Loose and Clunky Ball. ... Dyson Ball DC 25 not locking beater bar brush in place while upright - Duration: 17:09 ...
    How to fix your Dyson Vacuum Cleaner when it loses ...
    ? 7:45
    https://www.youtube.com/watch?v=0vd3ldLXgI4
    Apr 16, 2013 - Uploaded by Chuck Fresh
    How to clean the two filters in your Dyson Ball or Animal Vacuum... troubleshooting computer problems, pc helpline, free pc repair... How to take apart Dyson DC 17 to Clean and Service - Duration: 14:33. n4ktz 178,332 views ... Dyson DC24 - Resetting the brush bar (Official Dyson video) - Duration: 1:55.
    [PDF]Dyson DC24 Manualhttps://www.dyson.co.uk/.../Dyson/.../Manuals/DC24_Manual.pdfDysonNote your serial number for future reference. After registering for your 5 year guarantee, your Dyson vacuum cleaner will be covered for parts and labour for.Dyson DC24 Manual - ManualOwl.comhttps://www.manualowl.com/p/Dyson/DC24/Manual/112339Manuals and user guide free PDF downloads for Dyson DC24. ... I Have A Dyson Dc17, Is There A Fuse Or Reset Button On The Vacuum Motor ... Complete Dyson customer service phone numbers and contact information at ContactHelp.com.Dyson DC24 Multi Floor Instruction pack - Part 914529-01 ...https://www.dyson.com/parts/u/user.../dc24userguide.aspx?...DC2...DysonDyson DC24 Multi Floor: Instruction pack - 914529-01.Buy genuine parts and accessories direct from Dyson.DYSON DC24 USER MANUAL Pdf Download. - ManualsLibwww.manualslib.com > ... > Vacuum Cleaner > Ball DC24Page 2: General Safety Precautions. Do not use with damaged cable or plug. If the supply cable is damaged, it must be replaced by Dyson Ltd, our service agent ...
Jan 28, 2016 | Dyson Vacuums
How do I get the brush to spin on a Dyson DC 24. I have thoroughly cleaned everything and pressed the reset button.
Hi , if i am correct the brush bar is driven by a small electric motor inside the brush bar. It sounds as if the motor has gone or the small printed circuit board has a fault. You will have to get it checked.
Mar 05, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
Does anyone have "duct" assembly instructions for Dyson DC 24? (Not the owners assembly manual)
Google Dyson. co On the drop down window, find your model, type in Dyson DC 24, at bottom of page click on shopping info, click parts. you can order from there.
Oct 19, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
How do I change to different powers
Hi there, it's Jack at Dyson.
DC24's brush bar is powered by its own motor. This means the brush bar can be turned on for carpets and rugs, and off for hard floors or delicate rugs.
To turn off the brush bar, just press the silver brush control switch located next to the red on/off switch. Press it a second time to turn the brush bar back on.
I hope this helps, but if you'd like any further advice you're welcome to contact our experts directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 25, 2014 | Dyson DC24 All Floors Upright Cleaner...
Replace belt on DC 27 Dyson vacum cleaner
Upright /undo screws holding the rotating brush,and then
remove the brush and cleaner refit using new belt.
Jul 29, 2014 | Dyson DC27 Total Clean Vacuum Cleaner
Dyson dc 24 brush works intermittently
Broken wires in the side of the machine
Dec 27, 2013 | Dyson Vacuums
Jul 05, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Brush bar is not turning when I turn on my dison vacum
Hi There,
The Dyson DC15 All floors is actually a 2 motor upright, meaning the suction motor is separate from the motor that rotates the brushes. The first thing you should check is the reset switch on the brushes. Behind the brushes there is a little red pole, push this down to reset the brushes, and see if this fixes the problem.
If not, then you may have a bad on/off switch for the roller brushes. Try pushing the switch next to the main on/off switch that controls the brushes up and down, up and down, can you hear the brushes attempt to come on at all? If you could hear them come on even somewhat, this means that your brush on/off switch is bad and needs to be replaced.
If nothing happens when you push this switch, it still may be bad and not getting any power at all to it.
Does the machine make any sound at all when you try to turn the brush switch on and off?
Please try pushing the reset switch, then testing the on/off switch first. If neither one of these solutions works, please just use the comment field on the repair and let me know, and I can then walk you through some more advanced diagnosing of your machine.
Thanks,
Chris Jones
GoVacuum.com
Apr 28, 2010 | Dyson DC15 All Floors - The Ball Bagless...
The brush bar wont spin on my dyson dc 25... i
Kind regards
Darran
Jan 08, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
My dyson dc 24 just stop picking up. There is a
Check to see if the brushes on the bottom are turning if not change the vacuum belt.
Sep 13, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson Ball DC24 Bagless Upright Vacuum Logo
62 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
