Question about Hip Street TITAN Tablet
Unlock screen pattern
How can I reset a forgotten screen pattern
I have forgotten the pattern code for my asus tablet
there is usually a reset button somewhere on the unit, try that
Feb 04, 2015 | ASUS MeMO Pad HD 7 ME173X-A1-GN 16 GB...
How to unlock tablet that has a forgotten pattern on it
if you have a google account, you can do this option
  1. When you try different patterns and unable to unlock your phone in five attempts. Then a message pop-up and shows two buttons "next" and "try again".
  2. Now click on "next" button and you see two options for unlocking phone. One is answer the security question and the second option is to provide Google account details.
  3. Mostly people don't set a security question. But if you set it then simply answer the question and unlock your device quickly. Otherwise check the Google account option and click "next".
  4. Now provide your Google account username and password attached with your device and click on "sign in".
  5. After that you are directed to choose new pattern and now you can unlock with this pattern.
if you don't have your google account, you can do the recovery option, but you will lose all your data in there
  1. Power off your phone.
  2. Now press Volume up, power and home button at the same time and wait until your device starts.
  3. When you see logo screen release the power button and keep pressed the other two buttons.
  4. Now your screen shows android system recovery and there is a list. Use Volume up or down keys to select option from the list. And select factory reset option and then press power button to let the action begin.
  5. Now it asks you for confirmation, select "yes".
  6. After factory reset completes, it again shows you android system recovery screen. Now select reboot option and after restart it will not ask you for pattern.
Jan 20, 2015 | Coby Kyros MID7120-4G 4 GB Tablet - 7" -...
TOO MANY PATTERN ATTEMPTS ON SAMSUNG GALAXY GT-P7100
Pattern Lock- Incorrectly enter pattern 5 times (4 or more points each time) . Pop up message will appear Click Next and you will be prompted for google a/c details or security question for pattern lock.
tap forgotten pattern and on next screen enter google account details. Then next screen allows you to choose a new screen lock option.
Otherwise for a factory reset use recovery mode
The only other solution is a hard reset which is only as a last resort. You need to access Androids Recovery mode. Check your manual. Most devices it is power off then power up holding volume + and power buttons.
Once in this mode use power down button to highlight "wipedata/factory reset option, then use power button to select it.
Vol - button to to scroll and select yes delete all user data option with power button. When device reset select option to reboot now and the device will turn on unlocked but you will have lost your personal data.
Aug 07, 2014 | Samsung Galaxy Tab 101 Tablet...
AX109JC20130709
You do not say what type of password was set and if you have forgotten it or just want to reset from a known password..
If you just want to change your gmail login password
- Go to google.com/accounts on the tablet browser
- Sign in
- "Change Password"
- Go back to the Home Screen on the tablet
- Open the GMail app, clicked on Menu, then Refresh -- you will get a sync error
- Wait for a notification to re-enter your password (a triangle with an exclamation point in the tablet notificaiton bar and/or something in the gmail screen)
- Enter the new password
This simple solution sometimes works:
Turn it off.
Turn back on.
When you get the warning triangle in the notification bar, open the notification.
You will then get a login screen.
Input your new password.
Pattern Lock- Incorrectly enter pattern 5 times (4 or more points each time) . Pop up message will appear Click Next and you will be prompted for goole a/c details or security for pattern lock.
tap forgotten pattern and on next screen enter goole account details. Then next screen allows you to choose a new screen lock option.
Locked with PIN or password _Try Screenlock bypass pro from play store.
Face unlock - you were asked to provide a pattern or PIN backup when you set it. Just bypass and enter PIN or pattern.
Good Luck
Aug 06, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
FORGOTTEN UNLOCK PATTERN
It is quite normal that after providing an unlock pattern to your tablet or mobile, you forget the pattern and attempt unlocking the device multiple times. In this process, many times your device gets permanently locked, and you no longer get any access to it. If you have forgotten your recovery email, you will not be able to unlock the device using that option as well. More.. How Do Unlock My Tablet if Forgot the Unlock Pattern or Recovery Email
Apr 17, 2014 | Tablets & eReaders
How do you reset the password as we have forgotten it
If it's linked to your google account you should be able to reset it. Taken from user manual:
After five wrong entries, you can reset
your unlock pattern. Tap Forgotten
pattern? and enter your Google account
username and password.
Note: You must have an active
Google account on the tablet and
an Internet connection.
If this option is not available, please
contact your local Acer service
center.
Mar 15, 2014 | Acer Iconia B1-710
I had a pattern password on my Coby, and I havent used it in a long time. Now I need to use it but i forgot the the passcode! Please Help!!!!
You have to reset your tablet back to factory settings: If you have MID7015: Here is a step-by-step procedure on how-to perform a factory reset when the unlock pattern code has been forgotten:
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the MID7015******
Step 1- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Step 2- Click on "Power Off and select "OK" .
Step 3- Once the unit has been turned off. Press and hold the "reset" button and "power" button simultaneously for eight seconds.
Step 4- The following screen will appear. Press the "reset" button.
Step 5- The Android system recovery screen will appear.
Step 6- The "Home and Menu" button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". . Press the "reset" button.
Step 8- The following screen will appear. .
Step 9- Press the Menu" button to select "Yes- delete all user data".
Step 10- Press the "reset" button.
Step 11- The following screen will appear .
Step 12- Press the "reset" button to reboot/restart the unit.
Sep 01, 2011 | Coby Kyros 716829701508 Tablet PC
How to unlock it if you forget the password?
This is for MID7015
Jul 07, 2011 | Coby Kyros 716829701508 Tablet PC
Hip Street TITAN Tablet Logo
35 people viewed this question
Top Hip Street Tablets & eReaders Experts
Are you a Hip Street Tablet and eReader Expert? Answer questions, earn points and help others
