Question about Brother Sewing Machines
Filling Bobbin!!!!!!!!! I have a C55055PRW Project Runway model. I am new to sewing, and have spent days trying to figure out how to fill a bobbin. I can follow the directions up to the point of threading the machine to get ready to fill a bobbin, but when I begin filling the bobbin, I end up with a bobbin full of loops and loose looking thread. I am making sure that I push the bobbin to the right so it is against that little round thing, but nothing seems to work for me. I have wasted a spool of 250 yards of thread and am no closer to getting this figured out. BTW, I have looked at the manual, and I seem to be doing it right. But I guess I'm not. Does anyone know what I might be doing wrong?
  • Brother Master
  • 7,365 Answers
Try youtube for a video, there are several to look at and maybe one will help you
Posted on May 07, 2014
2 Suggested Answers
SOURCE: I have a brand new Brother CS-6000i. The first
since it's brand new, if it's still under warrenty, take it back & get another one
Posted on Nov 02, 2010
Im looking for a Power Cord for a brother limited edition project runway LS2300PRW. also looking for the bobbin for this particular item as well
You can search the internet for both of these items. Input the make & model plus the description of the part you are seeking.
Nov 01, 2016 | Brother Sewing Machine Project Runway...
Every time I use this machine something else is wrong with it :-(. Now the bobbin thread us bubbling up in the back of the material and there is a grinding sound as the needle hesitates to move. What
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Nov 09, 2014 | Williams Brother PC-420 PRW Limited...
Singer 7258 bobbin filling issues
If it is new, it is defective, return it for service or replacement.
Mar 23, 2014 | Singer 7462 Mechanical Sewing Machine
Messy looking bobbin not filling properly
There are a couple of things that could be causing this that you can check. First, when taking the thread from the spool and wrapping it around the little metal button on the top of the machine, you need to make sure the thread is pulled up under the button (I always compare it to dental floss)- this will ensure the thread is held at the proper tension.
Next, how are you threading the bobbin itself? The thread should pass between the two disks and out through the hole at the top. Make sure you leave a tail of about 3-4 inches to hold on to.
Last, when you put the bobbin onto the spindle on top of the machine, you need to twist the bobbin until you hear it click into place. If you look at the spindle there is a little piece of metal that looks kindof like a paperclip- this piece needs to align with the little notch on the inner hole of your bobbin.
Once ce you are ready and have checked all these things, hold the tail of thread coming out of the bobbin straight up in the air while you press the pedal and begin to wind. Once you've wound a decent amount of thread on the bobbin you can snip the tail and continue winding.
i hope this helps you!
Mar 22, 2014 | Brother Sewing Machines
White sewing machine model 1805 can't get it to sew the wheel turns and belt is ok . It is like the wheel is frozen Do you change it after filling a bobbin?
If I recall correctly, to fill a bobbin you must first release the belt from the wheel by loosening the knob on the small machine wheel. Then after the bobbin is filled you need to tighten that knob again. Do you have the manual?
May 27, 2013 | Sewing Machines
Bobbin is very loose when sewing
try adjusting the top thread tension to one number or letter higher
until the stitch look better
change the needle
Aug 28, 2012 | Brother CE8080PRW Limited Edition Project...
Filling a bobbin
Look though these threading and bobbin winding guides for a machine that closely resembles the one you are using - http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Apr 21, 2010 | Riccar R651 Mechanical Sewing Machine
Bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Aug 17, 2008 | Sewing Machines
Sewing Machines Logo
65 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
