Question about Sony Playstation 3 (PS3) Console
Ifit live I can't get my PS3 to allow me to sign into ifit live to watch my workout. I fill in the sign in I for, but when I click login it won't execute the page
Ifit wifi security issues
http://www.youtube.com/watch?v=k9zxICKIe7E
Dec 21, 2013 | Zyxel Computers & Internet
Tip
How to configure your treadmill with an iFit Live WIFI Module
First, when you receive the package you will take out a little credit card that has a promotional code to give you one free year. Go to ifit.com and select "register now" on the top right. Put that activation code into the website. It will then ask you to create a username and password along with asking for fitness information to help you create a workout program. After this is complete select the "support" button on the top of the website and select the option "set up your ifit live wireles module". This will take you to a screen with instructions to configure. Select the option "install now" or "launch now" which will be located underneath a big blue ifit live logo. It will download on to your computer the program as well as an application called Adobe AIR, which is used to run the setup program. It will then ask you for your newly created username and password. Click log in then it will update firmware files from ifit.com. After this it will prompt you to select your wireless network. Push the button that says change settings. This will bring up wireless networks in your surrounding area. Push the select button next to the wireless network you use in your home. If your internet requires a password you will then be prompted to select the encryption type and type the password. After you have typed the password and pushed continue it will test the wireless connection. After it says "setup complete" take the module out of the computer. Unplug the machine and put the module in. Turn the machine on and remove the safety key if treadmill or let it fall to sleep if it is an elliptical or a bike. After around two hours it will be done updating and you can download your first workout.
on Aug 18, 2010 | Exercise & Fitness
Tip
How to use iFit Live with built in WIFI.
If you have a workout machine that is supported by iFit Live technology and does not require a wireless module then there are a few steps to configure it. First, make sure you are connected to the internet. To do this tap on the little "i" in the bottom right hand corner of the touchscreen and then tap wireless network. Next to your home wireless network tap "connect", then done. After you are connected we need to check the version of the firmware. to do this click on the picture of the gears on the bottom right hand of the screen. You will see a version number on the top left. The current version is 5.12 but may be advanced by the time you read this. tap the update firmware button. This will take about five minutes and will then prompt you to cycle the power on your machine. After the power is cycled and the machine is back on tap "iFit Live Workouts". Then tap "Live Workouts". It will ask you to login using the information provided when you registered. After you login there will be a big green start button. Tap that and your machine will be registered online and it will pull off of the internet a demo workout. Finally, go online to ifit.com and log in with the same information as above and download the workouts and programs you desire.
on May 24, 2010 | Exercise & Fitness
Need an owners manual for ifit wifi
go to www. ifit.com or www. nordicktrack.com and download for free.
or www.iconservice.com
God bless you
Jul 03, 2012 | Nordic Track iFIT Performance Treadmill...
Ifit wifi module
go to www.ifit.com or www.nordicktrack.com and get support ONLINE via chat.
God bless you
Ifit light flashes. Everything works properly except light flashes, which is distracting and irritating.
o 1 Check the connection cablebetween the Pro-Form device and the home stereo, computer, television or VCR ifthe iFit program is not working. Ensure that both the Pro-Form device and thestereo device are both turned on in order to function properly.o 2 Connect the Pro-Form deviceto the computer prior to logging onto the website iFit.com if the iFit programsare not downloading or operating on the computer. The fitness device mustremain plugged into the computer at all times in order to use the iFit programsduring the workout.o 3 Insert the console key andpress the "Program Select" button repeatedly if the iFit program isnot working properly. Ensure that the fitness device is connected to thedesired output device, such as the computer, television, VCR or MP3 player. TheiFit indicator should be lit on the console display.o 4 Press the "Start"button on the console if the time display is flashing on the Pro-Form device console.The iFit program will not function while the time display is flashing.o 5 Listen for a chirping soundif the incline or speed changes suddenly on the fitness device. The chirpingsound indicates that a speed or incline change is about to take place, even ifthe iFit program has not announced the change.
Nov 09, 2011 | Exercise & Fitness
C2155 treadmill 1 1/2 yrs old, Nordic track. Panel lights up when the key is attached, beeps a triple beep sound fast about every 15 seconds? Keeps beeping when any of the buttons are pushed and won't...
I had the same problem with my Nordic track. I pressed every button until I found the one that did not beep. The one that does not beep is stuck. My problem was with the Ifit button. The first few times I would push the bad button until it started beeping. That worked for awhile (couple of weeks but started up again). I disconnected the Ifit unit and now the thing work fine except for Ifit which I never used. Nordic track wanted to sell me a new console which cost more than the machine.
Jun 28, 2010 | Nordic Track NordicTrack Treadmill, A2550
Will my ifit treadmill card work in an incline
Technically, the Incline Trainer and the treadmill are two different type of machines. The incline trainer raises much higher so the card that is designed for the treadmill will not work on the incline trainer unfortunately.
Nov 29, 2009 | Proform Quick Burn Pro Treadmill with 12...
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
