Question about Garmin StreetPilot c340 GPS Receiver
The cable broke so I can't recharge my C340 unit. Can I buy a replacement cable?
You can get a new cable at amazon.com or you can charge your unit on your computor
Posted on Aug 16, 2012
Yes either at Garmin or at some stores like Wal-mart or Radio shack!
Posted on Jun 16, 2009
Where you plug in to charge is broke
Hi.
If you broke the lighter socket on car dash, replace it.
If you broke the cable replace the cable. Here the spare:Garmin Power Cables
If you instead damaged the power socket on your Garmin, call the Garmin number listed in the owners manual. The Sat Nav must be sent to Garmin for repair:Garmin ' Contact
Next time use a Suction Mount Windscreen Holder
Regards.
Ginko
Dec 15, 2011 | Garmin StreetPilot c340 GPS Receiver
We have a kodak easy share cameraC340. We use regu;ar alkaline batteries. After taking a very few pictures the batteries quit working. this has been a problem for a long while
Yeah ,your just need a little money to buy rechargeable li-ion batteries for your cameras ,why make the old batteries not charging enough power affect your shotting,fun can come back after you giving your EasyShare C340 camera a new replacement battery pack.
Feb 10, 2011 | Kodak EasyShare C340 Digital Camera
My Garmin c340 has won't turn on, screen is completly dark unit is charged
I has the same problem with a streetpilot 540.. It wouldn't turn on, even once charged. There was no reset button under the serial number. However, prise off the grey plastic square plate on the front panel which goes around the screen. ( there's even a little space for your fingernail under the Garmin logo). The reset button is under that plate. Press that with a screwdriver then turn on. My unit turned on once reset.
Aug 10, 2009 | Garmin StreetPilot c340 GPS Receiver
C340 updates
The cable can be found here:
https://buy.garmin.com/shop/shop.do?pID=290
It is the usb cable found close to the bottom of the page you will need to purchase it unless you can find the original box that it came in and the cables may still be in there.
The software updates can be found here:
https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00401-20&cID=164&pID=290
You will most likely have to download it to your computer and then transfer the files to your unit after you have connected it to you computer via the usb cable. if you have a digital camera or a playstation portable or some other such device the cable that came with one of those devices may fit the Garmin. if not you will have to order one via the above link and wait untill it arrives.
Oct 04, 2008 | Garmin StreetPilot c340 GPS Receiver
GARMIN C340 VOLUME CONTROL
I had the same issue. My C340 fell of the dash and the volume control (potentiometer) broke off and was rattling inside the case. I tried to find a replacement (103B stamped on the pot) but have not been able to find one. I tried a mini 10K ohm pot from Radio Shack, but the posts were not properly positioned for the circuit board inside the Garmin.
I took the easy way (for now) and simply strapped the two control points together with a piece of wire giving me maximum volume. Orient the circuit board with the missing volume control to at the bottom right. The control mounts with 5 points, two on the right edge of the board are simply physical mounts. There are three other connection points just to the left in a slight arc. The top and bottom point have holes to place the legs of the pot. The broken off legs may still be in these holes. Solder a piece of wire between the top and bottom points. Be careful since the solder pads (to the left of the holes are very delicate.
Not an elegant filx, but you get the voice back.
Jim H
Sep 03, 2008 | Garmin StreetPilot c340 GPS Receiver
My Garmin C340 is dead!!!!
I had the same problem on a trip. Required two fixes and once I did this the unit worked fine.
1. Replace the fuse in the car adapter (reason it wasn't charging when I used it in the car).
2. See the users manual on page 31 regarding resetting your C340.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Jul 21, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin C340 GPS - Will Not Power On
Thanks. This helped me fix the problem.
Apr 02, 2008 | Garmin StreetPilot c340 GPS Receiver
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 FROZE? Here is how to fix it!
My garmin shuts down immediatly when I switch it on. Dont know if there is an internal battery that needs to be replaced or some thing else.
Jan 26, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 gps freezes up
Avoid buying Garmin GPS. Their units have a non user replaceable battery that last about 2 years. After that, you have to send the unit to Garmin to replace the battery and be hit with at least $150 plus shipping. Possibly more if they need to fine tune something else. Look at other brands with easier battery replacement such as Sony, Navigon, etc. Garmin is a total rip off.
Sep 08, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
52 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
