Question about Hoover Dryers
Noise when starting no spin then starts after manual spin
Cutting out
Piaggio fly 125 tries to start but then makes a constant noise like a car revving.
Hi, Mark the starter drive/Bendix is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed it is not serviceable and needs to be replaced. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have nice a day. Piaggio fly 125 starter drive Google Search
Quality Replacement Parts For Piaggio
Download PDF Vespa Piaggio fly 125 150 workshop manual
Jan 08, 2016 | 2008 Piaggio Fly 125
Dryer hums but will not start
bad motor,if it does start and runs then shuts down and you can't restart it until it cools down you have a bad motor,or open the door and see if you can spin the drum,i found a dryer that the belt cut through the pastic belt pulley and the motor couldn't turn,also something could be stuck inthe blower wheel but if you can spin the drum then it's the motor.the noise you heard is either a bad roller,the belt pulley or the motor bearing.next time send the model number and i can look up you dryer to see what parts are in it.hope this helps.
Dec 29, 2013 | Maytag Dryers
Dryer drum needs several manual pushes to start
or just a bad belt cheap but labor intensive
http://www.youtube.com/watch?v=7OVBi0LcrzQ
Apr 29, 2013 | LG DLE2532W Electric Dryer
Spins slow, does not drain and leaks a little.
SOUNDS LIKE MIGHT BE SEAL LEAKING WILL NEED TO DO BEIRINGS AND SEALS
Jun 17, 2012 | Maytag LAT2300 Top Load Washer
How do I reduce my clipper's rattling noise and still be able to cut properly?
The power screw is the correct way to adjust the problem you describe. If you have attempted to adjust it as instructed in the user manual and have not had satisfactory results, there may be a problem with the clippers.
Most Wahl clippers have a 1 year or longer warranty. You can call Wahl for warranty service at 1-800-334-4627
Nov 12, 2011 | Health & Beauty
Cricut makes loud grinding noise and will not turn roller bar
My wifes' cricut seems to have had the same problem. Try turning off the power, then manually slide the cutting carriage to the left look inside to the right. you should see a red button pull on it until it clicks. power up the cricut and see it it works. it solved the problem for my wife.
Jan 02, 2010 | Provo Craft Toys
Riding mower won't start
Check the starter. Sound like the gear on the starter is stuck or broken off and not engaging flywheel.. Just your starter is spinning
Jun 16, 2009 | Mtd Garden
GE Profile Dryer will Not Spin
I opened the dryer panel and saw that one of the two belts that stabilize the drum had come off. It is a soft, sticky, rubbery substance and part of it and balled up so it was wedged between the drum and the dryer wall. I cut that portion off and it runs fine now.
Dec 07, 2008 | GE Profile Harmony DPGT750EC Electric...
The washing unit makes a high pitched loud noise
Check to see if you have a bra underwire or nail stuck in the spin tub. Look around inside the tub looking for something stuck in one of the holes. Dont use the machine until you find the problem or you cut the tub in half with like a nail or screw and then the machine has to be rebuilt $$$$
You may have other problems, However start here. Let me know if you have other questions
May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
Dryers Logo
14 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
