Question about Quartet gbc 5220S Shredder
Shredmaster 5220S on off switch doesn't work, paower is there but nothing happens
What gallon bags does shredmaster 1256S use?
GBC Shredmaster Personal Shredder Bags Staples i use the plastic bags you get when grocery shopping they don't look pretty but they work for me
Jan 08, 2015 | Shredder Office Equipment & Supplies
Frigidaire galaxy series makes ice but won't dispense
If nothing at all happens then check the micro switch on the lever/button section. This will probably require taking the dispenser section off. If nothing at all is happening its as though it doesn't register the dispense, if the switch worked then at least something would happen ie the flap, the drive motor etc
Jul 08, 2013 | Refrigerators
Cruise control not working
The adjustment of the brake light switch or it could be bad. the brake lights can work fine and the part of the switch that works the cruise doesn't The swiches that control it from the steering wheel can losse connection in a part called the clock spring. Vacume connections can effect the cruise but yours is likly cables less therefore doesn't work the cruize.
Oct 09, 2012 | 2005 Chevrolet Equinox
Coffee maker turns on but will not brew
why question to all of this is with a "self clean" button, why doesn't it every tell you to clean it..... ??
Sep 07, 2012 | Cuisinart DCC-1200 Coffee Maker
My kenmore front load washer doesn't want to start all lights are working but nothing happens even the door won't lock
your door switch is the problem,where the door latch goes into the machine a little switch sites behind this a safety feature and if this is broke the machine will still switch on but will not work it will need replaced they are cheap.adrianxxx
Jun 02, 2012 | Kenmore 44072 Front Load Washer
I'm having a problem with my Quartet gbc 5220S Shredder.What it is doing I have all of the doors shut and everything is in place and it is saying that the door is open. What could be the problem going on?
Check that a piece of paper is not causing any safety switch to be kept open.
make sure lid is fitting correctly.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Quartet gbc 5220S Shredder
GBD Shredmaster Model 2260X about one year old...door close switch was intermittent and now does not show "closed" at all even when the switch is deflected. Is the problem likely to be in the switch or on...
If blowing some canned air into the switch doesn't cure the problem, the switch will have to be replaced.
Try Radio Shack or an electronic supply store.
Also, check the door alignment screws.
Sep 28, 2009 | Quartet gbc ShredMaster 2260X Cross-Cut...
How to fix a stuck shredder
get a pair of needle nose pliers and pull the jammed paper out. (you may need to figure out how to pop off the top cover to get better access to the blades)
May 27, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
Syncmaster paower button blinking and no display
CHECK THE REFRESH RATE ON TH OLD COMPUTER MONITOR AND MOVE IT TO A HIGHER REFRASH RATE IN THE CONTROL PANAL, MONITOR, PROPERTIES, ADVANCE SETTINGS
ROD
Feb 10, 2009 | Soyo DYLM1986 Monitor
Quartet gbc 5220S Shredder Logo
51 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Pie-man
Level 1 Expert
graybeard32301
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
