Question about Kenmore Select Seal-N-Save
Manual for kenmore ultra seal-n-save model 69043
Seals need replacing
2 Suggested Answers
  • 45253 Answers
SOURCE: Door seal for kenmore freezer model 29205
Water Filters Lawn Garden Appliance Parts
Posted on Sep 19, 2015
INSTRUCTIONS on Using Vaseline and hairdryer heat to help create a better seal on Kenmore upright manual defrost Freezer gasket??
cleaning the gasket first is a must . warm soapy water .then check the seal gasket with a magnet .before greasing it with vaseline,unless this unit is OLDer than I am it is a magnetic seal but they do split and need replacing .
Oct 17, 2015 | Kenmore Freezers
Kenmore upright freezer
order a new seal at the link I provided or ebay or your choice
also check the lid or door adjustmens and obtain specific help instructions at the link I provided
Appliance Repair Help Troubleshooting and Appliance Parts
Apr 08, 2017 | Kenmore Freezers
Condensation forms around the freezer opening, between the rim and the seal.
The lid is warped or the seal is bad and leaking air.
Determine which it is and replace the seal or the lid.
Jun 27, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
Freezer ok refrigerator not cold we changed the overload relay model no. 59673503201 kenmore elite
feel door seal after door has been kept closed for a quite a time.If it feels warm at any one spot door seal needs replaced.adrian;;;;
Nov 10, 2009 | Kenmore Freezers
I have a kenmore upright freezer model #253.9266411 there is a gap in the upper left side does anyone know how to adjust the door? The seal is fine
I'm assuming you don't want to replace the door seal. Open the freezer door. Stand "inside" the open door and place your foot at the right bottom corner (looking from the inside). Place your hand in the top right corner and pull it very slightly toward you. Do this in small amounts until the gap closes making sure you don't open one at the bottom.
An alternate method is to warm the gapped section of the door seal with a hair dryer to soften the rubber enough to allow the magnet within the rubber to pull the seal gap closed. This has worked for me numerous times by making small adjustments at a time. Good Luck
Sep 02, 2009 | Kenmore Freezers
Kenmore commercial upright freezer not sealing well - thawing
If the door seal does not seal completely, replace it. This is very important for freezers.
Contact Rick at Restaurant Parts and More.
\1-888-814-1110. He can most likely get what you need. Just have model and serial numbers and he'll do the rest.
Home Depot and Lowes is a definite no.
Apr 04, 2009 | True 23 cu. ft. / 651 liter Commercial...
Kenmore upright freezer not cold enough to freeze
Sounds like a door seal that isn't sealing all the way around. That would be my first replacement. Is the unit level back to front and side to side? Is it really full of food?
Call your local appliance parts house and get a magnetic door seal first. They aren't that expensive. But make sure you do not have the freezer overloaded, which could account for the lack of that vacuum sound.
Finally, is self defost? Even if it is, a lot of times the vent on the bottom in the back gets packed with ice. If it is, remove the food and use a hairdryer, being carefull to unplug the freezer first. Melt all that ice and empty your overflow tray at the bottom underneath.
Mar 07, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Which setting on an Energy Miser saves energy?
OFF is the Energy Saver mode.
To reduce moisture, there is a heater around the door seal that stays turned on, using energy. If you switch to ON, you use more energy.
It is confusing though.
Jan 17, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore freezer
if the gasket isn't torn and the gap isn't caused by a door hinge problem you might try putting some vaseline on the door seal. If that doesn't help you may have to replace the seal.
Dec 30, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore Select Seal-N-Save Logo
380 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
