Question about GRACO INC GH 833 Airless Paint Sprayer
Will not prime, have checked the suction hose for air leaks and blockages, also checked the bottom check ball to see if it was free
New, never used before Dyson DC40 has no suction on the bottom, but has good suction through the hose. I have checked for blockages like it was suggested here on the website and the way it was explained in...
On this model dyson there is a flapper valve that opens when the handle release is engaged. It switches the air flow from the hose to the floor nozzle. They break there all the time, and you have to take it to a dyson repair shop.
Jun 25, 2014 | Dyson Dc 41 Ball
Vax c90 p 2 b 200wI have cleaned filters but hoover/suction keeps cutting in and out?Can you help ?
check for a partial blockage in the wand/ hose ( rag-ball--hair ball ) Check that the hose is not collapsing at past kinks.
Jun 11, 2013 | Vacuums
Done every thing suggested. Still doenst prime. should I fill sand filter?
No prime = either impeller problem, air leak, or blockage on output(bad filter or bad valve) My first choice is dirty filter. Second choice is impeller. Both easy to check.
If you have checked those than you probably have an air leak. Hold a very slow running hose over all pipe joints running into filter, while motor is running. Most likely place is the screw in fitting on front of pump. The water from hose will temporarily seal leak and it should prime.
May 29, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Hi my pump won't prime or pump every thing is free and spining but won't pump
4 possible problems: 1. Was the pump filled with water first. 2. Make very sure that there are no air leaks on the suction hose and connectors. 3. Try less vertical lift on the suction side. It can be increased when primed. 4. Check for blockages or damage to the impeller.
Nov 17, 2010 | Briggs and Stratton 073001 2" Portable Gas...
Dyson Animal, purple ball, no suction upright
you might be missing a blockage in the hose from the brushes to the dust collector Take apart the hoses and check
Jul 28, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Our Dirt Devil D2 bottom has no suction
I would check the bottom of the unit to see if there is any blockage. I don't know if this unit has a switch that you set to switch from hose to floor. If so I would set it to floor and see if there is any suction in the hose, indicating a switching problem. If there is no suction in the hose, I would still check the bottom of the unit and disassemble it as much as you feel comfortable to see if you can see any blockage. Good luck!
Mar 13, 2010 | Dirt Devil Reaction Twin Cyclone Upright...
Dyson hose looses suction
You have a blockage in the wand. Stand behind the machine and:
1) Remove the u-bend which is located NEXT to the right-hand side wheel, NOT above it. It connects from the bottom of the long gray hose to next to the right-hand side wheel. It is attached to the machine with a rectangular-shaped clip - push the clip and pull the pipe down.
2) Look through the wand if you can (DC07 wand is bent) - if you can't see the ground you have a blockage in either the hose or the wand
3) Remove the hose and separate it from the wand - hold the wand up into the air and look through it - if you can't see light coming through the other end, there is a blockage in the wand. Use a long object like a stick or a metal hanger to remove the blockage.
4) If the wand is clear, stretch the hose out and look for dark spots - those are the blockages. Again use a long object to remove the blockage - be careful not to damage the hose, you don't want to buy a new one.
Jun 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
It has lost most of its suction power...what to do?
clean all the filters if this doesn't help then check for blockages at head, hose and entrance to collection chamber
May 30, 2009 | Vacuums
Nothing inn the canister after using,suctione working,bottom roller working,no air leaks from hoses.Also when running awhile it shuts off by itself,have to wait awhile to use again
I'm not sure what vacuum you have, but that sounds like a blockage to me. Thermal shut off kicks in, shutting the motor down, to prevent damage from overheating. After waiting like 1 hour it probably comes back on. Make sure hose, filters, bag (if any) is clean. All "airways" of vacuums need to be clear of any blockages, since airflow is what makes vacuums work.
Apr 18, 2009 | Vacuums
GRACO INC GH 833 Airless Paint Sprayer Logo
Top GRACO INC Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a GRACO INC Air Tool and Compressor Expert? Answer questions, earn points and help others
