Question about Nautilus NT 1230 Hack Squat-Leg Press
What is the weight limit the NT 1230 can handle?
How much weight can be used on the NT 1230?
Owners manual what is the weight limit
There is no maximum passenger weight capacity listed in the owners manual for my Boulevard S-50, and no maximum passenger weight capacity for the Marauder 800 (which is almost exactly the same bike) listed anywhere that I can find on the internet. The front and rear springs are adjustable for passenger weight, but I would suggest the maximum weight is limited by the rear tire capacity stamped on the sidewall and what weight you feel comfortable handling. Don't forget to include the weight of the motorcycle (about 456 pounds) and the weight of the gasoline (about 6.0 pounds per gallon).
Sep 08, 2014 | 2004 Suzuki Marauder 800
How much combined weight is allowed on the 1999 800 suzuki maurder
As I answered to the same question posted by G. Moore:
"There is no maximum passenger weight capacity listed in the owners manual for my Boulevard S-50, and no maximum passenger weight capacity for the Marauder 800 (which is almost exactly the same bike) listed anywhere that I can find on the internet. The front and rear springs are adjustable for passenger weight, but I would suggest the maximum weight is limited by the rear tire capacity stamped on the sidewall and what weight you feel comfortable handling. Don't forget to include the weight of the motorcycle (about 456 pounds) and the weight of the gasoline (about 6.0 pounds per gallon)."
How much weight can an electric massage chair handle? I am overweight and want to buy a massage chair; however I would hate to spend the money and in the end damage the chair or void the warranty.
Each manufacturer has their own weight limit published, so I advise asking in advance. From my research, it seems that most chairs can hold up to 270lbs; although there are some models that have a higher capacity.
Aug 06, 2012 | Furniture
What is the weight limit on a treadmill
hi good day..When you run on a treadmill the impact is 2 1/2 times your body weight. The impact from walking is considerably less. Therefore individuals who weigh in over 200 lbs need to consider a treadmill that can withstand the additional impact. Most treadmill manufacturers overstate their weight limit by as much as 50-75 lbs.
Treadmills for Users Over 250 Pounds: If you are in the 250 lbs range you better find a model that claims to at least handle a 300 lbs user. Look for models that have a deck that is around and 1-inch thick. A ½-inch deck may break from users that are hefty..
Apr 19, 2011 | Health & Beauty
What is the maximum weight load?
There is no real correct "max" weight. The bikes suspension travel will produce limits in handling and top speed as the weight increases, It should be able to carry to 2 adults with ease, say 180kg, If you are carrying big loads, then additional tyre pressure would be advisable. Upgrades in rear spring rates would be advisable also if you intend to do touring with heavy loads. You can get a full service manual here for the correct pressures to run and suspension adjustments you can make for high loads. Cheers
regards robotek
Jan 17, 2010 | 1994 Honda VT 600 C Shadow
I'm trying to find an instruction manual for the Peg Perego Velenzia. Would like to know weight limit and different functions
The weight limit is 45lbs,and the handle is reversible,it lays flat,fits a carseat,bassinet,and there is a step for a older kid to step on in the back,you can also go to www.pegperego.com to see it.
Jul 13, 2009 | Baby Gear
Height adjustment not adjusting
The height adjustment wont engage unless the handle is in the down position. Not knowing this led me to overturn the hight adjustment knob.
Step on the handle release, pull the handle back and lay the vac on its side. Then you can get the knob and the plate back together again.
BTW, the reason I had this problem is because the front brush slows dramatically when using on carpet, I thought it was set too low, and turned the knob (in a manly fashion, putting it past its limit). Still working on that one. After inspecting the belt, looks like one worn and cracked spot gumming up the works.
Jun 21, 2009 | Bissell 3920 Bagless Upright Vacuum
Nautilus NT 1230 Hack Squat-Leg Press Logo
82 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
