Question about Refrigerators
I have a Crystal Cold 18 cu/ft propane refrigerator/freezer. I've had this unit for 7 years now and I clean the burner and the flue on regular intervals. After this last cleaning the unit would not stay cold and I turned the thermostat to the coldest setting with the same result. I clean the unit again with the same result.It has a good light blue flame. What could be the problem?
    Genius:
  • 1,689 Answers
Hi mmpdk
thanks for using fixya.
this has go to be the thermal fuse or the capacitor for the thermostat assembly. These part control whether the unit gets cold or not and sustain the chose temperature.
the parts mentioned abive is usually located in the background near the thermostat controller or the power supply, near the heater assembly away from the blue flame.
these part replacements can be done through DIY, but best if you bring it to a service center.
hope this helps.
regards,
voodoo
Posted on Jun 14, 2009
I have a new Crystal Cold 18 Cu. It keeps shutting down. How long should it be at maximum before I turn it to a medium cold ? I have a 1 inch exhaust linked to the chimney venting outside.Pierre
It has to be absolutely level to prevent damage. Place the level in the freezer compartment and adjust the leveler feet to get it level. Once that is done, put a thermometer in the freezer and watch how long it takes to freeze ice. Now about that vent . How long is the pipe? If it is too long, it won't vent properly and the hi heat sensor in the flame compartment will shut it down for safety.
Aug 11, 2016 | Crystal Cold Stainless Steel Propane...
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Which direction do i turn the temp knob to make it colder? i have no numbers on the unit to go by.
I'm taking a stab at this. But almost every product i have seen, cold is to the left when turning a dial or knob. when it comes to water lines; Hot is almost always left. Hope that helps.Good luck
Jun 21, 2015 | Crystal Cold Propane Refrigerator/Freezer...
I have a Crystal Cold propane refrigerator and
You more then likely need a new thermostat. b0560f71-786e-45e7-a413-9112b90c0a0f.jpg
Sep 14, 2013 | Dometic RM2452 Refrigerator
Fridge does not get cold during propane gas function only. Upper Freezer section does. Whole unit does perform and freeze and cold function fine with electric and generator function. Why only during...
According to the manual the following is the most likely items to cause that failure. But since it is only in the frigerator section and not the freezer section it could be the lower circuit board.
LP Gas
Orifice
Flue Baffle
Flue Tube
Burner
Lower Circuit Board
Sep 10, 2011 | Dometic RM2652 Refrigerator
I have a GE refrigerator/freezer side by side. The freezer temp stays at 0 <which is fine>. The refrigerator will not go above 29. The acceptable temp is recommended at 37. I have shut off and...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jun 30, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
My refrigerator isn't staying cold nor is the
Look and see if coils need cleaning below. Do a good clean. Feel the compressor, if it's hot to the touch or cold it may have a bad relay. A relay can fail to drop circuits (causing the compressor to overheat) and open (causing the compressor to be idle).themobilian_2327.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 09, 2011 | Frigidaire Side by Side Refrigerator 23...
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    Warm refrigerator and freezer
    May be a bad defrost timer and the evaporater is froze up with ice. Clean dust buildup from the condenser under or behind the unit. Always give the model number
    May 03, 2010 | Amana 22.6 cu. ft. Side-By-Side...
    My propane fridge will not get cold
    You have described an Ammonia refrigerator. The chemicals in the system are Ammonia, water, and hydrogen. In a crazy system of events, heating the bottom of the unit will cause the chemicals to seperate and then reunite in a complete cycle.
    If you have never smelled a strong ammonia smell, then yes, the upside down thing will many times work.
    The chemicals can become seperated in the wrong areas of the interior components.
    Perform the upside down thing for 24 to 48 hours. Return to normal. Pause it for minimum of 4 yours and try again.
    If the burner is working correctly, then you should see some results.
    Oct 30, 2009 | Refrigerators
    Refrigerators Logo
    670 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Marvin
    Marvin
