Question about Aero Wings 2: AirStrike for Dreamcast
Aero wings 2 crack
In the aero wings 2.cdi is missing the exe fle
My Honda silver wing has got a fully charged battery but it won't start
Hi, Cieran and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2, TPS, ETP, IAC,or BAS).
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box if applicable.
17. Tilt sensor needs a reset.
18. Security system not disarming alarm needs a reset.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
My Wing Won Start
Engine Won Turn Over
2003 Silverwing won start
Honda FSC600D 2005 SILVER WING Owner Manual
Jul 05, 2016 | 2012 Honda Silver Wing ABS
2009 Honda Shadow Aero ran fine yesterday, stopped for about 3 hours would not start last night. Turned over would not start, help?
sounds like a CDI issue!
could also be an ignition switch or run/stop switch issue.
is the bike lacking any power when running?
Maybe stator pick-up coil as well.
Have electrical components checked at the dealer.
May 24, 2014 | 2004 Honda VT 750 Shadow Aero
E2700 cdi wing mirrors not foldng
probably just rusty try spraying releasing fluid in it move the mirror as the button is being pressed or the motor and gearing is going
Feb 06, 2014 | Mercedes-Benz Cars & Trucks
Yamaha 25 nmo
The power supply is common for all the coils.
Have you switched the coils (wires marked 1 and 2)? If still the same coil non sparking, replace that coil.
If the same output non sparking, check the pulser coil for that cylinder. Invert both pulser coil connections (white red and white black). If the miss is on the same cilinder, replace the cdi. If the miss is on the other cylinder: replace that pulser coil.
Jun 10, 2013 | Clymer Boating
1999 Honda VT 1100 C3 Shadow Aero engine not getting fuel
Hi, Mthornton2 you need to locate the fuel flow origin first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
2. Fuel cap or fuel tank not venting properly.
3. Fuel filter clogged with rust or dirt.
4. Fuel valve not in the on or reserve position.
5. Vacuum line to fuel valve cracked, broken, pinched, or missing.
6. Fuel valve/petcock clogged or diaphragm cracked, cut or torn.
7. Fuel line from the fuel valve to the carburetor or fuel pump clogged, cracked, pinched, bent, broken, or missing.
8. Fuel pump not working.
9. Fuel line touching cylinder or head causing fuel to boil and vapor lock, repair by rerouting and wrapping line with convoluted tubing.
10. Carburetor inlet clogged.
11. Carburetor float or needle and seat stuck.
12. Carburetor not venting properly overflow line or bowl fitting clogged, pinched, or bent.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Won start not getting fuel to carb
Way around the VT1100 Fuel Pump problem
Honda SHADOW VT1100 Owners Workshop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda Shadow VT1100 Owner Manual
Aug 16, 2012 | 1999 Honda VT 1100 C3 Shadow Aero
Overheating
According to my owners manual the following items should be checked.1coolant level 2 faulty temp gauge or gauge sensor 3 thermostat stuck in the closed position 4 faulty rad cap 5 blocked water passages in rad,hose,or engine 6 fan blades cracked or missing 7 faulty fan motor 8 improper ignition timing 9 improper spark plug heat range. I think I would start by replacing the thermostat after a good engine flush and replacing the coolant.Good Luck
Nov 25, 2010 | 1986 Honda GL 1200 Aspencade Gold Wing
Aero Wings 2: AirStrike for Dreamcast Logo
329 people viewed this question
Top Aero Video Game Consoles & Games Experts
James Wishart
Are you an Aero Video Game Console and Game Expert? Answer questions, earn points and help others
