Question about iPhone Apps
CAN I VIDEO A PROGRAMME on BT VISION
I Want to record a programme which is on bt vision is this possible?
SOURCE: remote control
the code for the bt.vision box remote to work a durabrand tv is under the emerson range the code i used was 004 it works fine
Posted on Oct 10, 2007
yalmer
  • 549 Answers
SOURCE: codes for tuning bt vision box to sanyo tv
 There are only 2 codes for Technosonic. 0037 and 0556. I hope these help.
Sympton Problem Solution
Rolling Screen?
Black & White. PAL Video is selected in error. Click on the TV SYS button located on the DVD remote near the Power button.
Light to Dark Picture. Connection to VCR or TV/VCR combo. Unplug the DVD player from your VCR and connect the DVD player direct to your TV (bypass the VCR). If TV does not have audio/video plugs, or if you have a TV/VCR combo, you will need to purchase and install an RF modulator (available at most electronic retailers).
The light to dark picture? Condition is caused by the disc manufacturer's license encoding at the time of manufacture. It is not cause by the DVD102 player.
No Video. TV needs to be switched to the correct input mode. Your TV must be switched to the correct video input selection. You can only switch the TV to accept an outside video source by using the original factory remote. Locate the button on the factory remote that switches the TV input. The most common descriptions on remotes are: GAME, TV/VIDEO, A/V, VIDEO, INPUT or SOURCE.
Universal Remote Code. The code has not been published. The Universal Remote manufactures create the codes.
Region Error. Software issue. Return the DVD player.
Unit Displays No Disc Even After a DVD has Been Loaded. Defective unit. Return the DVD player.
Unit Displays Loading Even After Giving Adequate Loading Time. Defective unit. Return the DVD player.
Here is what I was able to find.
If not let me know and I will try finding more info
Posted on Feb 14, 2008
  • 1694 Answers
SOURCE: bt vision remote
www.remotecodelist.com .....................................T.
Posted on Mar 22, 2008
scousegitt
  • 8 Answers
SOURCE: BT VISION BOX
Bt vision service addres is not a physical address like your house, it is the ip number of the bt server which allocates connectivity for your vision box. This number is kept under wraps as bt will NOT give it out over the telephone, they insist that an engineer must call to input this number if they cannot do it remotely. I think that this is to prevent unauthorised access to their servers. A load of Bull...t i hear you say, well i agree it is totally stupid that they wont give you this number. this address is asked for by your box when a diagnostic fault usually CO3 error occurs. People who think that this address is like a house address or an address of where the box is located do not know what they are on about.
Jonn
Posted on Jan 22, 2009
shawty-lozzy
  • 151 Answers
SOURCE: how do you connect bt vision to a sony bravia kdl
Sounds like you cant have set up the scart cables properly. Im unimpressed with BT for not setting it up for you, why didn't they?
Plus you will not need the freeview box if you have BT Vision, so i would take out the freeview box and just connect one end of the Scart lead into the back of the BT Vison box then put the other side of the lead to the Back of the TVs scart socket. Then all you need to do now if change the channel to AV1 OR AV2 or whatever channel you have.
Posted on Jul 23, 2009
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
Can I record programs from the BT vision box to my USB to watch on my PC
Usually it works the other way around: you download videos to your PC, copy/transfer them to a flash drive and then watch those videos from the flash drive on the big screen of your TV rather than on your PC's not-so-big screen. To do what you want, check if your BT Vision box has the capability to copy files from its internal hard drive to the USB flash drive.
Feb 02, 2015 | Televison & Video
Murphy TV maximum volume not loud enough when watching recorded programmes from BT vision plus.
Hi, does the BT vision Plus not have it own volume control as well ???
Regards
Rob
www.electronicrepairs.co
Feb 03, 2014 | Televison & Video
Bt com help btvision
contact bt vision its a free service you have to push some of the buttons in a particular sequence only they can tell you
Jan 14, 2014 | Computers & Internet
I have an e-motion tv and am unable to set my bt vision controler up as can't find a code
Same problem solved through patient "trial & error" ... for my e-motion TV, the BT Vision remote works with code "0081"
To program the BT Vision remote, instructions can be found at:
http://bt.custhelp.com/app/answers/detail/a_id/13573/~/programming-my-black-bt-vision-remote-control
Mar 06, 2012 | Televison & Video
How do you connect bt vision to a sony bravia kdl 37v4000.I have it working ok on freeview only but the bt vision appears on analogue channel 6 and the vision remote changes the tele channel not the vision...
Jul 23, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
Bt vision remote
Mar 20, 2008 | Televison & Video
iPhone Apps Logo
48 people viewed this question
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
