Question about Vehicle Parts & Accessories
Headlight assembly How do you install headlight assembly on 2010 ML350
  • 1,381 Answers
On the driver side you can do it by unbolting the washer bottle or unbolting the entire lamp from the front of the truck. Only 3 fasteners hold it on.
Looking at the front of the car there is a trim strip right under the headlamp. It unlocks with a small tab on the side closest to the grill. You can see the lock by opening the hood.
When the cover is off there is two bolts. Remove them.
On the top of the headlamp there is a long screw. Remove it.
Just beside that is one more clip that holds the lamp to the fender.
The entire lamp will simply pull forward out of the truck.
Unplug the harness and replace your bulb.
Posted on Jan 13, 2016
How to change low beam headlight bulb on 2010 ml350
With a lot of cursing, usually. Remove the rear cover from the headlamp assembly. Grab the socket attached to the bulb and turn counter clockwise about 1/8 of a turn. The bulb will then come out with the socket and can be replaced. Install in reverse order (remember the orientation of the bulb and socket and they will only go in one way).
Oct 20, 2014 | 2010 Mercedes-Benz ML 350
How to Remove headlight cover from volvo xc90
I have a C70 2010 Volvo convertible, and found that the entire headlight assembly removes by pulling the metal clip sticking up just behind the radiator by the headlight. Once you pull this up, you can pop the entire assembly out through the front. Makes it super easy to change bulbs.
May 05, 2014 | Vehicle Parts & Accessories
REPLACE HEADLIGHT 2008 SPRINTER
On some cases there are few hidden clips holding the assembly from under hood,that has to be released to remove headlight .
There are few troubleshooting help links showing how to replace car headlights,i suggest you to refer the links to solve these issue.
Click the link below:------
How to Replace a Headlight http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight.html
How to Replace a Headlight Bulb
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-bulb.html
How to Replace a Headlight Switch http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-switch.html
How to Replace a Headlight Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-assembly.html
How to Replace a Park Light Assembly http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-park-light-assembly.html
Low beam headlights Modification? http://schematicsdiagram.blogspot.in/2012/04/low-beam-headlights-modification.html
Headlight Assembly Removal On Honda Accord http://technoanswers.blogspot.in/2012/06/headlight-assembly-removal-on-honda.html --------------- Honda Headlight Assembly Removal
http://schematicsdiagram.blogspot.in/2012/06/honda-headlight-assembly-removal.html-----------
How to Replace a Headlight Door http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-door.html
All headlights not working? http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
How to replace HID headlight bulbs for lexus 400h? http://schematicsdiagram.blogspot.com/2012/01/how-to-replace-hid-headlight-bulbs-for.html
Working of Headlight switch?
Both headlight bulbs blow together?
Car headlight bulbs don't last long?
These will help.
Thanks.
Nov 23, 2012 | 2010 Mercedes-Benz Sprinter
How do I get to the front headlight to change it
Re: Replace headlight bulb
  1. INSTALLATION GUIDE:
  2. BMW E38 99-01 HID TYPE 7 Series 1PC Halo Amber Projector Headlights
  3. Parts Identification:
  4. Projector Headlight
  5. Halo & L.E.D.
  6. Bottom of the Headlight:
  7. Ballast Bracket, Halo Wires(red/black)
  8. Turn Signal Adaptor
  9. TOOLS REQUIRE
  10. 10mm - 8mm socket
  11. Philip Screwdriver
  12. Crimper/Pliers
  13. For more information about how to install your vehicle, come visit our youtube page on
  14. http://www.youtube.com/spyderauto
  15. Remove the facotry headlight from the BMW. First remove the front panel cover below the headlight to access the bottom screw of the headlight housing. There is also two screws on the top of the housing.
  16. Once you have remove the headlight, turn the headlight around and remove the bracket that holds the Ballast. Then remove the ballast using a philip screwdriver.
  17. Unplug the wire from the ballast, and then remove the Xenon Plug from the housing. Put the Ballast aside.
  18. Carefully remove the D2S Xenon Bulb from the factory housing. Once you have remove the bulb, transfer the bulb to the Spyder headlights.
  19. Remove the bracket from the Spyder Headlight, and then install the ballast on the housing like the original. Once you have put the ballast on, put the bracket back on.
  20. Remove the Panel Cover bracket from the original headlight to the new Spyder Headlights as shown here.
  21. STEP:
  22. Install the Spyder turn signal socket if the orignal does not fit, unplug the factory plug from the harness and plug the new one on.
  23. Install the Spyder Headlight back on to the vehicle. Plug the Harness back on, the halo/L.E.D. Wires is connect to the Parking lights. These wires are optional to your vehicle, you do not have to wire them together.
  24. Factory Xenon Headlight
  25. Spyder Projector Headlight using Factory Xenon Lights
  26. STEP:
BMW e46 HID Headlight Replace
Nov 22, 2012 | Cars & Trucks
Headlights wont work and dash and parking lights come when ignition switch is turned on. sometimes jiggling wires works. what is the problem?
Check out related help links with solutions to troubleshoot these problem.
Click the link below directly:---
Heater fan and headlights will not turn off with ignition off? http://technoanswers.blogspot.com/2012/01/heater-fan-and-headlights-will-not-turn.html
High beams stopped working but headlights still work?
http://howtobyme.blogspot.com/2011/11/highbeams-stopped-working-but.html
Only one head light works on 2001 Dodge Caravan? http://howtobyme.blogspot.com/2011/11/only-one-head-light-works-on-2001-dodge.html
Headlight Assembly Removal On Honda Accord http://technoanswers.blogspot.in/2012/06/headlight-assembly-removal-on-honda.html ------------- Honda Headlight Assembly Removal
Headlight wiring diagram for 1997 Lincoln Town Car?
http://technoanswers.blogspot.in/2012/02/headlight-wiring-diagram-for-1997.html
Dash Lights And Front Marker Lights Flashing On And Off http://schematicsdiagram.blogspot.com/2012/10/dash-lights-and-front-marker-lights.html
---------- 2001 Chevrolet Tracker: Headlights and Dash lights Pulsating? http://whoisbyme.blogspot.in/2012/06/2001-chevrolet-tracker-headlights-and.html
--------- No parking lights and headlights not turning OFF? http://technoanswers.blogspot.com/2012/01/no-parking-lights-and-headlights-not.html
------------- How to replace HID headlight bulbs for lexus 400h? http://schematicsdiagram.blogspot.com/2012/01/how-to-replace-hid-headlight-bulbs-for.html
--------- Head Lights Comes ON by Itself? http://whoisbyme.blogspot.in/2012/07/head-lights-comes-on-by-itself.html
--------- Only high beams work but head lights not working on Ford F350?
http://howtobyme.blogspot.com/2011/11/only-high-beams-work-but-head-lights.html
Only high beams working on GMC Savana?---------
How to replace Headlight Bulbs on Lincoln Town Car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-headlight-bulbs-on.html
How to change headlight?
http://repairhelpcenter.blogspot.com/2011/12/how-to-change-headlight.html
Both headlights and turn signals not working? http://schematicsdiagram.blogspot.com/2011/12/both-headlights-and-turnsignals-not.html
Headlights will not turn OFF on Ford expedition and car trailer?
http://technoanswers.blogspot.com/2012/01/headlights-will-not-turn-off-on-ford.html
Headlight Assembly Removal on 2010 buick lacrosse? http://technoanswers.blogspot.in/2012/04/headlight-assembly-removal-on-2010.html
--------- Headlights flickering and car hesitates to start?
http://howtobyme.blogspot.in/2012/02/headlights-flickering-and-car-hesitates.html
Hummers headlights flashes while start?
http://technoanswers.blogspot.in/2012/02/hummers-headlights-flashes-while-start.html
Using non-AFS headlamp assembly for AFS assembly?
http://schematicsdiagram.blogspot.in/2012/02/using-non-afs-headlamp-assembly-for-afs.html
How to replace Headlight Bulb on 2001 mitsubishi magna
http://www.howtorepairguide.com/2012/10/how-to-replace-headlight-bulb-on-2001.html
These details will help.
Thanks.
Nov 22, 2012 | 1996 Pontiac Grand Am
How do you remove a low beam headlamp and replace on a 2010 mercedes ml350?
quite easy you remove the bumper to gain access so you can remove the headlight .
Aug 01, 2011 | Mercedes-Benz ML350 Cars & Trucks
How do you remove the headlights off a Pontiac grand am 2004
Lighting Headlight, Side Marker, Park & Turn Signal Assembly Removal & Installation To Remove:
  1. Open the hood.
  2. Remove the front air deflector.
  3. Apply light pressure to the headlight lens to hold the headlight in place while disconnecting the retainers.
  4. Lift up the headlight retainers to release the housing.
  5. Remove the headlight assembly, pulling straight forward from the headlight mounting panel. NOTE: Note the location and position of the adjuster retainers and locator tab.
  6. Disconnect the wiring harness from the headlight assembly.
  7. Rotate the bulb(s)/socket(s) as needed counterclockwise to release.
  8. Remove the bulb(s)/socket(s) from the headlight assembly.
To Install:
  1. Install the replacement bulb(s)/socket(s) to the headlight assembly rotating clockwise until fully seated.
  2. Connect the wiring harness to the headlight assembly.
  3. Position the headlight assembly to the mounting panel.
  4. Apply light pressure to the headlight assembly lens to hold the assembly in place while installing the retainers.
  5. Align the headlight assembly retainers and slide them over the assembly mounting tabs
  6. Install the front air deflector.
  7. Close the hood.
Feb 02, 2011 | 2004 Pontiac Grand Am
Once I remove the nuts and bolts, I can't get the headlight to move
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Disconnect the negative (-) battery terminal.
  3. Loosen the mounting bolts and nut of headlight assembly (A).
    Loosen the mounting bolts and nut of headlight assembly (A)-Santa Fe
    Loosen the mounting bolts and nut of headlight assembly-Veracruz
    Click to Enlarge
  4. Take care that retaining clip (A) is not to be damaged-Santa Fe.
  5. Disconnect the headlight electrical connectors.
  6. Remove the headlight assembly.
  7. Remove the headlight bulb:
    • Remove the headlight bulb(s) with a counterclockwise turn-Santa Fe.
    • Remove the headlight bulb after removing the bulb caps (A)-Veracruz.
      Remove the head lamp bulb(s) with a counterclockwise turn-Santa Fe
To install:
  1. Install the headlight bulbs.
  2. Install the headlight bulb caps-Veracruz.
  3. Connect the headlight electrical connector.
  4. Install the headlight assembly.
once bolts out lift up on the headlight unit hope this helps plz vote comment reply if you need more help
Jan 17, 2011 | 2007 Hyundai Santa Fe Limited
How to aim headlights on 2010 toyota camray
Pop the hood and stand in front of the headlight. Look down at the top of the headlight and then move towards the back of the assembly. Towards the center of the car (if you're looking at your driver side headlight, this will be "left" and vice versa for the passenger headlight) you will see a toothed wheel with a bolt thru it mounted on the back of the headlight assembly. It is surround by a rim with a slot at approximately 10 o'clock (driver's side headlight). Use a long philips head screwdriver and turn this wheel by inserting the tip of the screwdriver into this slot. I believe clockwise turns aims the beam lower. A few turns and you should be able to see which way is which.
Be sure to do your adjustments on a level surface with your lights approximately 25' away from a preferably flat wall.
Oct 05, 2010 | 2010 Toyota Camry
Headlight removal
1) Lift up on the headlight retainer to release the headlight assembly. 2) Release the headlight ball studs from the grommets by pulling the headlight assembly from the lower center corner. 3)Remove the headlight assembly from the upper fascia support. 4) Disconnect the harness connector from the headlight assembly. 5) Remove the headlight assembly from the vehicle. 6) Remove the access cover from the rear of the headlight assembly. 7) Remove the headlight bulb socket from the headlight assembly by rotating counterclockwise . 8) Remove the headlight bulb from the socket. Reverse these steps to install and make sure when your done to adjust the headlight.
Jun 17, 2009 | 2005 Pontiac Aztek
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
