Question about Polaris Pb4 - 60 Booster Pump
Pb4 pushes air with litle water
Pump changes and more air than water comes out so sweep stops
    Novelist:
  • 172 Answers
The line in front of the pump which is your suction side is sucking air this line need to be replaced you can just cut the pipe off un tread the male connector and put more teflon tape on it but it will be only a temporary fix is always better to replace the male tread connector
Posted on Jun 16, 2009
Water Flow to Booster Pump
plastic bag with a few socks in it, can be used to block the skimmer plumbing, if the pump is lower than the pool ! if not it will stop draining after the filter emptys
Apr 25, 2013 | Polaris Pb4 - 60 Booster Pump
I have a pb4 polaris booster pump that doesn't seem to put out enough pressure to run the pool sweep.
Check your in line screen and wall fitting to make sure they are right. Sometimes the over pressure button on the wall fitting will blow out.
Also, your local pool store should have a pressure stick they will lend you. It connects the end of the hose where the Polaris would be. You should be getting a least 28 psi. If you are getting less, you may have a clog in the booster pump's impeller. If you have that or more, the problem is internal to the Polaris. Verify that the backup valve is working properly as well.
Mar 21, 2013 | Polaris Pb4 - 60 Booster Pump
Polaris tail not sweeping. I believe the impeller on the booster is clogged restricting water flow
If unit is operating satisfactorily otherwise, the check end of sweep tail for missing orifice tip. Without it tail won/t sweep. Also check adjusting screw. Out - more tail flow In - less.
Dec 01, 2012 | Polaris Pb4 - 60 Booster Pump
I have a Sta-Rite Max-E-Glas II (1.5hp) Pool pump and a Hayward Navigator sweep. The sweep was working then stopped. Pulled it apart found bad bearings replaced them. Ran sweep again worked at first...
Is the pump leaking water? If you lost the prime or are having trouble priming then there would be an air leak somewhere on the suction side of the pump. Poor suction would interfere with the sweep. One way to ell if the pump or suction line(s) are leaking is to examine the inlet basket once the pump is primed. Any air left in there after a few minutes of operation once primed would indicate a leak in the suction/pump.
Jan 04, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Pump seems to running but the water pressure going to polaris does not change when you turn Pump on or off. Polaris is not performing as usual. Is there a way to check if pump is actually pumping the...
Disconnect the hose from the wall and with your hand fell how much pressure you have. It's possible you have an air lock. With the hose off the top fitting of the booster pump and the hose pointing away from you and electrical turn pump on and see what kind of pressure. This will also clear the air.
Jul 14, 2009 | Polaris Pb4 - 60 Booster Pump
Pump comes on for about a minute...then shuts off..
Has this pump worked at all -pumped water?
When it's running for about a minute, is it pumping water?
Is this a self priming pump or do you need to prime it?
Jun 28, 2009 | Polaris Pb4 - 60 Booster Pump
Booster pump for cleaner runs for 30 seconds and then seems to power down and loses pressure tough still running. seems lots of air comes out so sweep stops running
you have an air leak where is getting this air from wll is fron the 3/4 inch line in front of the pump the line goin in this line is loose but don't try to cut the pipe and put more teflon tape because this pipe got hot and now it won't fee tied is always better to replaced I was a pool techinicial in california now I have move to Georgia so I know this verrywell
Jun 14, 2009 | Polaris Pb4 - 60 Booster Pump
Polaris Pb4 - 60 Booster Pump Logo
167 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
