Question about Vehicle Parts & Accessories
How to install headlight assembly on 2010ml350 do I have to remove bumper
Do I have to remove the bumper
  • 3 Answers
SOURCE: How do I replace xc90 headlight assembly?
its really easy. Open the hood, you will see two metal flat bars on the backside of each headlight, holding the headlight assembly on. Pull up on each of them.... remove headlight. Ta da.
Posted on Sep 25, 2008
SOURCE: How do I remove my front headlight assembly.
My head light is broken and I need to replace the whole assmbly. How do I do this?
Posted on Jan 10, 2009
Fleetw00d
  • 31 Answers
SOURCE: Bumper cover removal
It is a little more complicated than that. There are two nuts below the headlight assemblies in the engine compartment. You will need to remove the battery and overflow bottle to get at the one on the passenger side. Remove the turn signals in the bumper, then there are 2 or 3 bolts holding a mounting bracket behind the each of the turn signals. There are a number of bolts with washer heads and reatiners on the underside of the bumper as the previous responder indicated.
Posted on Jan 26, 2009
SOURCE: I need to change the headlight bulbs in my hhr
i need to change the headlight inmy hhr
Posted on Jan 14, 2010
  • 3 Answers
SOURCE: How to change the whole headlight assembly on a 05 Honda CRV
You have to remove the front bumper and grill etc
There are 5 bolts holding the headlight assembly in place. 2 at the top and 3 underneath.
Remove the plastic cross piece by prising out the clips and then the grille clips too then unbolt the bolts eithr side under the wheel arch. The bumper is still fastened using cips. Pull the bumper forward to unclip.
Posted on Feb 19, 2010
How to Replace Headlight Bulb on 2005 Prius?
Remove fender well trim ( a few screws)
Remove front bumper COVER (not the bumper- the plastic cover)
About 14 screws. Mostly on the underside, get a creeper, and a few
on the top.
Remove the (left or right side) Headlight assembly ( a couple more screws).
One assembly contains the headlight, turn signal and running light. Unplug
the electrical connector from the assembly. All bulbs remove from the back
of the headlight assembly. Headlight is held in place by bail wire, smaller
bulbs are 1/4 turn.
Oct 20, 2016 | 2005 Toyota Prius
How to take passenger headlamp out of 328i bmw 2008 so it can be replaced?
2008 328i Passenger headlight assembly removal.
The headlight assembly is held in by 4 "star" bolts (size 25); 2 visible on the top of the assembly, 2 not visible or easily accessible.
The 2 bolts not so visible require that the front half of the wheel well come off and the front bumper or "nose" of the car.... The bumper is what needs to come off, but there are 2 bumper bolts hidden by the wheel well.
The wheel well is held in by 7mm bolts, 2 of which are actually bolted to the bumper on the bottom.
The front bumper is held on with 7mm bolts on the bottom edge, and star bolts, size 25, accessible on the top edge. (Hood open). Here were my steps.
1. Jack up the car on the side you are replacing, remove wheel.
2. Using 7mm socket, remove all the bolts to peel off the front half of the wheel well. With the wheel well out, you can see the 2 other star bolts holding the headlight assembly, but you can only remove one of them... even if you were good enough to get both removed, the headlight assemble will not push out through the bumper.... Keep going with bumper removal.
3. Remove 2, 7mm bolts of the front bumper that are now visible up near the outer edge of the headlight assembly.
4. At this point I removed the bumper's top edge start bolts and bottom edge 7mm bolts about 3/4 of the way across the bumper...
5. The bumper is very flexible and you can now pull it back , reach in, and get that last difficult star bolt on the headlight assembly....
6. Don't forget the one electrical connector....
7. I also recommend testing the new assembly by plugging it in before removing anything
Nov 09, 2012 | Cars & Trucks
How do i change my headlight assembly on a 2001 honda accord
HEADLIGHT REPLACEMENT
1. Remove the front bumper
2. Disconnect the connectors (A).
3. Remove the 5 mounting bolts (B), then remove the headlight assembly (C).
Fig. 21: Removing Mounting Bolts & Headlight Assembly
Jun 24, 2012 | 2001 Honda Accord
Do I have to remove the tray liner from the 2003 Rodeo pick up to replace tail light assembly?
Utility And Sportside Pick-Up Models
  1. Make sure the headlight switch is off and the ignition switch is in the lock position.
  2. Unfasten the screws retaining the lens, then remove the lens.
  3. Disconnect the bulb socket from the license plate lamp by rotating it 1/4 of a turn counterclockwise.
  4. Remove the bulb from the socket.
  5. Installation is the reverse of removal.
    Without A Step Bumper
    2. Disconnect the bulb socket from the license plate lamp by rotating it 1/4 of a turn counterclockwise.
    3. Pull the bulb from the socket.
    4. If necessary, remove the lens retaining clip and the lens from the filler panel.
      With A Step Bumper
      2. If necessary, lift the lamp up and tilt the bottom away from the bumper to release the lamp retainer.
      4. Pull the bulb from the socket.
      5. If necessary, remove the step bumper pad, the screws that attach the lamp to the bumper and remove the lamp assembly.
      6. Installation is the reverse of removal. Tighten the lamp assembly-to-bumper screws to 14 inch lbs. (1.6 Nm).
Dec 12, 2010 | Isuzu Pickup Cars & Trucks
How to change the headlight asembly on 2004 acura rl does the front bumber have to come off
yes the front bumper needs to come off see instructions below
  1. Remove the front bumper and front bumper upper beam.
  2. Disconnect the connectors.
  3. Remove the four mounting bolts, then remove the headlight assembly.
  4. Install the headlight in the reverse order of removal.
  5. After replacement, adjust the headlights to local requirements
Oct 18, 2010 | 2004 Acura 3.5RL
Need to replace the headlight assembly on front passenger side do i have to take off the bumper? for ponitac vibe 2003 also have dent on the area
Yes you do. This is the steps to do that to replace the entire headlight assembly:
Remove the front fascia.
  • Remove the front fascia extensions, if equipped.
  • Remove the front fender liners.
  • Remove the fog lamps.
  • Remove the bolts (4) from the front bumper fascia (3) at the fender.
Remove the bolts from the front bumper fascia at the fender
  • Remove the push-in retainers (2) from the bumper fascia using J38778.
  • Remove the fascia bolts (1) from the fascia.
  • Remove the fascia from the vehicle.
  • Remove the 3 bolts which secure the composite headlamp.
    1. Remove the sidemarker bulb electrical connector.
    2. Remove the sidemarker bulb, if necessary.
    3. Remove the composite headlamp assembly from vehicle.
    To install:
    1. Install the sidemarker bulb to the composite headlamp, if removed.
    2. Connect the sidemarker bulb electrical connector.
    3. Secure the composite headlamp to the vehicle with the 3 bolts. Tighten the headlamp mounting bolts to 89 inch lbs. (10 Nm).
    4. Install the front fascia.
    5. Install the headlamp bulb to the composite headlamp, if removed.
    6. Fasten the headlamp bulb retainer clip.
    7. Install the socket to the headlamp bulb.
    8. Install the rubber cover to the composite headlamp.
    9. Aim the headlamps.
    10. Close the hood.
    Oct 12, 2010 | 2003 Pontiac Vibe
    Damaged headlight assembly
    Its Easy Their are retainers on the top of bumper as well as bottom and bolts on each side at fenders as soon as you get the bumper off you will be able to change head lights and all then jus go back words to put back on
    Jan 23, 2009 | 1998 Buick Century
    Need to replace headlight assembly on 2005 Ford Escape
    ithere are 4 bolts that hold it in...the top 2 are obvious..the others are behind the bumper. the bumper must be removed to acces them...here are the manuals instructions..
    Item Part Number Description 1 — Headlamp assembly bolts (3 required) 2 — Headlamp assembly nut 3 13008 Headlamp assembly 4 14290 Electrical connectors
    Removal and Installation
    NOTE: Make sure the headlamp switch and the ignition switch are in the OFF position.
    1. Remove the front bumper cover. For additional information, refer to Section 501-19.
    1. Remove the 3 headlamp assembly bolts.
      • To install, tighten to 5 Nm (44 lb-in).
    1. Remove the headlamp assembly nut and the headlamp assembly.
      • Disconnect the electrical connectors.
    1. To install, reverse the removal procedure.
    Jan 01, 2009 | 2005 Ford Escape
    Dec 23, 2008 | 2005 Honda CR-V
    How to replace headllight lamp
    I know your frustration! I cannot believe the complexity of changing the headlights. Chevy has tried to make this a dealer item only just to change a headlight bulb. I will try to explain the procedure unfortunately I do not have photos. First you will need to remove the wheel well liner (two bolts and two plastic push pins). Pull the wheel well housing back (you will need to turn the wheel/tire to gain access) and using a 7mm socket remove the plastic support piece that holds the bumper in place (two bolts). Pull the corner of the bumper down until you can locate the bottom bracket of the headlight assembly that is held by a 10mm bolt. Remove it. (Oh did I mention this is a two person job!) Next move to the front of the vehicle (hood up) and remove all the 10mm bolts holding the upper part of the grill (I think there are eight of them). Now remove the obvious top two bolts on the headlight assembly! With two people - one to work the headlight assembly and one to push down the bumper and pull out on the grill assemble, slowly and carefully pull the headlight assembly straight forward. You will need to be mindfully of the small tabs on the headlight assembly that like to get caught on bumper/grill. If you are just replacing the bulb, you should be able to move the headlight assemble far enough forward to gain access to the bulbs without totally removing the headlight assembly. What a ***** job! SHAME on GM.
    Oct 11, 2008 | 2008 Chevrolet Suburban
    Vehicle Parts & Accessories Logo
    15 people viewed this question
    Top Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
