Question about Black & Decker Garden
Need replacement impeller for stripemaster 13
Broken impeller
Having problems with my 1999 yamaha waverunner 800. On full throttlr it seems like something is slipping as it jus revs up & has loss of drive
You either have debris on your impeller or in your impeller housing or you have a damaged/bent/broken impeller and need to replace it.
Jul 13, 2011 | Jet Inflatable Boat Motorized Scooter
My Bosch front loading washer is flashing E:13 and won't open
Hi, i had an E-13 error code on my Bosch 500 series washer. The drain pump impeller was plugged. Access the drain impeller at the bottom front right corner. Just put a pen in the hole and turn the cover. Then you need to manually drain the washer. I used a shop vac by just turning the cap until it started to leak and vacuum the water as it comes out, this takes quite a while. When you get it drained you can take the cap completely off. When I did I found a wipe in the impeller. I took it out and put it back together and the washer worked just as before.
Take care
Jun 13, 2010 | Bosch Nexxt 500 Plus WFMC5301UC
Zanussi FLE1116w won't drain
It sounds like you need to check out the pump. Remove the hoses from the pump and use a flashlight to look into the suction port on the pump for anything clogging up the works. Also check the pump impeller. This noise that you describe could be the impeller. If any blades are missing or broken or if you can't get the impeller to spin freely, the pump is defective and will need replaced. Hard objects like coins, pins, etc. can sometimes make it to the pump and can damage the impeller blades. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 30, 2009 | Zanussi FLE1416W Front Load Washer
My machine is not leaving the water out
Check the drain line for kinks or obstructions. You can take a flashlight, remove the hose from the pump and look into the suction port of the pump. Check for anything clogging the pump. (like the occasional stray sock). Also check the pump impellers for broken or missing blades and ensure that the pump impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective and will need replaced. Hopefully it is just a clogged pump or drain line. Hope this helped and best wishes.
Sep 10, 2009 | Washing Machines
The washer says f1 and stops
What you should do is get a flashlight, remove the hose from the pump and look into the suction port on the pump. Check the blades on the pump impeller. Make sure that no blades are broken or missing and that the pump impeller spins freely. If any blades are missing or broken or if you cannot get the impeller to turn freely, then the pump will need to be replaced. Hopefully, it is just a clogged drainline or pump. Hope this helped and best wishes.
Aug 16, 2009 | Dryers
Slow to drain
What you should do is get a flashlight, remove the hose from the pump and look into the suction port on the pump. Check for anything clogging the pump. Check the blades on the pump impeller. Make sure that no blades are broken or missing and that the impeller rotates freely. If any blades are missing or broken or if you cannot get the impeller to turn freely, then the pump will need to be replaced. Hope this helped and best wishes.
Aug 15, 2009 | Washing Machines
Code f-21. Wahing machine keeps on showing code F-21 after I put it on rins/drain cycle, and 2nd spin. What should I do now?
What you should do is get a flashlight, remove the hose from the pump and look into the suction port on the pump. Check the blades on the pump impeller. Make sure that no blades are broken or missing and that the impeller rotates freely. If any blades are missing or broken or if you cannot get the impeller to turn freely, then the pump will need to be replaced. Hope this helped and best wishes.
LG LDF8812ST WONT DRAIN JUST INTERMITTENT BUZZ NOISE
Hi, there may be an obstruction in the pump housing that is causing the motor to freeze or, the impeller may be stripped and , jamming the pump. this will cause the hum you are hearing. the best way to inspect is to , extract the drain pump by, removing
the bottom drain filter housing or sump. manually
move the pump impeller to self it is moving freely. if the impeller is stripped, it will not be able to produce the draining surge necessary to pull the water out.
If the impeller is fine and, there are no obstructions visible, this will confirm pump failure.. replace the pump in this case
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Jun 19, 2009 | LG LDF8812 Stainless Steel Built-in...
Motor just hums during the wash cycle. Put it in
OK, that piece of glass may have jammed the wash impeller. this will destroy the motor windings. you will need to gain access to the circulation motor asap.the impeller is attached to the motor that is housed within the pump casing(upper). try to manually move the impeller. if its stuck, try ot remove the obstruction.
It is possible that, the motor is already damaged to the point of no return. in this case, replace the circulation motor. your drain pump should be ran by a totally separate motor(wax).
**NOTE
Jun 09, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Garden Logo
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
