Question about 2009 Chevy Uplander Door Mirror g62269520h Power; Driver Side Houston, Texas
Mirror heater not working
Right hand side
    Sergeant:
  • 253 Answers
Check the fuse and the connection between the door and the body of the car. If those are ok then replace the heating element behind the mirror
Posted on Aug 14, 2014
Porsche 928 problems
should be located in the passenger side footwell though being that your one right hand drive may be in the drivers footwell behind the side plastic should look something like this
Jan 15, 2014 | Cars & Trucks
My controls located on the stirring wheel don't work the radio, my dual control ac on the right hand side comes out heat instead of ac,an now my compass on the review mirror is not working 2001ls
clock spring is the problem on the lincoln ls have the same problem with mine it cost around $150 to $200 depends where you get it its located behind the horn and on bottom of steering wheel look up clock spring hope this helps out. att. Jose P.
Aug 04, 2012 | 2001 Lincoln LS
Right hand side electric mirrors will not work when selcted
I is likely the mirror has failed, but the switches can cause this as well, replace the mirror switch first. The mirror is big dollars, even higher if it is color matched to the vehicle paint scheme
May 18, 2012 | 2006 Mercedes-Benz B-Class
Jag 2005 diesel 2.0 where is the fuse front right headlight
found this, hope it helps!
X-Type Fuse/Relay identificationpicture.php?albumid=77&pictureid=795
picture.php?albumid=77&pictureid=796
Engine compartment fuse box - fuses
Fuse Fuse Rating Colour Circuit
No. Type (amps)
F1 Cartridge 20 Blue Dip beam, High Intensity Discharge (HID) light relay.
F2 Cartridge 50 Red Ignition relay feed.
F3 Cartridge 60 Yellow ABS.
F4 Cartridge 30 Pink Rear window heater/heated mirrors relay.
F5 Cartridge 30 Pink Automatic transmission control module relay.
F6 Cartridge 30 Pink Heater blower relay.
F7 Cartridge 50 Red Power supply to passenger compartment fuse box.
F8 Cartridge 80 Black Blower module.
F9 Cartridge 50 Red Engine management system power relay.
F10 Cartridge 20 Blue Headlight power wash pump relay.
F11 Mini Not used.
F12 Mini Not used.
F13 Mini 30 Green Heated front screen right-hand side.
F14 Mini Not used.
F15 Mini 30 Green Heated front screen left-hand side.
F16 Mini 20 Yellow Left-hand dip beam, day time running lights, autolights.
F17 Mini 20 Yellow Right-hand dip beam, HID lights.
F18 Mini 20 Yellow Throttle motor supply.
F19 Mini 15 Blue Screenwash pump, rain sensing system.
F20 Mini 5 Tan Navigation display.
F21 Mini 15 Blue Side (Parking) lights.
F22 Mini 20 Yellow Accessories relay.
F23 Mini 10 Red Air conditioning compressor clutch.
F24 Mini 15 Blue Door lock power.
F25 Mini 15 Blue Direction indicators (GEM).
F26 Mini 15 Blue Horns.
F27 Mini 10 Red Automatic transmission control module, transit relay.
F28 Mini 15 Blue Ignition switch.
F29 Mini 30 Green Starter motor solenoid.
F30 Mini 30 Green Accessory sockets.
F31 Mini 10 Red Engine management relay coil.
F32 Mini 5 Tan Engine management control.
F33 Not used.
F34 Diode D3 Not used.
F35 Diode D2 Engine management control relay diode.
F36 Mini 10 Red Canister purge valve, airflow meter, throttle motor relay, power wash relay, air conditioning relay.
F37 Mini 15 Blue Engine management system, blower speed controller, road speed sensor (if fitted).
F38 Mini 30 Green Oxygen sensor heaters A.
F39 Mini 5 Tan Variable intake valves.
F40 Mini 15 Blue Automatic transmission control module.
F41 Mini 10 Red Injectors.
F42 Mini 30 Green Oxygen sensor heaters B.
Passenger compartment fuse box - fuses
No. Type (amps)
F60 Mini 20 Yellow Power windows left-hand.
F61 Mini 20 Yellow Power windows right-hand.
F62 Mini 7.5 Brown Rear fog lights.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear tail lights.
F64 Mini 7.5 Brown Left-hand - front side light, side markers, rear tail lights.
F65 Mini Not used.
F66 Mini 30 Green Left-hand power seat switches, heater module, lumbar pump.
F67 Mini 5 Tan Battery back-up sounder, transit relay, HID/dip relay, automatic transmission control module.
F68 Mini 15 Blue Cigar lighter.
F69 Mini 7.5 Brown Telematics display, In-car entertainment head unit, antenna module, navigation module, VICS (Japan), parking aid, amplifier premium 1 system, phone handset, phone power supply module, instrument cluster, PATS module.
F70 Mini 30 Green Right-hand power seat switches, heater module, lumbar pump.
F71 Mini 15 Blue VICS (Japan), telephone transceiver, telephone handset.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, Jaguar diagnostic connector/OBDII connector.
F73 Mini 15 Blue Sunroof unit/module.
F74 Mini 15 Blue Instrument cluster, Premium ICE amplifier unit.
F75 Mini 7.5 Brown Mirror fold back module, battery back-up sounder, air conditioning ECU.
F76 Mini Not used.
F77 Mini 7.5 Brown Left-hand and right-hand heated seats modules.
F78 Mini 5 Tan Phone power supply.
F79 Mini 10 Red Automatic transmission only: Reverse lights, reverse light switch, reverse park aid, electrochromic mirror, instrument cluster.
F80 Mini 7.5 Brown Park interlock, heater switch, OBDII, blower relay.
F81 Mini 20 Yellow Fuel pump control module.
F82 Mini 10 Red Variable power steering, alternator.
Manual transmission only: Reverse lights, reverse light switch reverse park aid, electrochromic mirror, instrument cluster.
F83 Mini 15 Blue Not used.
F84 Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor.
F85 Mini 7.5 Brown Right-hand high beam light.
F86 Mini 7.5 Brown Left-hand high beam light.
F87 Mini 15 Blue Front fog lights, master light switch.
F88 Mini Not used.
F89 Mini Not used.
F90 Mini 7.5 Brown Stop lights, cruise control.
F91 Mini 10 Red Sunroof, electrochromic mirror, power windows, power mirrors.
F92 Mini 10 Red Manual transmission cruise control clutch switch, ignition coils, automatic transmission rotary switch.
F93 Mini 30 Green Windscreen wipers.
F94 Mini 20 Yellow HID module.
F95 Mini 10 Red Airbag restraints module.
F96 Mini 7.5 Brown ABS module.
F97 Mini 7.5 Brown Glove compartment light, instrument cluster lights, licence plate lights.
F98 Mini 10 Red Mirror heaters.
F99 Mini 10 Red Luggage compartment light, footwell lights, puddle lights, vanity mirror lights, interior lights, aircon control unit, roof console unit.__________________
02 X-type 3.0l
04 S-type 3.0l
07 X-type 3.0l
Apr 05, 2012 | 2004 Jaguar X-Type
Need to know on a 2003 Jaguar X Type what fuse goes to the Fuel pump? The fuse box cover only lists the fuses by number.
The fuse box in the passenger compartment has the fuse you want, it is the F81 Mini 20 Yellow Fuel pump control module other fuses in that compartment are.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear lights
F65 Mini Not used.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, diagnostic connector/OBDII connector.
F76 Mini Not used.
F87 Mini 15 Blue Front Fogs master light switch.
F88 Mini Not used.
F89 Mini Not used.
Jan 07, 2011 | 2003 Jaguar X-Type
Same problem. motor works
adjust your mirror to center with your hand manually and try the switch again. if it still dosn't work switch to the other side mirror and see if the other side goes up/down. if it does then replace the side that's not going up and down....you have to replace the whole assembly. can't just replace motor.
Jul 19, 2009 | 2002 Toyota Camry
Cataliyst converter bank one; heater valve; etc. for Jaguar typeS
change O2 sensor their cheap enough ,heater valve not sure about ,seat and mirrors is either a fuse or a relay
Jan 05, 2009 | 2000 Jaguar S-Type
Heater core
NO, BUT THE COMPLETE HVAC MODULE NEEDS TO BE REMOVED. THIS IS BASICALLY THE LARGE BLACK AIR DISTRIBUTION BOX LOCATED UNDER THE RH SIDE OF DASH. THE RH BODY MOUNT BUSHINGS ARE ALSO GOING TO NEED REMOVAL & THE BODY SLIGHLTY RAISED TO GAIN ACCESS TO CORE UNDERHOOD.
Nov 06, 2008 | 1996 GMC Jimmy
Right Hand mirror doesn't retract
i would check the switch first and also the passenger side door jamb wire harness also i know it sounds simple but ALWAYS check ALL of you fuses before beginning any electrical fault tracing, try removing the switch and identify which wire powers the mirror and manually jump power with a paper clip to the mirror in question there should only be three wires one will have power and the others will be left and right mirror retraction if this works your switch is bad if not go to the mirror and power that manually and if no dice you got a bad motor -jeff
Jul 14, 2008 | 2001 Honda Civic
2009 Chevy Uplander Door Mirror g62269520h Power; Driver Side Houston, Texas Logo
79 people viewed this question
Top OEM Vehicle Parts & Accessories Experts
Bill Boyd
Tom Chichester
 Russ Hill
Russ Hill
Are you an OEM Vehicle Part and Accessory Expert? Answer questions, earn points and help others
