Question about Phase Linear UDV9010 Car DVD Player
Setting the clok
How do you set the clock?
  • 327 Answers
Re: Setting the clok
I hope this helps as there were no other instructions avaiable for that model. If this is no good, I will try harder to get the exact manual.
Posted on Oct 30, 2007
0 characters
3 Points
How do i change the time on the clock?
Hi the details are below. Hope it helps I have added a link for the manual at the very bottom, Good luck with it.....
Time Adjusts the systems clock. The time difference (+, -) between the time originally set in your navigation system is set here. You can also select summer time On/Off. > Time settings, (See page 131) Summer Time Choose whether or not to take summer time into account. On: Summer time is taken into account. Off* Summer time is not taken into account...... When the period of summer time comes, or when the summer time ends, your navigation system does not automatically change the summer time setting. > Change the summer time setting, (see Page 131)
To set the time difference, touch "+" or ."-" The time difference between the time originally set in the navigation system (Pacific Standard Time) and the current location of your vehicle is shown. If necessary, adjust the time difference. Touching "+" or "-" changes the time difference display in one-hour increments. The time difference can be set from +3 to -3 hours. If necessary, set to summer time. Daylight Saving Time (DST) is off by default. Touch "Off" to change the time if you are in the daylight saving period. This turns the display below summer time "On". 9 To complete the setting, touch "Back". The map of your surroundings appears. This completes the setup of your navigation system. Chapter 1 explains the basic operation of your navigation system. > To change the time later, (see page 75)
The link to manual here:-
Mar 29, 2011 | Pioneer AVIC-D3 Car DVD Player
Setting the clock
Please give me a min.i'll let you know if there's a manual available for your model
Apr 24, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
How do you start the clocks on this until?
From Eclipse tech support...
Basically, as they said: The clock is set by the GPS. The unit needs to be On.
AVN-5500 Setting Daylight Saving time: The clock is set by the GPS. The unit needs to be On. Push the [MENU]
button once, on the display touch the [SETUP] icon, then touch the [TIME ZONE] icon, and then select DAYLIGHT
SAVING On/Off. Push the [OK] icon to 2 times to exit. Tech Support[Quote]
So it does not appear that it can be performed manually.
I hope that helps
Mar 23, 2010 | Eclipse AVN5500 Car DVD Player
I cant set the clock "? i wanna solve for this prop
Try going to map mode the go to menu and click on function or setting and clock
Mar 07, 2009 | Pioneer AVIC-D3 Car DVD Player
Setting the clock on a Pioneer AVIC-N2?
Here is a link to the manual and install guide. pioneer
Software go to ebay there is someone selling the East disc for 60 and the west disc for 60 . that is the cheapest i have found
Feb 20, 2009 | Pioneer AVIC-N2 Car DVD Player
Clock setting on alpine iva-w200
Copied from support page:
Setting item: CLOCK ADJUST
Further setting items : HOUR / MINUTE / TIME ADJUST
Setting content: 1-12 / 0-59 / RESET
The clock-adjusting mode is canceled when the power is turned off,
when [RETURN] or [CONTROL] is touched.
Setting content: OFF / ON
Setting the Time
HOUR: Adjust the hour.
MINUTE: Adjust the minute.
RESET: If the clock shows less than 30 minutes past, the
minute will be “: 0”; more than 30, the hour
Setting Daylight Saving Time
ON: Place the Summer Time mode ON. The time advances by
one hour.
OFF: Return to the ordinary time.
Aug 19, 2008 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
Set the clock
The D3 is set automatically to West Coast (PST) Time. Only when you reset the D3 can you change the time. Hit the reset button and you'll start setting up the settings. It will bring you to the clock feature. Depending on where you are in the country you will need to hit the [+] button one click for each time zone east (i.e. East Coast (EST) is three clicks). Then you need to hit the "Summer Time" button becasue of Daylight Savings Time.
As for the Phone Book I don't use that feature so can't help you there
May 16, 2008 | Pioneer AVIC-D3 Car DVD Player
Setting the clock
Reset the unit and insert the navi disc. The time adjustment option will show up at start up. Goodluck.
Mar 11, 2008 | Pioneer AVICN2 In-Dash DVD Multimedia AV...
you have to go in to your setup. once in there push the numbered buttons and one of them will change the time.
Nov 24, 2007 | Alpine CVA-1003 Car Video Player
AUDIOVOX CDA 100 AM/FM/CD setting clock
  1. Turn the vehicle ignition and radio "on".
  2. Press and hold the Time/Frequency Selector button approximately 2 seconds until the time display begins flashing on the display panel.
  3. Within 5 seconds after the time display begins flashing press the Manual Down Turning button (<<) to adjust the hours and the Manual Up Turning button (>>) to adjust the minutes to the correct time.
  4. Five seconds after the last hour or minute adjustment is made, the time will be set in the unit and normal operation can resume.
Contact or 1-800-688-3135 and they will email (PDA) or fax a copy of the manual.
Oct 17, 2007 | Audiovox AM/FM/DVD/CD/MP3/WMA Receiver...
Phase Linear UDV9010 Car DVD Player Logo
269 people viewed this question
Top Phase Linear Car Video Players Experts
xxxxxx xxx
Are you a Phase Linear Car Video Player Expert? Answer questions, earn points and help others
