Question about Stiebel Eltron TEMPRA 24 Tankless Water Heater
How to reset
No power
I need help. My water heater all of a sudden stopped heating after an extension cord had shorted in the next room over. So could the problem be the breaker or the reset button which is stuck?
Check the breaker first and confirm that power is being delivered to unit. Then if power is confirmed, try the reset and make sure that power is now getting to the heating coils. If necessary, you can always jump the reset switch if it stays stuck.
Aug 26, 2015 | Water Water Heaters
Reset button on water heater keeps tripping
Need a new thermostat to keep the unit from tripping
Feb 13, 2013 | Bradford White CF-50-6 50 Gallon - 119,000...
Water is not hot
If your water has NO hot water, then click circuit breaker
Next, click red reset button.
Turn off power.
Open cover on water heater.
If heater has 2 covers, open top cover
After re-seting water heater, insulation must be put back over thermostat to prevent cooler air from affecting thermostat.
1) Reset button is a good starting place to check water heater.
Reset clicks off for a number of reasons, including overheated water.
2) Reset will not reset, then replace thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) Resets clicks on, but clicks off again later, you should diagnose the problem.
Clicking reset is not a hazard
Click the reset as often as you want until you have time to diagnose.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
4) Reset is not tripped, and you still do not have hot water:
Then use tester on top two screws (T1 - T3 screws -or- 1 and 3 screws) of upper thermostat to check if you have power.
If you have power, then replace thermostat.
If problems continue, a full diagnosis is needed as per the link above
If you need more help, add a comment and I will respond
Oct 29, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Electric water heater out. Already replaced elements and breaker. Getting power to the unit but no hot water. What now?
Have you reset thermostat on the heater, it will be the top thermostat right above the element. It will have a red reset button to press to reset. They will trip causing the heater not to work till it's reset or replaced due to thermostat gone bad. Chances are you may only have to reset it.
Please go to link below with to get some very helpful information on these topic's. If you replaced everything but the thermostat or reset it that's all left to hold out power to water heater. The thermostat is a safety device to protect the home owner. You may have had a element short out to trip it.
It will take 30 to 45 minutes to start to produce hot water after power comes back on.
http://www.water-heater-repair-guide.com/electricwaterheatertroubleshooting.html
Jun 17, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
I had a bad lower element, replaced it, refilled tank turned on electric, no power going to lower element
Check power going into thermostat and coming out. Power comes through top thermostat to rest of electrical component's. Thermostat may be tripped out if so press red reset button. If it don't reset the thermostat may be bad.
Jun 07, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Amtrol Boiler Mate WH-7P (oil). We had a power failure, and when the power came back on the water heater did not. We've checked fuses, etc., but there doesn't seem to be power to the water heater. We can't...
If you check for power at the tank, (the black and white wires) you should read voltage, either 24 vac, or 120 vac, depending on how it is wired. If there is no power there, then you will have to chase power back to where you do have it. There is no fuse or reset button on this model.
Jan 19, 2010 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
The control unit needs to be reset when I loose power
have two boilers one a rheem the other raypak, the raypak keeps turing off i have to push the reset button. what could be wrong
Dec 30, 2009 | Rheem Paloma Tankless Water Heaters...
How do you reset
press the reset button this should take it to high if no i belive your limit switch has gone bad please rate this answer good luck
Nov 20, 2009 | RELIANCE ELECTRIC WATER HEATER
Reset button for tankless water heater
you need to unplug the unit, wait for 30 seconds reset the temp to the lowest temp, then try it, if this does not work it might have done something to the circuit board, are you on a gfi out let it needs to be there is water and ele, and should be on the gfi with a reset on it,,
Jun 01, 2009 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Stiebel Eltron TEMPRA 24 Tankless Water Heater Logo
44 people viewed this question
Top Stiebel Eltron Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
