Question about iLO 2600 Television
Cable company switched to digital and the audio quit working for channels under 100 - former analog channels. channels 100+ work fine. when I switch to dtv, I get the "no signal" message.
  • 668 Answers
If you are using HDMI with the cable companies cable box, you may have to go into the
cable box menue and set the audio out as HDMI. I had a similar problem with my cable providers box.
Hope this helps,
Skyassoc
Posted on Jun 16, 2009
How do I change Channel default on start up
Use your remote. Press menu and look up initial set up or reset to factory settings.
* Note that as of Jan 2018 most cable companies do not provide analog outputs to TV sets. If your still using Channel 3 for an input to your TV then it won't work or will stop working some time this year.
* Hook up your TV using the old RCA video/audio jacks; Yellow plug is video, Red is audio right, White is audio left.
* You can also use an HDMI cable (best) for High Def picture which is all the rage for HD TV.
* You may also connect using the DVD style cable hook up which uses 4-5 separate cables (3 for colors and 2 for audio)
* Once you have some sort of video or message on the TV screen then you can proceed to setting up the cable box. Have the cable box hooked up and on for at least 15 mins. Look at the cable box display till the correct time is displayed. Power up the cable box till you see the power on indicator. Now use your TV remote to select the correct input you hooked your cables t. (probably HDMI) The display should show you your cable service. Now use the cable remote to select your channel.
* If you don't have a cable box but still have digital service (usually called basic cable - no premium) then use the analog/digital input on the TV remote and select initial set up. There should be an automatic channel search and set up to scan all the channels available on the line your connected to. This will take up to 15mins. If you know the specific channel you can cancel the scan and pick each channel for you own list. Letting the scan run may help you find other channels you are unaware of.
* Final; if your still having problems then call you TV MFR support line and they will talk you through to check your set.
* You can also check the cable company support line if the TV check out okay. The cable company may or may not be able to supply you service for really old Tube style TV sets as most if not all TV's are digital now.
Aloha, ukeboy57
May 29, 2018 | Computers & Internet
I have a panasonic dmr-eh50 dvd recorder, and it can not receive any channels, i have it connected ota antenna, and i am using the standard red,white and yellow cables.
I had a similar problem in DEC 2017. Curiously the cable company stopped by in a week or so. (I did not call them for service.) It was a "SPECTRUM" truck and not an "OCEANIC" truck. Apparently Oceanic got bought out and the Technician was going around the neighborhood (Honolulu) searching for "Home Broadcasts" I remember reading about WW2 military was looking for homes with RF signals (looking for spys) I'm a retired Army Signal Corps. The Spectrum tech installed a filter on my cable line to prevent our home from producing stray signals. He also told me that my 'analog' TV won't work in JAN 2018 as they are switching to all digital by then. Says my cable will work for a while but expect the company to switch all the cable boxes out to digital. Sure enough my TV stopped working (on analog channel 3) and my cable box stopped sending the analog signal to my analog set. I found out that some of the other outputs worked (HDMI, Optical, etc.) I got the Bedroom TV (bought 2017) to work on HDMI. Picture is crisp BUT I don't seem to have the picture size right. It's smaller than normal (on analog) and changing screen from normal, wide, zoom, etc. really makes it worse. Panoramic is the best so far. Now I notice our older 'Monitor' 42" Plazma (2010?) still works on Chan 3 analog signal. I didn't have another HDMI ($30) cable so I tried using my old DVD Yellow-White-Red RCA cables and found it did not work.
* So.. Short answer; you need to get your TV hooked up to the HDMI output of the cable box. But I would check with your cable company first to see if they can resolve your issue. Now days, they can use a computer (from their end) to correct the problem or send out a service tech.
Aloha, ukeboy57
Mar 21, 2018 | Panasonic Televison & Video
Tv problem- I have a LG model47lb5800. when I turn on the TV it shows a picture and sound for about 3-10 minutes. The TV then goes black flashes a picture intermittently. What's failing?
Aloha, ukeboy57
PS Try rescanning for channels. You will need channel 3 (sometimes #4) If it shows vertical bars then your set can't tune to the cable box. (Just like the old days of "Outer Limits") They do control the horizontal and vertical. You can try to hook your TV directly to the cable without the cable box to get some of the analog and digital channels if your set is less than 10 years old. But the channels are weird and hard to browse. You will need to write down the channels to remember your favorites. Cable remote won't work. But this is just a short term fix. You will end up subscribing to a cable or internet TV service.
Mar 21, 2018 | LG Televison & Video
I have a 19" magnavox
Do you have a digital converter box. If not, you need to get one to receive the analog channels.
Feb 06, 2011 | Televison & Video
Trying to set up Digital Labs 19''LCD TV/DVD combo and only gets limited cable channels (old tv on same cable gets lot more). Have completed auto scan and pick cable as reciever however only gets limited...
The remote control that came with my Digital Labs tv/dvd combo worked for about 2 seconds and never really worked correctly. Now, I'm trying to find a universal remote that will be compatible. Please help.
Dec 26, 2009 | Televison & Video
I am trying to hook up a digital labs, 19'' lcd tv/dvd combo and when i do the initial channel scan it doesnt pick up anything from the satelite at all, i have hooked them toghther anyway i can think of...
Most HDTVs have ATSC, QAM and NTSC (analog) tuners. It sounds like yours does not have an NTSC (analog) tuner. QAM tuners only pick up digital cable channels. You may need to switch to your cable company's digital service if your not already on it. Call your cable company for further info
Only receive channel 11
Just rescan the channels under the menu button!
Mar 11, 2009 | Insignia Digital-to-Analog Converter for...
Audio with digital channels, no audio with analog channels
I was getting a constant mono setting for all channels with no option to set it to stereo. I called Sharp, and they said that in order to receive stereo sound, you cannot use a standard coaxial cable. You need an S-Video or HDMI cable. This not only resolves the mono audio issue but also resolves the analog (vs. stereo) issue. Hope this helps!!
Feb 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Ittermittent digital audio drop out on some channels
Did the issue ever get resolved. I have similar issues with a connection to Cox Cable HDTV and Onkyo TX-DX989. All sources (DVD Player) sound fine and not issues except channels 706 and 710 on Cox Digital receiver. I had Cox replace the HDTV receiver and the same issue occurs. I've tried optical audio and also the COAX audio ports with the same issue. The workaround I have found is to set the audio to "Other" on the Cox box, but the volume then has to be turned up quite a bit.
Jan 16, 2009 | Onkyo TX-DS989 Receiver
Televison & Video Logo
74 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
