Need manual for a sears forester wood fireplace insert
Need manual, does it need additional flue pipe to put up chimney
2 Suggested Answers
  • 2464 Answers
SOURCE: How change a Marco Fireplace from wood burning to gas logs
HI best get as gas fitter in to look at this and see if it can be done safer bet
Posted on Feb 25, 2010
How to put the mantel and flue parts back on in the fireplace
Fireplace and Chimney Parts: Diagram and Anatomy
https://www.highschimney.com/.../parts-chimney-anatomy-fireplace-chi...
Nov 30, 2011 - A chimney is made up of up to 22 parts. ... Mantle - Also known asmantel piece or mantel shelf, this piece of hardware is more than a .... I have an old Blaze King Fireplace Insert that was purchased back in the mid 1980's.
How to install a wood burning fireplace insert - Hearth.com
www.hearth.com/econtent/index.php/articles/install_insert
A Heatform is a metal firebox which is built into a full masonry chimney. ... The distance to the adjacent wood trim and the mantle. ... All the way back in the fireplace, or out on the hearth? ... Rockford Chimney Supply - We are the best source forChimney liners and Stainless steel chimney liner kits to install your insert or ...
Dec 20, 2015 | Heating & Cooling
The fireplace no longer produces a flame, i do not have the manual to trouble shoot and fix it
Gas Fireplace Manual - Gas Fireplace Instructions: Mendota ...
mendotahearth.com/gas-fireplace-stove-owners-manual.php
Mendota gas fireplace manuals and gas fireplace instructions for Mendota ...Mendota Gas Fireplace Insert FullView Model FV33i PF2 - Installation Manual
[PDF]FIREPLACE HEATER - Crane
crane-usa.com/assets/.../Fireplace_Heater_2013.pdf
by C Care - ‎Cited by 2 - ‎Related articles
your fireplace heater, please contact Crane. Customer ... This instruction manualapplies to the following models of the Fireplace Heaters product line: Color.
Nov 29, 2015 | Heating & Cooling
I have a free standing wood burning stove Hearth Stone brand Is there a product that one could wrap the chimney flue with to avoid a small child from burning its hand? Thanks
There is a completely double insulated flue pipe available on the market by SELKIRK and more
INSULATED stove pipe DIY CHIMNEY FLUE - YouTube
? 4:06
https://www.youtube.com/watch?v=D6AHJ_XbOCo
Oct 19, 2011 - Uploaded by ROCKNTV1
CHIMNEY FLUE DOUBLE WALL INSULATEDhttp://www.rockntv1.com/2011/10/insulated-stove-pipe-diy .. And see google for vendors
Nov 29, 2015 | Home
Even if it was a wood burning fireplace from the beginning & was converted to gas ?
Now that's a LOT of additional information. I hesitated to answer your question the way it was worded originally.... IF in fact it is a masonry chimney and originally built to burn wood, you should have a chimney sweep do a thorough inspection of the flue to ensure it is safe to use again. Flue temperatures, while burning wood, EASILY exceed 1200 degrees whereas natural gas flue temps are in the 450 degree range.
It also should have a clay tile liner and not be fabricated of brick only. The unsafe thing of an unlined brick chimney or a chimney with a severely cracked liner has to do with unburned gases condensing within the inner surfaces of the chimney. Some of those gases are moist and will condense on the inner surface and eventually have an unsafe build up that can be ignited by an oversized flame or excessive sparks causing a flue fire. During a flu fire, temperatures exced 2000 degrees and an unlined BRICK flue of that age could have lost some mortar allowing superheated gasses to seep into the crevices. Those superheated gasses then explode when igniged by the flue fire and either do extreme damage to the flue, blow the entire chimney apart or in the worst case scenario burn your house down.
I'm sure you've seen houses burnt and the chimney was left standing....but you have also seen damaged houses with the chimneys blown off the end of the house and laying in rubble toppled out into the yard. The latter visual picture was an example of the end result of the gasses exploding. If the chimney was inside the house instead of on the end of the house, the house would have been burnt also.
There is a lot to be careful about when heating with wood and to start off safely you need to have your chimney inspected and the gas components removed with the gas line capped EXTERNAL of the fireplace.
Dec 08, 2014 | Home
Can't keep the wood burning in stove. How does the buck stove take in air?
To burn properly, it needs proper combustion air and proper draft. Draft is effected by the size and height of the flue the appliance is connected to and by how much combustion air is available. The appliance flue connection should not be reduced to fit a smaller chimney size. That is, an 8" flue should not have an 8 x 6 reducer to vent it into a 6" chimney.
The wood you are burning could contribute to a poorly burning fire. To burn properly, the wood needs to have been "seasoned" for a minimum of 1 year or close to it. Two years is even better. "Green"
or freshly cut wood contains an unbelieveable amount of moisture in it and a tremendous amount of the heat is wasted just "preheating" the wood to the temperature that causes it to release gasses for ignition.
I don't know the style or model of your Buck, but all wood burning appliances should have combustion air dampers of either a sliding design, rotating round design or hinged design with handle at the bottom front of the firebox. I'm sure there are some fancy new designs that have air piped in from outside the structure.
Every wood fired stove, fireplace or furnace has its own idiosyncrasies and its up to the user to determine what's required for making it operate as designed.
Dec 06, 2014 | Buck Stove Home
I bought a house with a wood burning stove but I don't know how to operate it
First make sure everything is clean,from the chimney to the stove.insure all metal flues are tight from stove to chimney. Open damper on top of stove(some are in metal pipes). Open your draft vents, usually on clean out door at bottom. Depending on chimney draft you may need to open clean out door to get it started. Load your kindling and get it started. Add bigger wood as it catches. Turn down venting and drafting as the fire roars. Just don't shut draft before vents. You'll get used to balancing draft and vent as you go. I hope this helps
Nov 19, 2014 | Home
I'm installing a wood stove insert with a 6" flu. Can I use a 5" or 5.5" chimney liner and be ok? Thanks in advance. Jacob Ullucci
If the stove exhaust pipe is 6", you need to have a minimum of 6" all the way up your chimney. If you use a smaller pipe you will limit your flow, which causes excess cooling and crystalizing of smoke creating more creosote, and more of a chance for chimney fire. The perfect solution would be to run a 6" liner down your chimney, and connect it right to the top of your insert. Make sure you install a top plate at the top of the chimney to insure pieces don't fall outside the liner. Lastly install a stainless steel cap to keep any animals out.
Sep 13, 2013 | Hearth Products Controls Round Match Lit...
How is air supply regulated in wood burning stoves?
To regulate air flow, there are damper devices built into the stove, flue and stove pipes. Keeping the air flowing correctly through a wood-burning stove is essential for safe and efficient operation of the stove. Fresh air needs to enter the wood compartment to provide oxygen fuel for the fire; as the fire burns, the smoke must be allowed to rise through the stove pipes, and exit through the chimney.
May 07, 2013 | Home
I can hear the wind blowing extremely noisy from my gas fire /chimney
It is not likely blowing from the fireplace, rather your hearing outside wind noise through the chimney pipe.
On windy days this is normal.
The noise can only be limited by the flue pipe damper and the length of the pipe.
Apr 14, 2013 | Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
