Netflix keeps rewinding
Keeps rewinding
I can't get connected to Netflix.All that pops up is error code 209826
1 (866) 579-7172
this is Netflix customer support phone number. Basically their are at least 9 way to contact them the link is below. Good luck.
https://gethuman.com/contact/Netflix/more
Dec 30, 2014 | Netflix
Netflix keeps buffering, how do i fix?
Make sure your WiFi is reliable
Aug 03, 2014 | Netflix
How to rewind film on minolta maxxum 5000?
Open door in the dark room.
See if it's already rewinded, but could be a stuck counter
May 12, 2014 | Minolta Maxxum 5000 35mm SLR Camera
My netflix has a lag
This is due to a slow broadband speed. Ideally you need at a minimum 2.5Gbs.
Mar 26, 2014 | Netflix
Sony BM-246 working, then not
If your cassette stops but the counters keep rewinding the left hand rewind spool is worn.This is accessible from the top by carefully removing the little washer/clip and inspecting the drive hex.Parts may be a problem although this is not that common a fault in a bm246. If the counters stop along with the cassette there is a drive problem in the deck and you are is deep****. If the B deck is the sad one the machine may have been used with a footpedal as a transcriber. The decks are interchangeable however and with a bit of care you could get a usable machine.. just unable to rewind the bad deck. Good luck.
Feb 03, 2009 | Office Equipment & Supplies
Camera keeps rewinding film
Check the manual rewind button on the bottom plate of the camera. Make sure the button is not jammed under the edge of the button opening. If it is you might be able to carefully pry it out with a sharp pin or tooth pick (be careful not to pierce the button or you could damage the circuit board underneath) Or you could remove the bottom plate and reseat the button (be careful of a loose spring to the film door latch)
Dec 03, 2008 | Minolta Maxxum 300si 35mm SLR Camera
ERR sign keeps blinking in the lcd
First check the batteries. Are they fully charged? If you still have the same problem, try this:
Is the film (that which did not rewind fully) still in the camera? If so, open the film chamber door once in a dark room and close it again. Try to rewind the film again. This could possibly be the result of the film getting stuck somewhere, preventing the camera from rewinding it.
Mar 18, 2008 | Nikon F80 35mm SLR Camera
Video will not rewind to beginning of tape.
the clutch gear needs to be replaced . you can order the part partstore.com go by brand and model easy to replace around 30.00 dls .
Jun 20, 2007 | Toshiba V643 S-VHS VCR
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
