Question about Dishwashers
Cata dwib60 Overfil alarm active. How to reset
Why is car alarm going off by itself?
The alarm system probably needs to be reset. With the door closed cycle the key in the drivers door lock cylinder and it should reset the alarm system.
Jul 21, 2014 | 2005 Honda Odyssey
How do you reset the alarm system on a Porsche Boxster
What exactly are you meaning by resetting the alarm? The remote fob will de-activate/activate the alarm
Jun 28, 2014 | 2000 Porsche Boxster
Cannot unlock doors and reset alarm
Go on youtube and put in how to reset your car key after renewing key fob battery good luck colin
Jun 30, 2017 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Download users instructions for ceramic t/ch hog model no. ECL90T
My search shows that the ECL90T hob is a product of an India-based company, Cata. Visiting their website reveals no direct link for Support or downloadable manuals. However, there is a link to contact them through email which I believe is your best bet. Here is the link:
http://www.cataindia.com/ContactUs.php
Also, I found a UK-based site where you can purchase parts. Contacting them may also yield a user manual:
http://www.myspareparts.co.uk/cata/Cata-ECL90T-Long-Ceramic-Hob
Feb 11, 2012 | Cooktops
2004 Hyundai Elantra won't start, emergency flashers keep blinking, can't shut off, lights dim, can't jump start, clicking from under dash from relays. What could it be?
The 'Keyless Entry & Burglar Alarm System" is activated. You must 'Disarm' the system using the Keyless Entry Remove (Key Fob) to "Reset" the system. The reason the engine won't start is due to the burglar alarm - it has a "Starter Kill" circuit which is activated when the alarm is activated. The alarm must be DEactivated to DEactivate the 'Starter Kill' circuit.
Another way to start the engine is to get in the car, put the key in the ignition and turn it to 'ON" and wait 3 to 5 minutes until the emergency flashers stop/turn off. Afterward, you should be able to start the engine. NOTE: This does NOT reset the burglar alarm. It will go off again when you enter the vehicle without using the remote/key fob.
Sep 06, 2011 | Hyundai Elantra Cars & Trucks
Cata Single Oven Stainless Steel EF60SS Can't get it to heat up
Hi Ya
I have the same oven with the same problem.
To resolve the problem you will need to replace thermal switch, which can be found at the rear of the cooker behind the protective cover. Approx at the bottom left corner. It looks like the shape of an eye with to wires. Hope this helps. Kevin Reseigh
Jan 10, 2010 | Ovens
Can't figure out how to deactivate the alarm on Umbro U564B watch
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu: Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
Mar 03, 2009 | Bulova Watch
Smoke Dector need to be reset on alarm.com
try forcing a signal for the detector and the resetting it. that way alarm.com will se the alarm and restoral. if that does not work call alarm.com and have them help you. make them earn there money,
mj
Feb 21, 2008 | GE Security Simon 3 Wireless Home Security...
Dishwashers Logo
13 people viewed this question
Top Dishwashers Experts
