Question about Kenmore HE2 Plus Front Load Washer
Drum balance Loud
    Top Expert:
  • Kenmore Master
  • 14,161 Answers
Posted on Jun 15, 2015
Error code warning my load is out of balance
If the drum spin noise is loud your bearings need replacing.
If the bowl(drum)goes out of balance with nothing in it your bowl needs to be replaced.
Sep 03, 2012 | Fisher and Paykel Washing Machines
I get a loud scraping noise when I first start up the dryer
It sounds like the drum is off balance, the drum could be scrapping along the side of the dryer. Check for a loose bolt on the drum assembly. Once it starts running the drum levels out and the scrapping noise goes away
May 14, 2011 | GE DVL223GB Gas Dryer
Washer is out of balance. it just leans to the left side and makes loud noise like metal on metal.
It sounds like your drum support, and/or balance mechanism inside the washing machine has broken. You will need to open your Washing machine and inspect the Drum Support, and the balance mechanism. Hook it back up or replace it if it is broken.
Feb 27, 2011 | Washing Machines
Loud thumping as drum turns. NOT and
felt bearing gone ...followed by grinding,,possible marks on clothes..
Apr 07, 2010 | Frigidaire GLER642A Electric Dryer
Washer drum on spin cycle loud and vibrates
To start ensure that is not just a balancing problem.
You probably have to replace the drum bearing, it is the part located at the bottom of the tub, the drum bearing if fixed at the back of the drum.
Parts & Accessories
Regards,
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Loud clunking sound during the spin cycle, washer is balanced and on 2nd floor
If you get a very loud noise coming from the machine, and this noise islouder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Nov 13, 2009 | Frigidaire GLTR1670A Front Load Washer
Loud knocking noice around drum area when on final spin.
i suspect the bearings have gone
hope this has helped :)
Oct 14, 2009 | Washing Machines
LOUD NOICE AND JUMPING
IT seems that the wash drum is hitting on the exterior body possibly the shock absorbers have flattened out. Also the balancing liquid in the top inner portion of the wash drum has leaked out u will have to check the two
Oct 08, 2009 | Washing Machines
Making a loud noise when on the spin cycle and not balanced
It could be a drum spring has broken or stretched too far, there is too much of a heavy load in the drum, or the bearing needs replacing.
Sep 11, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Machine drum makes loud noice in the spin cycle. Makes the same sound that a top-loading machine makes when it goes out of balance. Help.
  • Hi,
  • Try these:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 20, 2009 | Kenmore Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
