Question about Samsung RF4267HA 25.5 Cu. Ft. French Door Refrigerator with Thru-the-Door Ice
No water After ~ 2 years, my unit suddenly stopped sending water to the door. I suspect the problem is the door switch (which was replaced when the unit was brand new). Is this a common problem???
I have a whirlpool refrigerator side by side with Ice & water in door. I can't get water to come out. How do I fix it?
First make sure that the water line to unit is functional. then check out the solenoid that feeds the water to the door for operation. If it is not working there will never be any water appearing at door. And if solenoid is good the switch that sends it power may be non functional.
Mar 02, 2016 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sub Zero 700 suddenly stops after 12 years. Compresser is burning hot.
The compressor will normally be 100 to 110 degrees. I would suspect the thermostat or mouse damage in the freezer area. Also, if you keep it overstocked, to the point of poor air circulation, you could just have ice blockage. Put the frozen food in a styrofoam cooler or a good heavy corrugated box and give the unit a good full defrosting.
Dec 15, 2012 | Sub-Zero 700 Refrigerator Freezer...
Air condition wather in the interior car
Could be the drain tube is partially clogged. It is usually located on the fire-wall or down towards the floor pan under the car. It is usually close to where the A/C lines go thru the fire-wall. About 1/2 inch diameter sticking straight out but may have a 90 degree elbow pointing down.
Also, it's been extra hot and humid all over and moisture could be freezing inside the unit when on MAX A/C, then suddenly melting when switched to normal. This opens the outside air door and allows warm/hot air into the unit instead of recirculating the cold air inside the car. The drain may not be able to handle a large, sudden quantity of water.
Perform a "driveway" test. Open the hood, start engine and run the A/C on normal with the windows or doors open. Locate the drain tube by looking for water dripping. Once located twist 2 or 3 pipe cleaners together and verify the tube is clean. Then close the doors/windows and switch to MAX A/C. Check for water dripping. If it stops dripping, water is freezing inside and now you know why!
Aug 28, 2011 | 1998 Jeep Grand Cherokee
Just had the idle air control motor replaced and within 1 day, the a/c stopped working and a lot of fluid saturated the front passenger side floor board. Can this recent repair be related to this issue as...
You might take it back to who ever changed the idle air control motor and ask them about it. They could have knocked the drain tube out, or plugged it to stop it from dripping on them or the floor.
You can try this...
Aug 28, 2011 | 2001 Mitsubishi Montero Sport 4WD
Can't find the drain line for ac. water is leaking in side on pass side
Aug 22, 2011 | 2001 Daewoo Lanos
Air conditioner leaking in passanger floor boards how do i fix it
Also, its been extra hot and humid all over and moisture could be freezing inside the unit when on MAX A/C, then suddenly melting when switched to normal. This opens the outside air door and allows warm/hot air into the unit instead of recirculating the cold air inside the car. The drain may not be able to handle a large, sudden quantity of water.
Aug 12, 2011 | 2003 Pontiac Vibe
I have several problems with my Whirlpool washing machine AWO 12763: 1 .- For a long time do not make spin until we press the door. 2 .- For the past few weeks, when entering water, says suddenly we...
Hi.
F-22 is door lock error. The door lock was already defective and now has failed completely. You need to replace the door lock.
Here the error explained in detail:
F22
DOOR LOCK ERROR
Theme Door Lock message is prompted when the door cannot be locked. The CCU (central control unit) will try to lock the door six times before displaying the F 22 error code.
Possible Causes:
The door lock mechanism is broken or removed from door.
Door switch/lock unit failure.
Repair Procedure:
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock, and the central control unit.
Regards.
Ginko
Jun 04, 2011 | Washing Machines
We ve had the Bosch fridge-freezer (KGU3201GB/01) for about 10 years. Suddenly this morning the freezer started losing temperature, which rose to -13 degrees and the alarm went off. We put the...
Hi Robert, sounds like the unit is not defrosting.
Try this to indicate defost issues.
1. relocate food in the freezer, turn the unit off for 2 days and leave the door open, this will allow total defrost.
2. clean, then restart unit with door closed, after and every 2 hours check temp, I feel you may find it will get to its operating temp reasonably fast and should stay there.
If this is the case, I suspect the defrost heater element has failed and needs replacing, this is the most common cause of your type of issue.
Hope that helps and please dont forget to vote. Regards Russ
Mar 19, 2011 | Bosch 3.2 cu. ft. / 91 liter Upright...
My whirlpool suddenly stopped dispensing water.
most fridges stop dispensing water when you open the door. Find the door switch and make sure fridge interior light goes on/off when you manually press door switch. This would show you that the door switch was faulty.
If the water connection to the appliance is one of those watts flood-safe water lines, it may have stuck shut. I've seen this happen when the house water pressure is too high.
Does it still make ice?
If so, then the water connection is good, and either the switch in the water dispenser has failed or the water shutoff valve for the water dispenser has gone bad.
Some models have a problem with the water line getting frozen, such that simply leaving the light on in the water dispenser compartment overnight and/or manually defrosting the unit can get it working again.
Nov 02, 2009 | Refrigerators
Ge gsl25jfrfbs water disoenser not working
Solenoid or the dispenser switch.
The water supply line connects to a water valve on the Ref. this water valve has two solenoids, one for the ice maker and one for the water in the door. Check this solenoid with an OHM meter.
The dispenser switch should send 110 volts to the solenoid. Check at the solenoid while pushing the water switch in the door.
Jan 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
Samsung RF4267HA 25.5 Cu. Ft. French Door Refrigerator with Thru-the-Door Ice Logo
24 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
