Question about KitchenAid Kitchen Appliances - Others
Kmt4115cu lever broke needs replacing
My Kitchenaid toaster lever plastic knob broke off. I epoxied it and it worked for a while, but then broke again. I found a replacement part somewhere online but now can't find the site again. Do you...
Should not be a problem.
Most toaster knobs just push on.
Some are held in place by a metal clip that increases the friction. Some are held in place by a tiny set screw on the bottom of the knob.
You'll figure it out.
Feb 16, 2014 | KitchenAid KMT4115CU Contour Silver Four...
Ink release lever in brother MFC-6490cw broke
Did you ever resolve issue with broken tab. I have same problem on my black cartridge release tab, and am wondering if I can need tab or can salvage. Thanks!
Nov 17, 2012 | Brother MFC 6490CW InkJet Printer
The gear shifter broke off my 02 Mountaineer, the metal part that attaches the shifter lever to the steering column broke.
Shift lever collar is what is broke on our 2002 Mountaineer. It isn't difficult to replace, just time consuming. Look up part number 905-104 at Oreilly's
Oct 27, 2010 | 2002 Mercury Mountaineer
Choke lever . Can I fix this myself? broke off and
According to the model, maybe JB Weld the choke lever back together and fuel lines are completely replaceable....get 'um at a lawnmower parts/repair shop. They are Tygon lines.
Jun 05, 2010 | Garden
Fuel door lever broke
YES THE DOOR COMES AS AN ASSEMBLY
Mar 16, 2010 | 2005 Jaguar S-Type
Replace lever mechnism to recline seat
O'reily stocks a new handle that is especially made to replace the handle that broke. It attaches to the broken shaft you have sticking out of your seat. This is a common problem.
Jun 13, 2009 | 2000 GMC Sonoma Extended Cab
I need to replace the Ice dispenser lever in ny
Unless the old one actually broke, you can re-install it if it merely fell off. Use a mirror and a flashlight to see the hole on the side toward you so that you can re-insert the lever that goes towards the front, then re-insert the lever into the back hole. If the lever actually broke, the new lever will come with directions on how to install it.
May 14, 2009 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Explorer seat
You need a new or used passenger seat tilt lever. Mine broke also. There are a couple on sale on EBay for $30.00. See link, otherwise you can buy new from Ford for about $75.00.
http://cgi.ebay.com/ebaymotors/FORD-EXPLORER-DRIVER-SEAT-TILT-LEVER-ASSEMBLY-91-94-OEM_W0QQcmdZViewItemQQcategoryZ33701QQihZ023QQitemZ360071362943QQrdZ1QQsspagenameZWDVW
Jun 28, 2008 | 1997 Ford Explorer AWD
Kitchen Appliances - Others Logo
42 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
