Question about Magellan NAV6510 GPS Receiver
No power up
Unit has been stored in plastic bag for approx 6 yrs but now will not power up it appears to have been kept dry, no damage is apparent
Is it safe to store food in plastic bags?
Consuming food that has actually been incorrectly kept has the possibility to earn an individual unwell, specifically if that storage space container is a plastic which contains hazardous chemicals. With time these chemicals have actually been connected to cells modifications, hereditary damages, chromosomal mistakes, losing the unborn baby, abnormality, very early beginning of adolescence and also hormone adjustments. In youngsters, chemical leaching could trigger damage to their creating body immune system as well as could lead to interfering with hormonal agents and also behavior issues. Plastic bags are incredibly popular with both sellers in addition to customers since they economical, solid, light-weight, useful, along with sanitary ways of lugging food in addition to various other items. Not just is cluttering unappealing however it is likewise an extremely major ecological risk. Read more option for keep store your food at Icegreen Bulk Reusable Shopping Bags for Grocery Icegreen Canada
Nov 03, 2013 | Home
What is the best to care for my sleeping bag?
When not in use, sleeping bags should be kept away from high heat and away from moisture.
Store in a dry location in moderate temperature.
During use, try to keep the sleeping bag dry and away from open flame.
After use, air dries the sleeping bag outside for several hours.
Follow the manufacturer's instruction for cleaning the sleeping bag. Instructions differ based on the type of material and insulation.
Jul 09, 2012 | Camping, Backpacking & Hiking
How many yrs before a plastic bag rot
first of all, wrong category, and second of all, plastic bags only rot after at least 10 yrs
Jun 20, 2011 | Computers & Internet
I'd like to clean my Canon ip4600 so as to store it for future use. Can this be done please?
If you are not going to use the printer for a number of months, you will need to clear the printhead of ink. Remove the ink cartridges and stretch electrician's plastic electrical tape to seal the ink outlet. Put the ink cartridges in a zip lock plastic bag for storage
Remove the ink cartridge carrier clean with warm water and put in a zip lock plastic bag for storage.
Remove the printhead and soak the printhead, printhead down in warm distilled water overnight. After the printhead has soaked, replace the water with another warm distilled water bath and soak for a couple of hours. This should clear the ink from the printheads. Let the printhead dry and one it is dry, store it in a zip lock plastic bag.
Clean your printer with a damp cloth and wrap it in a plastic bag along with your installation disk and installation instructions.
Your printer and components are now ready to be stored.
Let me know if you have any more questions.
Apr 12, 2011 | Canon PIXMA iP4600 Color InkJet Photo...
This is not a problem, just a curious question: At my vacation home, I have a HP Deskjet D1520. Marvelous little printer for occasional use. My question is this....The printer sometimes sets unused for 3...
Many people apparently have had success with taking out their cartridges and storing them in a tightly sealed plastic bag along with a moist paper towel.
Nov 05, 2010 | HP Office Equipment & Supplies
Vhs SP tapes
It sounds like the tapes may be physically damaged, wrinkled or creased. This may have been done when they were played in whatever machine you used 5 years ago. Tapes can also be damaged in storage by heat or humidity. Tapes should also be stored on end in their boxes, not flat. If these tapes were stored flat, the bottom edge might have gotten wrinkled. This can damage the control track and cause playback issues.
May 09, 2009 | Sony SLV-D380P DVD Player/VCR
Panasonic NV-V8000 no apparent power ,fails to switch on
Check all the small size capacitors on the power board (switching ps). There is a small capacitor that will need to be replaced sooner or later. (They dry out with age).
Dec 30, 2008 | Panasonic Televison & Video
Unit wont stay powered up
Check for overheating. Place the unit in a large plastic bag and place it in the refrigerator for 1/2 hour. Don't allow condensation to appear on the unit before powering it up, the heat will evaporate any potential condensation. Put moisture absorber or rice in a paper bag in the plastic bag for safety to absorb any moisture. Then power up. If still inoperative check for DC or AC voltage on speaker connectors. If one side is different, or if DC appears on the outputs, audio output may be shorted. See if plugging in headphones stops the problem, some units disable the audio outputs with headphones plugged in.
Nov 30, 2007 | Yamaha DVR-S200 DVD Player
Magellan NAV6510 GPS Receiver Logo
15 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
