Question about Beckett Corporation Beckett Professional Pond Pump, 5000 gph
I need an impeller for a m400aul fountain pump
All of the blades broke off the impeller and I need to replace the impeller and I can't find one
We purchased a mushroom fountain from canadian tire and need a replacement submersible fountain pump pt300-70 can you supply the pump or advise where we can get one?
fixya site doesn't sell anything
most fountain pumps can be bought from nursery supplies , quality hard ware retailers and some irrigation pump and parts retailers
take your pump along as a sample to get the correct voltage and pump capacity
most are a simple impeller running on a plastic shaft and they fail because moss, weed , hair etc wrap around the shaft and jam the impeller movement
Apr 29, 2017 | Garden
Need impeller
Try: http://www.ebay.com/itm/115-VAC-75-GPH-P60-SUBMERSIBLE-FOUNTAIN-PUMP-2-1253-/380224882001
You can get the impeller with a spare motor for less then $20.00. Your local Low's store may have one in stock.
Aug 04, 2013 | Cal Pump Cal Fountain Pump P-60
Waterfall pump hums but won't pump
this sure sounds if the impeller is blocked and not being able to turn ,Dont let it run this way , can dammage motor of pump , remove intake cover (unplugged) and wash out with garden hose real well , see if impeller (black plastic blade) can turn with your finger (unplugged) , should move easy ! this might be an indacation of need for a filter on pump inlet !!!
Oct 14, 2012 | Little Giant Submersible Fountain Pump
Impeller shaft broke at impeller. moytor started to make loud noise . removed end of pump to find impeller at bottom of housing.
i have the wsame problem. A new pump will run me 550 I dont think I could replace the impeller shaft
Oct 17, 2010 | RTO AquaScape 4500 GPH Pump
Pondmaster 1200gph pump stopped working. Inside
Sounds like the impeller broke.
Just remove the 4 phillips head screws to remove the housing, then pull the impeller out. When replacing the impeller be sure to have a good grip on it as the magnetic attraction will pull it in pretty hard.
The pump may still be under warranty, if so call the number on this web page: You can also order parts from them.
http://www.dannermfg.com/contact.asp
Jul 08, 2010 | Pondmaster PM 1200gph Mag Pump Plastic...
I want to replace an impeller for a Little Giant submersible pump
This is a plastic impeller on a brass hub. If the impeller is loose it is probally cracked or overheated and melted, ether way you will have to break the impeller off of the hub then you will need to break hub loose from shaft. You can do this by putting pump in a vise and putting a pair of vice grips on hub and giveing them a sharp hit in a counter clockwise direction. you will need to replace the seal and impeller and should check to be sure than you can get these parts before you start.
Aug 24, 2009 | Little Giant Submersible Fountain Pump
Slow to drain
What you should do is get a flashlight, remove the hose from the pump and look into the suction port on the pump. Check for anything clogging the pump. Check the blades on the pump impeller. Make sure that no blades are broken or missing and that the impeller rotates freely. If any blades are missing or broken or if you cannot get the impeller to turn freely, then the pump will need to be replaced. Hope this helped and best wishes.
Aug 15, 2009 | Washing Machines
I'm replacing the impeller and seal assembly on a Hayward 3/4 HP Max-Flo pump as the original impeller broke at the shaft. I had to remove the impeller thread assy. inside the seal by splitting it as there...
First remove seal plate and mounting plate on motor. The front end bell of the motor is alunimun and is probally corroded, you will need to scrape most of this corrosition off the front of motor and then wire brush this clean. A coat of paint will not hurt at this point or coat or coat in a good pool lubricant to stop corrosion in the future. This calcium will build to the point of warpin seal plate and tweaking impeller shaft and it will quite often crack the seal also. As far as reassembly hand tighten only. If the pump has the motor it came with you have to shut the power off at the breaker and carefully use a 3/8 open end wrench to hold the back of the motir shaft. If the motor has been replaced you will need to check with the manifctuer.
Aug 13, 2009 | Hayward 3/4 HP Max-Flo High Performance...
Impeller shaft broke on 1500 pond pump. Can I replace it and where do I get it?
fishmate offers replacement impellers - try water landscape supply, http://www.waterlandscapesupply.com
Jun 23, 2009 | Fish Mate Garden
Beckett Corporation Beckett Professional Pond Pump, 5000 gph Logo
362 people viewed this question
Top Beckett Corporation Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Beckett Corporation Garden Expert? Answer questions, earn points and help others
