Question about Baumatic B604SS Stainless Steel Gas Single Oven
Fan not stopped working
Fan not working
Fan has stopped working in lower oven. Now only works as a conventional oven.
Sounds like you have a either a bad fan motor or the wiring broke or came loose from the fan motor. Sparks indicate a wiring problem at that area or motor burn out.
Mar 30, 2015 | Ovens
I have a fan forced chef classic wall oven and the fan has stopped working....why ould this have happened/
There has several reasons the fan could have stopped working:
-It is possible the fan wiring/connections have become loose or unplugged
-It is possible that the fan motor has worn out or become jammed over time due to debris
-If you recently cleaned your oven, the fan could have stopped working if it came into contact with any caustic oven cleaner.
Hope this helps.
Feb 28, 2011 | Ovens
Fan oven stopped heating
Is the fan working in the oven if not then check if the clock needs resetting.If the fan is working then it is more likely that the ring element around the fan has failed.Check also if the thermostat light comes on,this is an indication it may be ok.
Hope this helps.
May 25, 2010 | Ovens
Cooling fan made loud noises then ovens stopped working.
If the fan is not working you need a new fan, if the fan is working but there is no heat you need a new heating element.
Dec 25, 2009 | DCS Ovens
The fan has stopped working but if I connect it direct to the mains it runs OK 900gdo
After seeing that the fan was OK I replaced the PCB that controls the fan and this fixed the problem.
Before the fan stopped completely I had noticed that it sounded slow.
I got the part from espares but they took forever to deliver it (10 days).
Oct 17, 2009 | Stoves Ovens
Fan stopped working
If it is heating without the fan working, then there is probably something wrong with the fan.
If there is no heat as well as the fan not working, then check that the timer is set to manual and not on auto.
To access the fan and heater, remove the rear panel inside the oven, spin the fan by hand,it should be completely free,
If it is not, then it needs replacing.
Plz rate my solution.
Thanks
Jan 02, 2009 | Belling XOU252 Electric Single Oven
Neff 1861 oven fan stopped working
Fitting new bulb would not cause fan to stop working.
If it is getting hot, then there is something wrong with fan, try spinning fan by hand, it should be free, and continue to spin under it's own momentum.
Hope this helps.
Thanks.
Dec 29, 2008 | Neff B1861 Single circotherm super...
Bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Dec 17, 2008 | Bosch Ovens
Corbero oven fault
The fan oven element may have gone open circuit.....bulbs go so just replace it
Oct 05, 2017 | Electrolux Ovens
Baumatic B604SS Stainless Steel Gas Single Oven Logo
Top Baumatic Ovens Experts
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
