Question about Troy-Bilt Garden
It cuts off when you excelarate but will sit and idle ok
It cuts itself off as if it were running out of gas when you accelerates
  • 143 Answers
SOURCE: Dies when pressing the accelerator
If your chain brake is not engaged, which i am sure you have checked, look at the air breather filter or the exhaust muffler which could be blocked with carbon.
Posted on Jun 09, 2009
  • 3 Answers
SOURCE: Engine will not idle and run when starting in cold weather
Have a mechanic take a look at your throttle position sensor and engine idle sensor. Make him manually adjust them as opposed to just putting in new ones. It may require that you have to have a higher idle than normal. Your underlying cause is going to be that I am sure you have a lot of miles on your engine.
Posted on Jul 20, 2009
motor1258
  • 6674 Answers
SOURCE: 2005 MPV shuts off after I let go of the gas after
I'd pull the "idle air control valve " (located on side of throttle body near front) off, and use some throttle body spray cleaner on it & the port it came out of. Spray pintle (pointed part) good to remove any gunk etc. Re-install, it & try it. if it cures your problem for a while & starts to act up again, replace it.
Posted on Aug 06, 2009
bazzz7071
  • 342 Answers
SOURCE: 2001 yamaha ttr 250, starts, idles ok, bogs at acceleration
Has the bike been stored for any long length of time?
old fuel in the carburetor will turn to a varnish like residue blocking the jets,or possibly water in the carburetor.
Posted on May 03, 2010
Testimonial: "The bike was not stored and was ridden regularly, but it still sounds like it could be the carburetor. Thanks for your insight."
SOURCE: Yamaha 2001 ttr 250. Bogs above half speed, under load
I have the same problems with my 1999 TTR 250, were you able to find out anything?
Walt
goalhawk@hotmail.com
Posted on Aug 07, 2010
Accelerating by itself
check your vacuum hoses for leaks
Sep 22, 2017 | Cars & Trucks
Vw polo 2004 only idle?dont want to excelarate
There should be a code thrown for this problem, the link below is a forum on this problem and what it took to fix.
http://www.vwaudiforum.co.uk/forum/showthread.php/119042-No-Accelerator-pedal-response-engine-sits-at-1200rpm
Jan 12, 2016 | Cars & Trucks
My car jerks, cuts when iddling and switches off when running
To fix the jerking rotate your tires and what do u mean by cuts when idling if it cuts off then there is a chance there is water in your gas tank due to precipitation just go to the gas station and put about a full tank but u need to keep a full tank in it when your not using for a while when I was locked up I couldn't let it idle without turning off so I would just sit in it and barley press the gas until it thought it was ok to let go and it ran good till my starter went out and the switching off you probably need to get a new gas pump line or whatever it's called I forget.
Feb 04, 2014 | Cars & Trucks
My car jerks and cuts off when i excelarate after driving for awhile
Clean or replace the "Idle Air Control Valve" and use injector cleaner in your gas tank...STP super concentrated in the black bottle is proven...Hope this helps.
Jul 12, 2012 | 1997 Buick LeSabre
When the car is driving it cuts back several times, sometimes if idleing it sounds like it may cut off, what would cause that?
This is the LT1 engine that's used in the Corvettes - I have an LT4 Vette from that year, and may be able to give some guidance here. Please answer some questions for me:
Does the cutting off you're talking about (when driving) happen when you hit the accelerator? Can you go really slow and it works ok? Does it idle relatively well, except when you hit the gas a little? What RPM's does it seem to cut off (driving or idle)? How many miles on the car? Do you drive it daily, if not, how long has it been sitting? Is the car garaged? What maintenance have you/previous owners performed in the past?
Answers to these questions will narrow things down considerably...
Jan 24, 2011 | 1996 Chevrolet Impala SS
'07 Triumph Bonneville idles but wont accelerate
What happens when you try to accelerate?
Does the exhaust smell 'weird' when it's idling?
The most likely problem, especially with the bike sitting up during summer, would be gas has gone stale. If the bike sits long enough, the gas will actually turn into a varnish.
Drain the tank, refill with fresh gas, and let it run a while.
Basically, you have to run out whatever gas is between the tank and the cylinders, so the fresh gas can get to the cylinders.
I'd put a box fan blowing on the front of the bike to help keep the ehat down. Blip the throttle after a few inutes. Depending onhow much old gas is 'stored' in the fuel lines and such, it may take 10 or 20 minutes to burn out the old gas. Keep blipping every few minutes, and let it cool down after 20 minutes. Some bikes have short fuel path and clear in 2 minutes at idle, I've seen custom setups that took over an hour.
Sep 27, 2009 | 2007 Triumph Bonneville T100
Jun 08, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Surging
A lot.
Fuel cut off valve
Wire harness
Pump.
Etc..
Jan 25, 2009 | 1995 Mitsubishi Mighty Max
The 2000 mountianeer starts and runs fine but shuts off
CHECK THE COLD START ENRICHMENT VALVE AND OR THE IDLE CONTROL VALVE. I AM ASSUMING THAT YOUR VEHICLE IS FUEL INJECTED. ONE OF THOSE HAVE GONE BAD.
Jan 24, 2009 | 2000 Mercury Mountaineer
Garden Logo
71 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
