Question about Clarion VZ401
Does the tft screen have an auto close option I have auto open set but whats the use of auto open if dosent close
Tft auto open an close
Face book comes up then stoppes wont oppen
What browser are you using? Need to check setting for your Network
If Using Internet Explorer: Go to Tools > Internet Options> Connections Tab> LAN Settings > Try and put check on Automatic Detect Settings> OK > Close the screen. Open again Facebook..If still not working, go back to LAN Settings and remove check mark on all boxes. Try again.
For Firefox: Go to Tools> Options > Advanced> Network > Settings> Select on Auto Detect Proxy Settings for this Network>OK> Close the screen. Open Facebook. If not,go back to choose NO PROXY. Then try again.
Sep 06, 2011 | Facebook Social Network
Performance Teknique ICBM-9472T 10.4 in. Car Monitor
Hey ,, yes it can be fixed, and any eletronic technician can replave the wire or resolder it to repair the problem, if you but friend wishes to try ask him to cut the section of and just resolder the rest or re add a pice and then resolder it.
Jul 17, 2008 | Performance Teknique ICBM-9472T 10.4 in....
Screen resolution is not fitted in down, i am unable to see the taskbar. I have tried more and more to set the screen but its not fitted yet.
hi..
LG W1941S-PF Monitor is a 19" TFT monitor with max resolution of 1366x768. So there should not be any problems with viewing . This monitor incorporates an auto fitting option which will set common resolutions evenly and nicely.
look for a button named "AUTO" on monitor panel and press it. It will fill screen automatically..
Mar 18, 2011 | LG W1941S-PF Monitor
When I open gta sa it comes up white screen then closes help me..
sometime cleo 2/3 dosent work for some people(me) if u have cleo uninstalling it and see if it works.
if u dont have cleo and this problem is happing then try reinstalling gta sa. PS: if u do reinstall gta sa and u have any light modsor anything u might want to back them up.
Aug 18, 2009 | Rockstar Games Grand Theft Auto: San...
Monitor displaying everything horizontally
Some monitors don't give orientation feedback to the video card to auto change the orientation when you move from a horizontal screen to vertical. what you need to do is get to display properties and advanced settings (right click desktop > properties > settings > advanced > video card settings > orientation) - you should find an option to change the orientation of the display - correct it accordingly. if the settings are not being saved after you restart, you need a video driver update - find it on your manufacturers website.
Jan 13, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Screen problem
on monitor u will find the debug option just try for that.
Dec 16, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Black striped down left hand side of display
Hi Danny, you haven't been very clear I will assume you pushed the auto configure on the monitor,
I would go into the menu on the monitor and reset the size of the screen if it has a setting for that 1024x768 should fix the problem
let me know what you find as I have never worked with a hp W19 monitor, if nothing else set the monitor to defaults again in the menu and that may get you back to having normal screens.
L8r
Nov 13, 2008 | HP w19 19" LCD Monitor
Screen retracts, then opens, and retracts, and does not stop
I had that problem too I'll I did was press the reset butoon on my unit and everything resetted but the bypass code, you have to reprogram your stations and the time thats it
Mar 20, 2008 | Jensen's VM9312 Car DVD Player
DUAL XDVD8181 car unit - motorized TFT screen won't come out!
Open it again and check the ribbon cable for cracks, the one that get drag in and out every time it open and close. Because it is a defect for Pioneer too, and Pioneer would replace it free. Goodluck.
Mar 01, 2008 | Dual XDVD8181 Car Video Player
Keeps opening and closing
you can try the following:
With the car off but iginition switch "on" ,press multicontrol until "face auto open"option comes. select "off" and see the result.
or
Press RESET with the iginition "on".
the default setting will be "auto open ".so select it "off".
Dec 03, 2007 | Pioneer DEH-P5800MP CD Player
Clarion VZ401 Logo
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
