Question about Infinity Speakers PS410 Primus 10-Inch 300-Watt Powered Subwoofer
Infinity harman subwoofer ps410 not working
No sound
Why doesn't subwoofer work?
Your nose and eyes should lead you to the faulty part for this, once you get inside the subwoofer. Anything that burns up producing the smell will possibly leave a visual trace. But your nose will lead to the part that smells. Replace it and see what happens!
Nov 26, 2015 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
Surround effect firmware update
I doubt this is a firmware issue, but if you would like to inquire about same, try the Harman Kardon website. If you need further assistance, or would like to inquire about repairing your HK, please visit my website at audioserviceclinic.com, and contact me there. BTW, worked for Harman as technical support for all Harman,JBL and Infinity products. Thank you.
Mar 30, 2014 | Harman Multimedia AVR 145 Receiver
Do i need a satellite cord for this harman kardon to work properly
You shouldnt need a satellite cord. If the HK 12 has parallel L and R inputs and outputs, you should be able to run sound into the sub, and then out to whatever speakers you have. Assuming they are not a part of a sound system, and you are running 2.1 stereo.
Mar 19, 2011 | Harman Kardon HKSUB 12 Subwoofer
How do u hook up the infinity entra sub it has speaker level(input and output) that look like these red and black spots r for spearker wires and then line level input so I connect my music to the rca plugs...
Maybe if you described the setup with exact model numbers for everything involved we might be able to answer with specifics.
You could poke around her for the Entra Manual for YOUR model.
http://manuals.harman.com/INF/Hom/Owner's%20Manual/
What they do NOT explicitly tell you is that the amp in the sub is not for your other speakers running off it's Speaker Level outputs. They're just there as a pass-through if you use Speaker Level from your own amp.
Line Level (RCA) IN to the sub will NOT pass anything out those Speaker level outputs.
Jan 13, 2011 | Infinity Entra Sub Subwoofer
Need to find parts or data sheet for ps-12 subworrer amp or amp replacement
Infinity will sell you the service manual for $20 (I think)
1-800-553-3332 ask for parts or
parts@harman.com
We also sell the complete amp ***'y part# 351648-001 but they are not cheap.
parts@harman.com
Nov 17, 2010 | Infinity PS-12 Subwoofer
I want to build a box for my kappa subs and i need to know what specs would make them sound great. they are goin in my 97 chevy ext cab truck. the box is going to be my back seat also
http://manuals.harman.com/INF/CAR/Boxes%20and%20Parameters/1001dvc.pdf
Not knowing your musical preference, take a look at this spec sheet and pick the sound you'd most like. The bandpass design usually gives the most SPL, but a larger box is probably deeper while still having good volume. Some audio purists say a sealed box sounds the best, subjectively, but the SPL isn't as great.
Nov 08, 2010 | Infinity KAPPA 100.1DVC Car Speaker
Want to use only subwoofer of HK695
The problem is that you need the satallite speakers , they have the volume control on them which thats why you only hear the subwoofer.. yes , i tried other speakers to it and no sound either.So you will need the satellite speakers it come with.. good luck!!
Dec 28, 2008 | Harman Kardon HK695 Computer Speakers
Subwoofer - no sound
Had the same problem when mine first arrived. Unplug and replug the power cord at the back of the woofer. Worked for me!
May 16, 2007 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
Infinity Speakers PS410 Primus 10-Inch 300-Watt Powered Subwoofer Logo
100 people viewed this question
Top Infinity Speakers Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Infinity Speakers Audio Player and Recorder Expert? Answer questions, earn points and help others
