Question about Frigidaire Washing Machines
Siemens s1042 Door locked
My siemens siwamat xlp 1340 shows a lock key and wont operate
that means that the door catch is not operating properly you may need to replace the door lock yourself or call the washing machine engineer for a quote eric
Jan 13, 2018 | Siemens Washing Machines
I can't get the child lock to deactivate on my Seimens S12-38 washing machine. Anybody got a solution?
Deactivate child lock siemens washing machine S12-74 ...
www.fixya.com/.../t15773878-deactivate_child_lock_siemens_washing
Jan 10, 2013 - deactivate child lock siemens washing machine S12-74 - SiemensWashing ... -Press and hold the option down touch button for 5 seconds or until you seethe magic message 'Child lock released'. ... I can`t deactivate the childlock ... I CANTDEACTIVATE THE CHILD LOCK AFTER WASHING MY CLOTHES.
How to unlock washing machine door for siemens s12.38 ...
www.fixya.com/.../t11409270-unlock_washing_machine_door_siemens
Dec 21, 2015 | Washing Machines
How to open front door Siemens iQ500 washing machine?
if the door is locked shut the inter lock needs replaced u will have to take lid off
Apr 26, 2015 | Siemens Washing Machines
My Siemens Extraclasse 1300 Washer/dryer just stopped as though no power. Fuse is ok.
check door inter lock by putting mech on leave 4 five mins go and try to open door imeditlaty if if opens straight away its the inter lock
Feb 22, 2015 | Siemens Washing Machines
Door of Washing machine doesnot opened
the door interlock has failed
other then try to leave it off and struggle with the door
you need sometimes to release it from behind
not easy sometime with some machines
the replace the door lock interlock catch
it will work fine then
Sep 19, 2014 | Siemens Washing Machines
Siemens washer dryer 1060
its either parental lock or
the door closed detect has failed
so many fail
today ive answered the same thing more than 10 times
you need to check out your home insurance and warranty etc
try get the repair free
if this fails just look for the door lock switch for it
and DIY
Sep 01, 2014 | Siemens Washing Machines
Error code E13
This error appears to be linked to the door lock but is not described in the user manual.
To find replacement door lock refer to item 202 on the diagrams at this site
http://www.siemens-home.com/ie/store/spareparts/Automaticwasherdryer/WK14D320GB/01
Apr 26, 2014 | Siemens WK14D320GB Integrated Washer...
Siemens e12 46
This
is either a fault with door lock or the pecker unit on the door this video
might help
Jul 22, 2013 | Washing Machines
Broke handle off of siemens TOP WD1200 champion, the settings are all in chinese and my clothes are locked inside. help?
This is a common and easily fixed problem. The door should NOT be opened after the wash is completed. You have to wait for AT LEAST 2 minutes to try the door, do not use force. There is a built in mechanism for most front loaders to delay the door opening, so be patient.
If you have used force you have already damaged the door lock, so replace. You are lucky if the door can be opened after the lock sign goes off - otherwise you just have to change the door lock.
Click if helped.
Mar 30, 2013 | Siemens Washing Machines
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
