Question about Sony Prs-t1 Pearl Red 6" Ebook Reader With Wi-fi
Sony reader repair
Stops working
Reader suddenly went beserk, lots of activity as though I were pushing buttons to change pages, etc. and then it stopped working properly; some part of the screen shows correctly while most of screen is...
separtdifge3,
Probably a charge issue, try this:
1. Connect the reader to the computer for 15 minutes (make sure there is a red steady light)
2. Disconnect the reader and press the reset at the bottom
3. slide the power switch to turn it on
4. If the problem persist you will need to do a hard reset
5. If after a hard reset the issue is not resolve problably you will need to contact sony to get it repaires =(
eBookBoy
http://digialreader.freeforums.org
Jul 01, 2011 | Sony Reader Touch PRS-600
My Ps3 has jst stopped Playing or Reading any disk i put into it...It will do everything else like plat demos and all bu jst wont pplay any disks. What is Wrong does anybody out their Know?????
The laser reader inside the machine isn't working, you need to have the reader replaced. Go to the store where you purchased the console and explain the problem, they will send it to get it repaired or give you a number to call; like Sony. If you explain the problem to them they will ask you to send them the playstation, it will be repaired free of charge, so long as you have a warranty :)
Apr 10, 2010 | Sony Playstation 3 (PS3) Console
My battery drains within 1 day on my sony prs-600.
1. Connect the Reader to a different USB port of the Computer. 2. Connect the Reader directly to the USB port of the Computer; dont use any USB hub or adaptor to connect the Readr to the Comp. 3. Disconnect the Reader and then press the RESET button. 4. Try connecting the Reader to a different Computer to check whether the USB port of the Computer is working properly. 5. If the issue still persists, service may be required. Follow the below link to initiate the repair: http://eservice.sony.com/
Jan 28, 2010 | Sony Reader Touch PRS-600
I purchased a used Sony PRS 700. It is locked in
If the Demo mode is appearing on the Reader and you're not able to do anything in the Reader, it seems that there is an internal issue occurred with the Reader. However, since you've already performed soft reset and hard reset with the Reader, the service of the Reader is the only available options. The PRS700 Reader is covered under the Sony exchange program. This exchange is for the same or comparable model. Please follow the below mentioned link to get it repaired or exchanged from Sony:
Jan 12, 2010 | Sony E-reader Portable E-book MP3 Player
Sony prs505 ebook reader screen has blank area
Since the Reader was dropped, there might be some internal physical damage occurred. And it requires service., Contact urmanufacturer to get it serviced. If you located in U.S., the Reader is covered under a exchange program and yoiu will get a similar or same model. You can get more information about the exchange program at: http://eservice.sony.com
Jan 06, 2010 | Sony E-reader Portable E-book MP3 Player
My sony reader has stopped working. When I click on the icon, a message says that it has stopped working. Then a message appears that says a problem has caused the sony reader to stop working and I will be...
Just spent 2.5 hours figuring on this out with a Mac. Sony customer support was TOTALLY worthless. Finally figured out my PRS-505 firmware was not up to date. This is a problem because there is no indication of a firmware update on the Mac support page since you cannot update the firmware using a Mac. Out of desperation I checked the Windows updates and there it was - the firmware update that was needed to make this work. I took a chance and updated it on Windows 7 using Parallels and it FINALLY WORKS. Days like this I wonder why the hell I gave up paper books. Here hoping that Apple can make a decent tablet so Mac users are not 2nd class citizens in the eBook world. Unh. What a way to spend a Saturday afternoon.
Dec 29, 2009 | Sony Reader Pocket PRS-300
Cant get the reader library installed on my computer
Perform tyhe troubleshooting steps listed on the page to get the issue resolved: http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1003504
Dec 27, 2009 | Sony Reader Pocket PRS-300
Just recd my new sony prs 300 and have downloaded sony digital reader library program. Im running vista on dell insperion350.Every time i open up the reader library and try to go to online store i get the...
This issue may be caused by the Data Execution Prevention feature in the Windows Vista operating system or if certain folders used by the Reader Library software are corrupt. Add the Reader Library to the Data Execution Prevention feature. To add the Reader Library software to Data Execution Prevention,
Please click here to get the steps.
Dec 11, 2009 | Sony Reader Pocket PRS-300
The Sony PRS-600 Reader has a well-known screen glare problem. Are there any fixes for this problem? I would think it wouldn't be too hard to just replace the screen's surface with something that works...
The PRS600 Reader doesn't have any settings to increase the brightness and contrast. Howevver, this is not a well-known issue with the PRS600 Reader. You may try resetting the Reader by pressing the RESET button. If the issue still persists, unfortunately the Reader may require service. Please follow the link to get it repaired: http://eservice.sony.com
Nov 09, 2009 | Sony Reader Touch PRS-600
The LCD screen is broken...where do I go to get it
Actually, no body can repair the Sony Reader, as this product is newly launched. Hwever, you can check your local telephone directory to check whether any service person can repair it. But, it's always recommended to repair the Sony Reader at their Service Center, unless it may damage if any third party service man try to repair. Here are some tips to get it repaired by the third partyservice person:
The Service person should have the service manual of the Reader.
The Service person should have the prior knowledge to repair the Sony Reader.
The Service person should be a certified repair person.
Oct 03, 2009 | Sony E-reader Portable E-book MP3 Player
Sony Prs-t1 Pearl Red 6" Ebook Reader With Wi-fi Logo
26 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
