Question about Health & Beauty
Fingers sticking togetherwhen working
Index and centre finger when doing manual work such as painting or sanding
    Problem Solver:
  • 79 Answers
Trigger Finger Treatment In Phoenix
Dr. Michael Fitzmaurice, hand doctor in phoenix provides trigger finger treatment in his Fitzmaurice institute. Call (480)719-4750 for tenosynovitis treatment.
Know more here: Trigger Finger Surgery Tenosynovitis Phoenix Fitz Hand
Posted on Sep 18, 2015
  • 44 Answers
I'm assuming that what you're trying to describe is that the joints in your fingers feel like they are locking in a bent position after doing work. If this is so, it is very likely that what you're experiencing is trigger finger. The tendons that cause your fingers to be able to bend run through small openings in the bone. The tendons can develop small nodules or bumps on them that are larger than the opening the tendon runs through. When you bend your fingers the nodule passes through easily, but is difficult to get it back through in order to straighten out your fingers. This problem can become worse and very painful without treatment or care.
Posted on Mar 24, 2014
How do I paint my finger nails perfectly?
use cellotape or inch tape wrap around nails and color the nails and peel off simple and cheap
Feb 23, 2015 | Health & Beauty
Dip stick does not show oil even when full
If you have new oil and know for sure that there is sufficient oil in the sump this is not a new problem as new oil has little refelective quality and is almost impossible to see on the metal dip stick as compared to oil that has done some work. Assuming that you are looking at the right dip stick and not the tranny one. I find that by drying off the metal and painting it with white paint ( oil Resistant ) past the full mark will help. Other than that run you finger down the stick until you feel the oil
Feb 18, 2013 | Cars & Trucks
Is there a paint available that can cover-up the rust ring around the center, that holds the glass turning plate?
try a paint pen used on cars or finger nail enamel :)
1st clean the area sand off rusty bits
Jul 28, 2012 | Microwave Ovens
Fingerprint reader working but not showing image
From the description it is a software problem, If you were sticking things in the scanner bar that would not help and it will prevent the laptop from working.
Mar 30, 2012 | HP Compaq 6910p Notebook PC PC Notebook
We have an older knemore Mod 11?713400s/washer and
Clean the old paint surface with TSP cleaner, then sand the surface lightly with ~400 grit wet or dry sandpaper (wet--dip in bucket of warm water often while sanding and sand carefully in any corners). Cut a 1/4-paper-length strip from a full sheet and fold twice into a 1/3-width square. Sand using just your fingers to hold the paper--no sanding block. Wash with clean hot water, and dry with a clean cloth (no paper towels). Mask off the area you don't want painted, then using an epoxy-type paint spray can, spray the area evenly and lightly for the first coat. Follow can directions for the second coat. Remove the masking tape and paper shortly after the second coat--peel the paper and tape AWAY from the new paint at all points and don't let any of it get stuck in the new paint before it drys. If the second coat was applied fully wet overall without running, it should turn out very well. Good luck!
Aug 08, 2009 | Dishwashers
My Dyson will not lock into the stand position
- Stand behind the vacuum cleaner
- Remove the AI PIPE (it has two purple buttons that you push together to lift it up and out - it looks like a Tuba)
- Lay the handle down
- Stick your index finger and middle finger into the vacant AI Pipe Hole (the square hole)
- Reach over with your thumb and press the black button in front of the square hole
- WHilst pushing the black button, lift your index finger and your middle finger and move the gray plastic piece up (lift the square holse basically)
- Remove your fingers from the square hole
- Lift the handle and stand your machine back upright again
- Place the AI Pipe back into the square hole
Jul 16, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
How do I open my gucci watch to change batteries?
Get a #0 1.6mm precision Phillps screwdriver (these are brittle) or similarly strong, thin piece of steel.
Hold the watch upside-down across your index finger while gripping the straps tightly between your index finger and thumb on one side, and index finger and middle finger on the other (ie. squeeze the strap around your index finger).
On the underside of the watch, stick the tip of the screwdriver under a square slot where the watchband is connected at an angle perpendicular to the strap. Firmly pry upwards on the cover on one side, then the other, until the cover pops off.
The battery is a Renata 379.
To put the cover back on, align the square slots precisely with the ends of the straps (keep these out straight), then firmly push the cover straight down until it "snaps" shut.
Dec 31, 2007 | Watches
Hi patrisegu
I am guessing that you do not in fact have a W50 model Sony camera as the fault you are describing sound like one of the older models. The problem that you have, is caused by the CCD imager inside the camera. A quick check to see if it is a loose connection to the CCD or in fact a CCD failure is to lightly squeeze the camera between your thumb and index finger. With your thumb being just below the LCD ( careful don`t break the screen.) and your index finger just below the lens unit. If you see any improvement there is a loose connection and it should be quite cheap to have it repaired. If nothing happens, the CCD is faulty and you might even be-able to get it fixed for FREE in some countries if you take it to your local Sony repair centre.
Good luck
Dawiem
Oct 24, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Health & Beauty Logo
162 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
