Question about Aiwa Audio Players & Recorders
I have a Aiwa NSX-V50. The belts on the cassette player have broken. Where can I buy new belts for the cassette player.
I have a Aiwa NSV-V50. The belts have broken on the Cassette player. Where can I buy new belts
3 Suggested Answers
Grubhead
  • 5455 Answers
SOURCE: i have a nsx-9000 cassette deck will not play.
Make a note of how the belt fits, then remove it and measure the diameter. Then buy a replacement, belts do go bad from time to time, so a new one might cure the problem. Put the diameter size (to the nearest mm result, IE: 50 or 55mm, not 52mm! Into google and "cassette belt" and you should find one for the job.
Posted on Feb 27, 2010
  • 7 Answers
SOURCE: Aiwa NSX-V70 Cassette deck Belt?
u can get from ebay.de website many type belts for sepcaly aiwa nsx seriess,all total cost 25 euro
Posted on Oct 10, 2012
Only one spindle turns on cassette player
It is probably a loose or broken belt. I do not know the unit so this is just a starting point.
Aug 10, 2014 | Aiwa Audio Players & Recorders
I need the three cassette drive belts
IF you can take the existing belts and measure them then you can order generic replacement on this site
http://www.studiosoundelectronics.com/cassette.htm
Aug 30, 2011 | Aiwa NSX-A115 Shelf System
I have a nsx-9000 cassette deck will not play.
Feb 26, 2010 | Aiwa Audio Players & Recorders
Aiwa NSX-V50 I took it appart and did not mark the gears on the cd tray,,,please help.
on the gears, there should be a "top dead center" mark. usually a small circle or a hole that matches up on both when it's at the normal closed position. hope that helps.
Dec 14, 2009 | Aiwa Audio Players & Recorders
Have Aiwa NSX-V9090 Stereo with jammed cassette. I removed the cassette; however the system still thinks it's in there? When I power up the system it tries to play the tape the stops. I am not able to load...
Check with a small torch, to ensure that there is no tape broken arround the pinch roller or head, if there was no tape broken away, between the pinch roller and the cassette head there is a white cassette bar, this may have become bent.
Aug 08, 2009 | Aiwa HS-TX426 Personal Cassette Player
Tape players do not operate
Sounds like the belt is slipping or broken. You should first listen with your ear near the cassette door to see if the motor trys to work. Many units use the main belt to work the lift mech. for the heads, If that doesnt have enough grip the motor will spin(Which you can hear lightly) and the unit does nothing.
Jul 20, 2009 | Aiwa NSX-A777 Shelf System
Aiwa NSX-V70 Cassette Deck Belt Replacement
Mark
try www.partstore.com I think you can get what you need there!
Please rate my response!Thanks!
Jan 15, 2009 | Audio Players & Recorders
Cassette door stuck closed
Firstly: do not think about forcing the cassette door! Look inside the unit. You need to hand rotate the capstan flywheel a bit,( a large-ish metal disc attached to the motor via a rubber drive belt.)That should release the powered deck mechanism and allow ejection. Then buy a new drive belt , so that problem does not recurr. Good Luck
Nov 02, 2005 | Aiwa NSX-A115 Shelf System
46 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
