Question about LG LD450EAL 45 Pint Dehumidifier
No power indicated
Was turned off for 5months now it will not start it shows no codes but clicks when plug in
My frigidaire dehumidifier fad704dud does not turn on when plugged in
Good Morning Robert,
I understand your Frigidaire dehumidifier, model# FAD704DUD, does not turn on when it is plugged in. I also see that the display lights up briefly and there are no error codes. Your appliance is designed to operate between 41 degrees F (5 degrees C), and 96 degrees F (35 degrees C). It will not work properly if the temperature is out of this temperature range, or the performance of the unit will fall greatly. The "Compressor" circuit has an automatic 3 minute time delayed start if your dehumidifier is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping. Make sure the tank is fitted correctly otherwise your appliance will not turn on. If you are still having trouble, you can contact your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Frigidaire Dehumidifiers
"bucket full" indicator on - running a hose
Since you have had 2 seemingly unrelated symptoms it is almost sure you have had a power board failure. If you post back with the complete model number we will try to check everything and see what we can come up with.
Thanks/Mike
Oct 25, 2007 | Kenmore 54701 Dehumidifier
How do I get it to work again.
Power supply failed. You need to replace it.
Jan 17, 2014 | Kaz Hfd-130 Enviracare Ifd Air Purifier...
My dehumidifier is showing an E2 code on it. It is a brand new haier, can you help me out with this problem?
E2 Code indicates a Sensor Error automatic shutdown. To find out which sensor it is you will have to call Haier Customer Support 1-877-337-363.
In the meantime, turn the unit OFF & unplug it for 15 minutes. Then plug the unit back in and turn ON. ON. Hopefully the unit reset itself and reverted back to the original factory settings. And you can set te humidity extraction level where you desire. If the error code reappears, definitely contact Haier, as youtr unit is still under warranty.
Jul 18, 2011 | Haier 45-Pint Dehumidifier
How do you know if it is on?
Assuming that the unit is plugged in to an outlet that has power, press the ON button and a green light should come ON. That will indicate the unit is getting power and is ready to function. If however, you have the humidity level set to high and it's equal to or higher than the humidity level in your home, the unit's compressor and fan will not turn ON and run. Keep in mind, the humidity level, whether it's and LCD readout screen or just a minimum and high setting, that's not the amount of humidity that the unit will remove. It's what it will maintain. So, setting it as low as possible, should cause the unit to start functioning.
If it doesn't start, check the water collection bucket, to be sure that it's installed properly and is making contact with the safety trigger switch. If it's not making contact, the unit will not turn ON.
Hope this info helped you. Please let me know. Thanks.
May 13, 2011 | Amana D545M Dehumidifier
I have cleaned the filter that is located in the front; however it still won't turn on, what could be wrong? thank you
If you're not getting any indicator lights, check the receptacle that it's plugged into. Is their power to it? If not, the circuit breaker in your home's circuit breaker panel may have been tripped. Or the outlet itself may be faulty (loose wire, poor connection, etc). If the indicator lights are working, but the compressor is not, turn the Master ON/OFF switch on the unit to OFF and wait 10 minutes before plugging it back in. This will give the electronics time to reset themselves.
Hopefully, the above will solve you problem.
Mar 24, 2011 | LG LHD659EBL Dehumidifier
Dehumidifier not cycling on
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier2_bing.gif Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Apr 08, 2010 | LG LD40E Dehumidifier
01% humidity
When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
The compressor is located in the rear bottom on the right side looking at the machine. After you press the start button and the blower fan comes on, bend over near the back of the unit and listen for the "click".
Sep 06, 2008 | Kenmore 54501 Dehumidifier
M7DH45B2A Dehumidifier
The fall may have knocked out some wiring -- open the unit (remove back panel, then remove front by taking out screws inside) and see if any of the cables to the front panel or control board came out.
Jun 20, 2008 | Maytag M7DH45B2A Dehumidifier
LG LD450EAL 45 Pint Dehumidifier Logo
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
