Question about Jerdon Deluxe Lighted Makeup Mirror JGL9W
Lights out in jgl10w
Doesn't light ups
The dash lights doesn't work
got to take the dash apart and remove the cluster and their lights attach to it.replace the blubs and it schould light up.
Jan 27, 2013 | Office Equipment & Supplies
What's your problem?back up lights on a 2002 chevy silverado 2500 HD doesn't work, i have checked the bulbs and fuses, they are good ,,, how do i fix them?
disconect the reverse light switch wires from the gearbox & bridge. If the lights come on it is a faulty switch.
Oct 12, 2012 | Cars & Trucks
1988 Trans Am will not start when ignition is turned all the way.
Take a test light to the small wire on the starter and have someone turn it to the start position. If the light lights up and the engine doesn't turn over, I would suspect the starter itself. If the test light doesn't light, try it in neutral and repeat test. If it still doesn't light up, it may be the PRNDL switch or the ignition switch itself.
Sep 22, 2012 | 1988 Pontiac Firebird
Lights wont come on dashboard
Two different problems. The most likely cause of the dash lights is a faulty headlamp switch. Your issue is a common complaint. The radio is another problem entirely. I would need more information before I could attempt any answer at that.
Dec 25, 2011 | 2002 Chevrolet Impala
I have a HP Pavilion Slimline s3700y that doesn't always boot. Power is getting to the computer; the light on the back lights up as well as the lights on the front. However, power doesn't seem to...
If you saying "doesn't always boot", most common would be motherboard...
If your motherboard still beeps, then probably some other components has the problem like RAM, GPU card etc., depends on your motherboard.
Hope that give an idea...
Jul 11, 2011 | HP Pavilion Slimline s3700y Desktop,...
Jerdon Deluxe Lighted Makeup Mirror JGL9W Logo
91 people viewed this question
Top Jerdon Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Jerdon Health and Beauty Expert? Answer questions, earn points and help others
