Question about Sunbeam Home
Replacement cord for sunbeam heated throw
Need a replacement cord N85AP/E23623F for a heated throw
I am looking for a replacement for 1 of the controls for my heated mattress pad. Where can I find 1?
www.sunbeam.com/.../bedding/controls/bedding-contr...
Sunbeam ProductsHow do dual controls work? The dual ... What if my control does not regulate my side of the warming product? ... Where can I purchase replacement controls?
Finding Replacement Cords and Controls for an Electric ...
www.thriftyfun.com/Finding-Replacement-Cords-and-Controls-for-an-El...
... blanket. Finding a replacement cord or a control for an electric blanket can be difficult. ... My blanket was under warranty and I got one for free. If yours is out of ...
Finding Replacement Controls for a Heated Mattress Pad ...
www.thriftyfun.com/Finding-Replacement-Controls-for-a-Heated-Mattre...
This is a guide about finding replacement controls for a heated mattress pad. It can be very frustrating to find replacement ... Read all 1 Answer ... Where can I findreplacement controllers for my Living Quarters heated mattress pad? By Steve.
Replacement Controls for a Sealy Electric Blanket ' ThriftyFun
Dec 07, 2015 | Sealy Heated Queen Size Mattress Pad - -
I want to know if my throw is under warranty. I think I probably registered it as a gift, probably two years ago, a Christmas gift. Serial #D105VT07176010612B86112.
Hi Judith
your heated throw has a 5 year warranty! Warranty is covered on this page, specs are on the bottom link.
http://www.sunbeam.ca/en_CA/service-and-support/product-support/product-faqs/bedding/warranty/bedding-warranty-faq.html
Sunbeam Velvet Plush Heated Throw Mushroom Sunbeam Canada TSV8WS R772 26A50
Dec 02, 2015 | Sunbeam Fleece Throw Electric Heated...
E on controlls
If you have a digital control, it is designed to flash "E" on the display to notify you that a problem may have been discovered. Gradient controls and warming throw controls use a blinking indicator light for this purpose.
Follow the instructions on the flag tag to reset the control or follow the steps below.
  • Unplug the system from wall outlet.
  • Check that the control is well connected to the module.
  • Plug the power cord into the wall outlet.
  • Set the control to "on".
If the system still does not operate, disconnect the power cord and contact sunbeam
Sites sunbeam Site
Jan 11, 2015 | Sunbeam Twin Heated Blanket Navy Blue...
Sunbeam Heating Pad
You can try to order a replacement through the company you originally bought the set from. If it is fairly new, the warranty may still be in effect. My sister goes through http://www.pioneercomfort.com and has had good results, you could try there.
Jan 17, 2014 | Sunbeam Heating & Cooling
I wish to replace or buy a new control for my Automatic Heated Throw. The P.N. number is: 105190-000. Please advise. jaclapp@gmail.com
I'm sorry, but I'm confused! This question references grill SG7621sp but mentions the Heat Throw, the only reference I can find that involves most of your information is a Sunbeam "electric blanket" item. Can you help me narrow down the search parameters?
Jan 10, 2013 | Sunbeam SG7621SP Grill
Iron cord twisted and my husband says dangerous. Can this be fixed as iron is otherwise OK?
If there are bare As in the copper is showing wires then it IS dangerous. If it is just the wires twisted then just straighten it out the best possible and you will be okay.If the wires are frayed to the point of the copper showing then you need to have the cord replaced. However, unless this is a fancy iron you will be better off throwing it out and then buying a new one rather then paying the bucks you will need to to have the cord replaced...
heatman101
Oct 04, 2010 | Sunbeam Microwave Ovens
New heated mattress pad won't warm up. Controls keep blinking.
i've lost my control for a king size electric blanket. it had dual control-can u tell me where i can get one and the cost. thx
Dec 13, 2008 | Sunbeam SG7621SP Grill
Sunbeam 4267-000 not turning on just blinking red
"FF" or a blinking light will display meaning “Fault Found”. The “fault” is in the amount of power available to the blanket, mattress pad or throw.
There are several causes to this problem:
1. Bedding product is plugged into an extension cord, surge protector, power strip, or not plugged into a direct wall outlet.
2. Bedding product wasn't plugged in properly.
To FIX this problem, do the following to reset your bedding product:
1. Unplug the power cord from the electrical connection.
2. Unplug the cord from the actual bedding product itself.
3. Re-plug the cord into the bedding product. Make sure the connection is secure and complete.
4. Re-insert power cord back into a wall outlet.
If the 4 steps above are not followed in order, the bedding product will not properly reset.
Dec 08, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
Home Logo
78 people viewed this question
Top Sunbeam Home Experts
topcat7736
Level 1 Expert
Andrew Taylor
Andrew Taylor
rhodesworks
Are you a Sunbeam Home Expert? Answer questions, earn points and help others
