Question about Canon P23-DHV Calculator
How load paper monroe 2805 adding machine
Where feed key
3 Suggested Answers
SOURCE: Paper feed problem
i disconnected turned upside down and started shaking it and believe it or not the roller starting working it prints fine!
Posted on May 11, 2008
solofixya
  • 34 Answers
SOURCE: paper won't feed in
Look down into where the paper goes into printer in the back, usually there is something stuck inside autosheet feeder.
Posted on Nov 11, 2008
How do I load paper?
I have a casion hr-100tm calculator and found the easy way to load a new roll of paper. Take a 3x5 index card and cut it on 45 degree angle, then with angle on the right of the machine feet it into the machine pushing it as you go. Once it begins to feed so you can pull on it, then take other end of card, scotch tape to new roll of adding machine tape. As you feed the card through the roll of paper foillows. Once it has fed into machine cut off 3 x5 card. Easy.
The problem is that all rolls of machine paper are not equal and the thinner paper doesn't want to feed. This way it works for any type. Hope it hellps.
Oct 02, 2015 | Casio FR-2650A Calculator
Loading paper feed
really need more information. but look for a little door on the back/ bottom and check for a paper jam. do you hear the roller motor trying to pull the paper?
Apr 21, 2014 | Royal Ezvue 550hd Adding Machine
Loading paper in a sharp el-1750v adding machine
i can tell you how in the back there is a **** on lower back slide paper in and push the button that looks like an arrow with ripped paper an it should feed
Jan 19, 2012 | Office Equipment & Supplies
We have messages in the memory but keep getting message to 'load Paper' there is paper in the machine . I hvae tried putting fresh paper in , but it comes up with the same load paper message?
first thing is you have to insert new A4 sheet in to the rec/paper tray.then press the STOP key.after machine try to feed the paper in to the printer unit and you can get print.( if the machine cant feet the paper,the machine have some paper feeding problem and you have to get technical support to solve this problem)
Mar 07, 2011 | Canon L220 Plain Paper Laser Fax
How do you load the adding machine paper on this calulator #P23-DHV Cannon
Paper loads into slot at end of machine. After inserting end into the slot (at rear, near power cord connection) press feed button until paper advance thru top.
Jul 05, 2010 | Canon P23-DHV Calculator
Loading paper into the Canon P170-DH Desktop adding machine
Rather than try to describe the process in words ("lift up the arm, then feed the paper through..."), I'll point you at the illustrated instructions in the manual at the manufacturer's web site: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=349&modelid=9785
Mar 03, 2010 | Canon P170-DH Calculator
I can't figure out how to load the paper into the Sharp EL1701v!!
Well depending on the model ther is often a small slot on the back of the calculator where the paper would feed through, you would push the paper in then press the feed key, which is often on the top left corner of the key pad. If you still cannot get the paper to load then call us at 1-800-BESHARP. or 1-800-237-4277.
Jun 30, 2009 | Sharp Office Equipment & Supplies
Canon P23-DHV Calculator Logo
13 people viewed this question
old marine
old marine
