Question about Sirius Starmate ST2 Satellite Radio Receiver
Broken audio jack
Audio jack broke off inside of receiver
  • 3 Answers
Replace the jack or the circuit card with parts off ebay. see the two cards pictured in my solution at this link.
My ST2 just died Still picks up all the channels fine but just doesn...
Posted on Apr 27, 2014
Broken connector in subwoofer connection on receiver
The only thing you do is to open your receivers,then locate the output connector if you see the female RCA jack ,then push it out the broken piece ,that's it
Jul 27, 2008 | Audio Players & Recorders
Audio input jack for headphone component broke off need to find new input and how to replace
No way to do that unless you can figure out a way to remove the part. The contacts inside that plug determine where the sound goes. No way to turn it off unless you remove the broken part. If you feel confident enough, remove the back of the TV and remove the broken piece from the jack.
Mar 02, 2014 | LG 32LD350 32 in. LCD TV
My speaker jack broke off inside my audio input in the back of the computer. I want to use the thermaltake case's front usb and audio out/mic in jacks, but they don't seem to get power or work. My drivers...
> Have you removed the broken jack from the rear end of the pc ?
> Are you trying to use the audio ports on the front panel ?
> if you are trying to use the audio port on the front panel you will first need to remove the piece of the broken jack stuck in the rear port - cos you can take an audio out line either from the front OR the rear any one
Oct 22, 2013 | Thermaltake Mid-Tower VL10001W2Z Element G...
My antenna jack on a marantz sr5500 broke. how do i replace it and where can i find one
If you still have the connector and if your Tuners board is not broken, you can solder it back on if you are careful. If not replace the whole tuner.
Part# 90M-AV000350R
Jun 21, 2012 | Marantz SR5500 Receiver
The headphone jack broke off inside my audio port. Is there a way to get it out?
You can use a thin needle type pointer with a bend at the end like a puller to pull out the broken piece inside the jack socket.
Since there is a small hole in the jack this can be made use to hook and pull out and it will engage to come out.
Also you can hold down the PC to tap and assist while you pull out using the tool.
Aug 24, 2011 | HP ProBook 4510s FM849UT Notebook
HDMI out jack physically broken on my rx-v1900. Fixable?
An audio repair shop should be able to get a replacement connector and swap it for you. I doubt that the part is available from Yamaha (and it would be pricy if it was). The connector shouldbe available generically. Digikey or Mouser should be a good source.
Dan
Nov 18, 2009 | Yamaha RX-V1900 Receiver
Problems with Magellan Maestro? 4040 GPS power connection
I also have the same problem - the yellow power jack has broken connections. I fixed it by soldering it back. In my unit, the connection pads under the external power jack were intact and I was able to solder the jack easily. The audio out jack nearby has also come-off the PC board, along with the pads. I am not able to re-solder these back. Since the audio jack is part of the speaker circuit I have lost the text-to-speech function!
Hope you are able to fix yours.
Dec 17, 2008 | Magellan Maestro 4040 GPS Receiver
Broken Female audio plug
take a 1-1/2" safety pin, straighten it a bit, heat the tip, stick it inside the broken pin, let it cool then work it out w/the broken pin attached. I had the same problem & this worked.
Nov 05, 2008 | Onkyo Audio Players & Recorders
Sirius Starmate ST2 Satellite Radio Receiver Logo
98 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
