Question about Home
How do u clean filter
I've unscrews it but it seems to be stuck ?
  • 717 Answers
Spa filters are put into a spa one of two ways. They have threads on the underside of the filter element and thread into place by unthreading it or the filter is simply pressed into place and to remove it you just pull up. It can be fairly heavy either way because all those pleats hold quite a bit of water when initially pulling it out of the water.
Rod
US Parts Center
888-521-6183
Posted on Apr 08, 2014
How do I open the filter cover on my machine .it came with the house. it seems stuck solid.please help regardsmary
Assume its a washing machine. If stuck solid it is probably scaled up. I had this problem,and managed to unscrew it using a plumbers wrench. You will hear a crack as the scale breaks up, and can clean thoroughly once removed. I replaced my filter, only 3 quid on ebay. Now cleaning it monthly !
Mar 03, 2015 | Washing Machines
I do not seem to be able to undo the filter on my whirlpool washing machine, does it just unscrew, or unscrew and pull. I can unscrew it, but it does not pull out.
Hi, Unplug the machine. Take a cake pan and put it under the handle for the filter. Unscrew counterclockwise slowly. Water will start to come out. When pan is partially full, retighten filter and dump water. Repeat until no more water comes out. Then completely unscrew filter and pull out and clean. Hope this helps.
Jan 17, 2011 | Whirlpool AWZ412 Front Load Washer
I have a Zanussi ZFW1221W machine and I suspect that the pump impeller/filter is clogged as it has never been cleaned and out and the machine started to refuse to spin and now won't drain. I have followed...
It should come out completely to clean it.
There is probably something stuck in the filter, that is preventing it from pulling out.
Try moving it from side to side as you unscrew it, and keep on doing this until it comes out.
Dec 18, 2010 | Zanussi Washing Machines
Cleaning the pump
The filter is part of the screw cover, there is probably something stuck in the filter that is preventing it from pulling out.
Make sure you have unscrewed it as far as it will go anti-clockwise, and try pulling it at the same time to loosen it.
Apr 30, 2010 | Washing Machines
I have a ge front load washer that won't drain i have stuck a coat hanger through the drain hose it doesn't seem to be clogged up.
take front cover off at bottom. there is a fiter that unscrews. be prepared for water to come out. clean filter and replace, good luck.
Jan 29, 2010 | GE WSXH208A Front Load Washer
Cannot unscrew housing around water filter seems stuck,
Open the freezer side and turn ice maker off. Leave freezer side open and try unscrewing the filter housing again. It will still be snug but keep turning and it will come off. Mine was stuck too but this worked. Good luck.
Jan 17, 2010 | Frigidaire FRS3R5EMB Side by Side...
Indesit wil 103 filter
stale smell may be due to using liquid detergent - change to powder.
filter may be of two types. if in the front, unscrew cap and just pull. may be difficult is a foreign object like a bra wire is stuck inside.
other type of filter is in the large diameter pipe from bottom of machine to pump. take off small back bottom panel and undo this pipe at the machine end and filter is inside this pipe. pull out and clean
Sep 04, 2008 | Indesit W 123 Front Load Washer
Refrigerator side freezing
kjn, I think what happened here is that the automatic damper assy. is stuck in the open position. This is why everything froze in the refer area. This includes the water filter and cartridge. I would unscrew the filter cover and see if it's frozen in there. If you find the filter frozen, take a hair dryer and go over it lightly until it will unscrew. After that you will have to check to see if the damper is stuck. You should be able to hear it open and close by turning the control on and off. Or get a mirror and hold it at an angle in back to see the gates. Part number for the damper motor is 240440701. Not that hard of a job...Catriver.
Jun 14, 2007 | Frigidaire FRS26R4A Side by Side...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
