Question about Canon PowerShot S5 IS Digital Camera
Canon S5 IS Powershot - Display Screen/Viewfinder Darkens
The display screen and viewfinder darkens prior to taking a photo in every mode except for Sports mode. I found mention in the Adv Manual that this could occur when taking photos in bright light, but is not recorded darker. This occured with our camera when taking photos in the evening with good light, but not bright, from one picture(ok) to the next (dark). As a matter of fact, I have taken photos with the camera prior to this in all light conditions from sunny beach to a dimly lit room and have never encountered anything like this. The condition is recorded and occurs at any light now in every mode except sport mode, thus making the pictures dark. I did find mention of someone getting underexposure on one of the problems on your site, but the solution did not fix my problem. I have tried the ISO setting in the auto mode, but it doesn't matter if it is on auto or on High. Do you have any ideas? Thanks.
I have the PS S500. It will not take pictures now, it flashes, but there is nothing on the playback. In fact, when I look at the image before taking a pic, there is nothing there. Sort of like there is...
is the screen displaying anything at all? if not have you tried looking into the viewfinder? occasionally cameras with viewfinders will display pictures on in the viewfinder and not the screen.
Try taking a photo and then check to see if the photo is there on a computer.
other than this, the camera unit inside the camera may have become damaged or detached, it this is the case, unfortunately, there is nothing you can do
May 04, 2011 | Canon PowerShot S500 IXUS 500 Digital...
No image is available to view on the lcd screen canon ixus85is
Click the "disp" button. The display of the camera has been turned off in the LCD screen but you can still use the viewfinder, this functionality is just for those who prefer to use the viewfinder instead of the LCD screen.
Jul 23, 2010 | Canon PowerShot SD770 IS / IXUS 85 Digital...
Screen went black
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Feb 27, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
When I turn on my camera the LCD screen is balck and I cant see anything thruough the lens. It does take pics because when I upload the disck Ic an see the new pics
Double check if the viewfinder is operable (not the LDC but the little thing you look through with one eye above it). Try pressing the display button to flip through the different modes as you're looking through the viewfinder. If the viewfinder does work (and the LCD screen doesn't come on as you're scrolling through the modes) then it is most likely dead (broken). If the viewfinder works, you're can still use the camera otherwise it's probably time to get a new one.
Dec 09, 2009 | Canon PowerShot S3 IS Digital Camera
LCD screen is black in Photo mode Canon SD1100;
Press DISP. button, and repeat untill the display shows up
Aug 10, 2009 | Canon PowerShot SD1100 IS Digital Camera
Blank screen
Sounds like you accidentally pressed the DISP (Display) button on the back of your camera. This manually turns the screen on and off in picture taking mode to save battery power. You could then use the optical viewfinder in its place. To turn it back on, just the DISP button one more time.
Jul 07, 2009 | Canon PowerShot SD600 Digital Camera
Canon PowerShot S5 IS Digital Camera Logo
162 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
