Question about Kenmore 24902 Top Load Washer
The washer will not call for cold water.
Only hot water comes out. I checked the cold water line and it is not clogged. bad switch?
    Problem Solver:
  • 13 Answers
I would expect it to be the solenoid valve, either stuck or dead. I don't know the specifics of how the machine is wired, but if you can swap the control wires from the hot water solenoid to the cold water solenoid, and from the cold to the hot, then if you still get only hot water you know the switch works and the solenoid is dead. If you get only cold after swapping the control wires, that means a bad switch. Depending on its design, if the solenoid valve is bad you may be able to pull it out, clean it up (be careful if you take it apart -- there will be small springs inside) and make it work again.
Posted on Jun 14, 2009
  • 867 Answers
If all water supplies are clear, yes faulty switch. make sure you checked the screen on the water supply, both ends.
No cold water coming into washer
There is a screen in the water inlet valve that gets clogged. Turn off both hot and cold water, take off the cold water line and clean screen out. If screen is clean, set to cold water wash and turn on the washer. You should hear the solenoid hum. If you hum, check the leads to the cold water solenoid. With the washer set on cold and turned on you should read 110VAC across the wires. If you have voltage the solenoid is bad. If no voltage, broken wire or timer problem.
Dec 31, 2012 | Washing Machines
When i use cold water it does not flow into the washer. only the hot water side works. i hooked the cold water line to the hot side and the cold will flow. what could be the problem on the cold side?
HI when you take the hoses off the washer look back inside the valve and see if the screen is clogged, if you dont see a clog, you need a new water valve, usually costs around $30-70.00
Sean
Mar 30, 2011 | Whirlpool Washing Machines
Cold water doesn't run into washer on any part of the wash/rinse cycle. Checked cold water line but not plugged uphecked back of washer where water line connects and no clog there either. Makes a...
Sounds like the valve isn't working properly.
One way to test is to turn off the water supplies and at the back of the machine switch the hoses.
Turn on the water and see if you get cold and not hot . If so replace the valve assembly
Jan 23, 2011 | Maytag Washing Machines
The cold water stopped while filling the washer. Will not come back on. I washed one load fine and then it quit. Model # 417.98702891, serial # XE04601499. Please help!
try and change the water temp selector switch.if the hot water is working.make sure to also check the cold water supply and make sure it is not clogged.you may need to replace the water valve.you can also swap the water lines and try to fill the unit if cold water is selected then you will get hot water if you do not then replace the fill valve.
Oct 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
My washer didn't stop filling and overflowed. Is
un plug washer and turn hot and cold water on,if water come's in than you have a bad water inlet valve.if water doe's not come in than you nead to check the line from the water leavel switch to the outer tub.if line is conected on both end's and ther are no hole's in it,than you have a bad water level switch.
Nov 24, 2009 | Washing Machines
Cold water is not filling when water temp is set to cold. When set to warm the washer will only fill with hot water. Appears that the cold is not working at all. I took the cold hose off of the washer and...
check the inlet screens inside the water mixing/inlet valve on your machine, they may be extremely clogged causing your troubles.
if they are not clogged up you need to verify whether line voltage is making it to the inlet valve allowing it to open, if present the valve is bad.
if not determine if your temperature control switch is bad, but usually its a water valve or screen..
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | Kenmore Washing Machines
I can't get the cold water to fill the tub/rinse. the hot works.
Your problem is either a clogged COLD fill valve or a bad water fill valve. Turn the water off. Remove the COLD hose from the WASHER. Check the filter screen inside the valve for sediment. If you find sediment,remove the screen and clean it. Replace the screen and turn the water back on. If you do not find sediment on the screen,replace the water valve.
Sep 21, 2009 | Frigidaire FWS1339A Top Load Washer
Washer Fills HOT WATER ONLY
If you checked the screens at the water inlet valve and they were not clogged, then you probably have a defective water inlet valve and will have to replace it. Hope this helped.
Jul 19, 2009 | GE WJSR2070B Top Load Washer
No cold water, only hot
The cold water inlet line is either clogged (it has a filter screen in it) or the cold-water solenoid valve is malfunctioning.
Remove cold water line, check for obstruction -- if no success, inspect electrical connections on solenoid valve (where the cold water line attaches to the back of the machine). If valve is getting current, take it apart and clean it. If that doesn't work, replace the solenoid valve.
May 29, 2009 | Washing Machines
Whirlpool LSR6132EQ1 Washer - Doesn't Rinse
I'm having the same problem with mine, but it's staying hot instead of cold. I've been reading about it, and it could be a kink in one of the water hoses (simple fix). The filter where the water comes in at could be clogged. The water inlet valve could be bad (which I'm thinking this is what is wrong with mine). This post is old, but just in case someone else is looking for this info... From website: http://www.acmehowto.com/howto/appliance/washer/diagwasher.php
Jan 09, 2008 | Washing Machines
Kenmore 24902 Top Load Washer Logo
78 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
