Question about Amana Comfort Zone 12M32PBEH Air Conditioner
Rheem criterion gas furnace
Air conditioner was installed in house 17 years ago when house was built, now will run, but will not blow cold air. first time has happened. any suggestions on where to start? I have already checked the filter, no luck!
  • steve
    steve May 11, 2010
    Is the outside unit running? Is there warm air coming from the top of the outside unit above the fan?
    Problem Solver:
  • 6 Answers
Check freon, you will need guages on the condensor, also make sure the cond, outside unit is operating
Posted on Jun 14, 2009
LX2000 gas furnace. It starts and runs for about 5 seconds, then why does it shut off?
Fix Furnace Flame Sensor (Flame That Goes Off) - YouTube
? 1:22
https://www.youtube.com/watch?v=fBJ3r9MUa-U
Nov 29, 2011 - Uploaded by RochNoure
A Furnace Flame Sensor is a safety device that reads the temperature and ... easy fix, but the furnace is ...
Troubleshoot the ignitor of the Rheem RGDA model gas ...
? 5:53
https://www.youtube.com/watch?v=Bx1pXONg2Oc
Dec 12, 2012 - Uploaded by grayfurnaceman
Troubleshoot the ignitor of the Rheem RGDA model gas furnace.... Jun Sim 5 months ago ... My lennox ...Missing: lx2000
Rheem Criterion II No Heat - YouTube
? 0:47
https://www.youtube.com/watch?v=yOSk6qvpWbA
Jan 7, 2010 - Uploaded by Work12Progress
Rheem Criterion II gas furnace model # RGPH-07EAMGR. When a call for heat is made t wo green led's ...Missing: lx2000
Heater will not kick on unless... [Archive] - Self Help Forums
www.selfhelpforums.com/archive/index.php/t-2153.html
Oct 19, 2004 - 25 posts - ‎9 authors
After a certain amount of time of not running, the heater will refuse to kick back on. ... 2 flashes, then a 2 second pause = pressure switch is open. What do .... On LP gas furnaces, the spark starts and the gas valve opens. ... Buffing them up with a little steel wool (5 minute job) is a good annual PM thing to do.
Dec 16, 2015 | Heating & Cooling
Are there any recalls on a Rheem Criterion II Model No. RGPH-05EAUER in WI? I have a house that was built in '98. The furnace doesn't dry out the air enough and tons of moisture has built up in the house...
there have been several situations wht rheems as far as control boards cracked heat exchangers cracked inducer assemblys and touchy pressure switches i would call to get a furnace inspection from a rheem dealer
sounds like you really need to buy a portable dehumidifier
Jul 06, 2009 | Heating & Cooling
Rheem Criterion II air conditioner runs but it does not cool
Check air temp out vent should be approx 20 degrees colder than room temp if it is your unit is too small for the amount of space you are cooling.Rule of thumb 1 ton(12,000btu's) for every 400 sq ft of uninsulated space
May 30, 2009 | Amana Comfort Zone 12M32PBEH Air...
Rheem criterion II flame stays lit for a few seconds then only cold air blows through the house
Your furnace needs a tune-up. MODERN FURNACES REQUIRE REGULAR MAINTENANCE!
Mar 10, 2009 | Goodman GMS90703BXA Heater
(HVAC) Furnace Not Igniting Quickly
Make sure a back draft in the flue is not happening. Wind can blow it out until the flue heats up. The flame sensor may not be close enough to the burner flame. It may be weak and need to be replaced or if its an optical one it may be dirty and not see the flame very well. Its not wasting much gas but it puts extra wear and tear on the gas controls, is noisy, and, as you said, blows cold drafty air. A gas control system that has issues of any kind is not real safe. It needs to get fixed.
Jan 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Rheem Criterion II Furane would not ignite
what you need to do is take and inspect the hose that goes to the pressure switch and make sure that it is not dry rotted. if it is and the combustion blower is running then firsat try to cut the hose down and slip on a better piece of rubber. If not then replace the hose,
Dec 25, 2008 | Heating & Cooling
Carrier Furnace wouldn't light, fan was running all the time.
Most furnaces have a photo cell if it gets dirty the photo cell does not see a flame so it trips the reset button on flame failure.
May 13, 2008 | Heating & Cooling
Amana Comfort Zone 12M32PBEH Air Conditioner Logo
268 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
